Old 07-13-2009, 10:33 AM   #571
jeff1's Avatar
Hello
I am having trouble to remove the Head Button from sleeve. I managed to remove the sleeve from crankcase and the head button came together. Its stucked.. have no idea what to do.
jeff1 is offline   Reply With Quote
Old 07-13-2009, 11:06 AM   #572
2 ways to do this. You can heat the sleeve and sometimes you can get it to loosen up before the combustion chamber can expand or you can take a round piece of wood so as not to damage the combustion chamber shape or the metal remove the glow plug and hold the sleeve in your hand firmly do not put the sleeve into a vise where it will most certainly be damaged. A few small taps should be enough to free it. The piece of wood should be round and will go into the end of the sleeve and use it drive it out. You then can use some very fine sand paper wet/dry at least 1000 grit or higher and remove very little material on the side of the chamber so as it goes into the sleeve with a snug not tight fit. Do not make it so it is loose. You want a good seal all around the sides and bottom of the chamber.
xspower is offline   Reply With Quote
Old 07-13-2009, 01:01 PM   #573
jeff1's Avatar
Thanks Jerry I removed the head button
so how many shims should I run with 30% nitro? It has 0.50mm of shims. I am at 600m above sea level
Old 07-14-2009, 01:19 AM   #574
stefan's Avatar
Send a message via AIM to stefan
hey guys,
can you give me an idea about the characteristic of the new 2651 pipe set?
Is it a rpm pipe or rather a torque pipe?
Thx.
stefan is offline   Reply With Quote
Old 07-26-2009, 11:20 PM   #575
keavze's Avatar
Default IDM evo3 spec2
hi guys,
how to tell the .12 IDM evo3 is spec2 from spec1?
the only difference is only the carb material used?
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 07-26-2009, 11:30 PM   #576
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Originally Posted by keavze View Post
hi guys,
I never saw a spec 2 carb with the .12 engine.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 07-26-2009, 11:40 PM   #577
keavze's Avatar
Originally Posted by PMSorber View Post
The new EVO3 (Spec-2) has a total new carburator. New reinforced plastiks, new lowspeed needle, new idle screw and liner, different alu.
This carburator will not leak or deviate during driving.
post#514 is talking about .21 evo3?
Old 07-27-2009, 06:29 AM   #578
The Spec 2 .21 has a slightly different piston/sleeve set the location of the wrist pin is different then the original case for the EVO3 also the new runs have a new carb completely this was a running change in the line. Now as the carb changed on the .21 they have also changed on the .12 as well. They have a steel slide as well as the other changes mentioned in the above post with the plastics and such. There is not a Spec2 EVO3 .12 though. At least that I have seen here in the states.
Old 07-29-2009, 03:36 PM   #579
Send a message via MSN to PMSorber
Yes and the EVO4 .12 as well. The latest version also has a new connection ball-joint with a scale for fine-tuning. Also the material of the LS needle has been improved.
And now to the Worlds at Lostallo Swiss!
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Old 07-29-2009, 11:52 PM   #580
Got another EVO4 today and finally got the new 2651 pipesets.
Old 07-30-2009, 07:25 PM   #581
gentleman81's Avatar
are u a dealer?
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 07-30-2009, 07:40 PM   #582
Originally Posted by gentleman81 View Post
are u a dealer?
No, just a driver. I believe that winners circle carries the IDM stuff.
http://www.winnerscirclerc.com/index...1181d8b9353bb8
Old 08-08-2009, 08:41 AM   #583
keavze's Avatar
hi guys, need some advices/comments:
my .12 evo3 power will only come on at about 270-280F, seems a bit on the high side?
if i rich the HSN to bring the temp down to 250-260F, there's simply no power at all...
air temp here is about 80F (humidity about 70%) and i'm running 25% nitro with total head shims of 0.5mm using idm #6 plug.
by the way, pipe 2651 is similar (or closer) to 2617 or 2607? any reviews using 2651 with evo3?
Old 08-08-2009, 11:37 AM   #584
Richen the LSN you are way to lean on the bottom. Not the top. The engine will tune a bit backwards from a Nova when you build heat up quick it is most of the time due to the LSN not the HSN. Hope that helps out. Also the pipes are really the best of the both of them better top like with the 2617 and good lower power with the 2607
Old 08-08-2009, 06:28 PM   #585
keavze's Avatar
is it due to the design of the carb or picco engines just need a richer LSN (not due to the carb design)?
i've tried richen the LSN slightly but it'll bog. the bog will only be present if i'm off the throttle and it's sitting for about 2s. however if i'm off the throttle and i immediately give it gas agin, it'll be fine...
CEN Products SCOOTER29 Rookie Zone 9 09-22-2005 01:57 AM
cen products chifan26 Nitro On-Road 7 09-19-2005 02:50 PM
