Old 01-01-2008, 01:32 PM   #166
MugenDrew's Avatar
Trader Rating: 30 (100%+)
Default Picco parts
Mr. DeYoung you have a P.M.
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 01-07-2008, 10:58 AM   #167
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
Default new motor
do all the carburators go in so tight? hopefully i didn't mess up the low end needle, because the idle screw was set to low and when i was holding the slide closed it (the low end needle) was pushing into the brass seat and may have damaged it. I guess I'll see when i tune it. I've never had another carb go in that tight before. Let me know thanks
Speedypeterb is offline   Reply With Quote
Old 01-07-2008, 02:20 PM   #168
The carbs go in tight. they are composite with a small piece of aluminum protruding from the base. We usually take a piece of fine emery paper or wet/dry sand paper and lightly smooth it down a bit if the fit is to tight. Then it should work down into the case fine with no resistance. That is what we have done in the past with them and have had good luck. Also there are some of the pinch bolts that do not allow the carb to tighten all the way. We remove a bit of the end material that faces each other and then the carb tightens fine. We usually remove about 1/2 mil.
xspower is offline   Reply With Quote
Old 01-07-2008, 02:21 PM   #169
Sorry did not even see it. replied to.
Old 01-07-2008, 06:57 PM   #170
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Brother Jerry!!!
Called you a few days ago.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 01-07-2008, 07:14 PM   #171
MugenDrew's Avatar
I'll make your phone ring tommorrow...
Old 01-15-2008, 06:30 AM   #172
Thank you Jerry motor was perfect & made time.
RanRhodes is offline   Reply With Quote
Old 01-15-2008, 10:34 AM   #173
MHarrison's Avatar
Jerry, The Motor Was Flawless, Qualified 3rd in the A-main WinterNats Pre Race.
Plenty of run time, And Good power all around.
MHarrison is offline   Reply With Quote
Old 01-15-2008, 01:20 PM   #174
I will take the TQ that Ryan got at the race and also how well Mark and chris also did at the race. I am glad to see that the motors are working out well now. And it is good to see that you guys are happy with the motors. Thanks
Jerry
Old 01-23-2008, 07:21 PM   #175
MugenDrew's Avatar
Default hey! you out there
[email protected]
Old 01-23-2008, 07:56 PM   #176
Team Kamikaze's Avatar
Originally Posted by Scott Fisher View Post
Brother Jerry!!!
Jerry,
I did not know that Scott is your older brother
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 01-24-2008, 05:10 AM   #177
It happens I try to keep it quiet!!! LOL
Old 01-24-2008, 10:41 AM   #178
now you know why I refer to him as kamicrazy!
Old 04-12-2008, 11:26 AM   #179
These motors are awsome folks, ive just recently started to run these engines and im amazed how fast they are! If you are in the market for a New Engine you have got to try these! My opinion the best engines on the market!
Jeremy Cupps
Sponsors are
Mugen Seiki, NovaRossi Engines, Enneti Tires, Byrons racing fuel, Airtronics, XceedRC, Mikes HobbyShop Porter Texas, Global Hobby Distributors, Avid Bearings, Paint by Smiley, and my wallet!
J-MAN is offline   Reply With Quote
Old 04-13-2008, 01:11 AM   #180
kcrunchone's Avatar
I must say that after some time and observing the engines that there must be major differences in the Red Dot and the IDM EVO3 since most people that I have spoken with have had carb issues and having leaks and using additional sealants to stop the leak. The IDM EVO3 does not leak and has just about matched up in my views with all engines on the track.
With the 2607 pipe it has performed well no complaints here. The season opened up but I have not run yet first race out just making sure the club issues went over well next race I will break in and get to test and tune and see how the engine recovery and the switch to the new fuel will be.
Rick Hill
"Failure Is Not An Option"
kcrunchone is offline   Reply With Quote
CEN Products SCOOTER29 Rookie Zone 9 09-22-2005 01:57 AM
cen products chifan26 Nitro On-Road 7 09-19-2005 02:50 PM
