Old 02-11-2007, 03:16 PM   #1
LOWGEARED's Avatar
Default MACH 15 RE breakin help
I own a LOSI XXX NT SPORT
IM on my 4th tank and I can get it to start. but as soon as I give it throttle it dies ...
Also when I take the glow ignitor off itll die after 5 seconds sometimmes immediatly. But the plug is brand new just changed today?? What can I do to fix this?
MEGA BAJA HOP UP LIST:
GPM BLUE ALUMINUM THREADED SHOCKS
LOSI YELLOW SPRINGS
GPM BLUE ALUMINUM A-ARM SET U/L
ACNCM ENORMOUS COOLING HEAD
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
ALUMINUM PIVOT BLOCKS
FULLY ADJUSTABLE C/C/S
LOWGEARED is offline   Reply With Quote
Old 02-11-2007, 04:04 PM   #2
MassiveMods's Avatar
Sounds to me like your engine is still rich , Try leaning it off on the HSN 1/4 turn clockwise and see where you end up. It could also be a case of not having a hot enough plug for the fuel you are using.
Whats the nitro and oil content of your fuel ?
Engine development manager Rifling Pty Ltd. Nitro fuel designer : Neo + World record title holder 2012 Austalian Nationals 147.6 KPH , 1 st 2 nd and TQ Australian National Buggy titles 2012. Victorian State title 2012 Neo + , South Australian state title ON and Off Road 1/8 2012 Neo + :-) QLD State Titles 2012 1st buggy & trruggy + TQ Neo + MG66 RX7 1st Sportsman Class Truggy QLD State Titles 2012 !! Nitro Addicts Australia . com
MassiveMods is offline   Reply With Quote
Old 02-11-2007, 04:50 PM   #3
LOWGEARED's Avatar
Im usin O'donnell Racing fuel 20% .. I got it running after Idling it through a whole tank! Rapped it up took it oout done some passes and was running 210 to 225 5th tank including the idle tank! turns out Its just not cut for factory settings in these weather conditions. SO I started from 3 on hsn and 2 1/2 LSN with a high Idle as I noticed it was trying to move on me so I backed it down and my temps stayed fine so Im wondering ? If Im taking it up 3/4 throttle and it whines and sputters a little is that good
breakin setting? NOTE: A tiny bit of fuel was blowing out the pipe when this was goin down!
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
breakin benches spudly12 Nitro Off-Road 11 01-24-2008 07:10 AM
BREAKIN IN A XXX NT HELP LOWGEARED Nitro On-Road 8 02-10-2007 10:25 PM
O.S. .12tr Breakin raptor 700 Onroad Nitro Engine Zone 2 06-26-2006 05:20 PM
WTT: Used DYN Mach .26 with Cooling Head for Mach .21 absolut_racer R/C Items: For Sale/Trade 0 02-28-2006 08:45 AM
motor breakin! speedxl Electric On-Road 12 10-10-2003 10:42 PM
