-   Onroad Nitro Engine Zone (https://www.rctech.net/forum/onroad-nitro-engine-zone-71/)
-   -   head mods (https://www.rctech.net/forum/onroad-nitro-engine-zone/148987-head-mods.html)
MassiveMods 02-24-2007 03:22 PM
What ive found with taking out fro the Geo Dome is you get a few things happen
1 Lower geometric compression = Higher RPM and slichtly less torque
2 Cooler temps from the head
3 Greater turbulence in the cylinder which promotes responce and fuel economy
To what degree of improvements depends on the individual situation. I tried the Multi cut about 4 years ago with a P5 off road engine , I cut about 4 head buttons and each week i gauged their results by swapping out for each race meet. I did this with a standard and turbo button and found the greatest gains from a single notch in a turbo facing the exhaust.. BUT ! i tried a 3 notch in a standard head button.. 1 in the front above the front intake port and 2 on a 45 deg andgle towards the exhaust. I then cut back the head button .2 mm to reduce its standard ratio and took a .2 shim to bring it back.. ..
I was a mennace ! it sounded like a rotary engine lol It created a lot of torque and great top end .. But rear bearings and rods wore very quickly..
MM
40% 04-18-2007 06:49 AM
Originally Posted by MassiveMods
i tried a 3 notch in a standard head button.. 1 in the front above the front intake port and 2 on a 45 deg angled towards the exhaust. I then cut back the head button .2 mm to reduce its standard ratio and took a .2 shim to bring it back.. ..
I was a menace ! it sounded like a rotary engine lol It created a lot of torque and great top end .. But rear bearings and rods wore very quickly..
MM
Bro u meant u shaved the button to .02mm and u added .02 shim ?. Did any timing problems arise with the notch facing the front intake?. What was the average fuel consumption b4 the bearings or conrod starts to show signs of wear?
40% 01-27-2008 10:09 AM
MM
Indeed it does sound like a rotary engine. I've mastered the technic and have modded all my engines with the 3 grooves for standard plugs. Has that different sound and power is on demand :)
razzor 07-15-2008 03:25 PM
Pics please !!! :)
Roelof 07-15-2008 03:45 PM
Originally Posted by razzor (Post 4639791)
Pics please !!! :)
http://truggy.nl/e107_plugins/conten...fuelklein7.jpg
Directly from: http://www.somender-singh.com/
Rc gur 12-27-2021 09:56 AM
Head mods
I am pretty sure the one scoop is for turbo burn rooms and has to be above the exhaust port
Rc gur 12-27-2021 09:58 AM
I know this is a dead thread but this has great info on here!
Roelof 12-27-2021 12:44 PM
The one large scoop has nothing to do with Turbo buttons, that mod was already done before turbo plugs existed. The last engine I have bought with a default manufactured scoop was the RB C5 Rody, a follow up of the normal C5. It also came with a forged piston but sad enough we did not get it on full performance, after sending it back to RB it came back to me with a normal button.
The Sing grooves do something. I did such a mod on the track with a same engine with a before and after mod. Just 3 small grooves gave a more solid shift from 1st to 2nd gear and you do see a coloring over the squish band prooving the small gooves do the steer some mixture into the squishband where the combustion in the small gap will give some power. But you can discuss if the performance comes from changing the total volume of the combustion room by just the 3 grooves and so giving a tiny different ignition timing or is it realy a better spread combustion?
