Old 02-08-2007, 05:17 AM   #16
MassiveMods's Avatar
i would say the biggest rod killer is cold temp run in. The rod cops a beating when its new, tight and cold run in rich. If you can immagine a sleeve tapered at the top and a piston non tapered. if the sleeve dosent get to expand through heat then the piston smashes into the taper. This shock then gets transferred to the rod bushing, crank pin and bearings.. Both on and off road engines punish the rod / pin relationship , there is a lot of free revving in off road , with less resistance it can really speed up wear. Im amazed that engines las as long as they do...
Engine development manager Rifling Pty Ltd. Nitro fuel designer : Neo + World record title holder 2012 Austalian Nationals 147.6 KPH , 1 st 2 nd and TQ Australian National Buggy titles 2012. Victorian State title 2012 Neo + , South Australian state title ON and Off Road 1/8 2012 Neo + :-) QLD State Titles 2012 1st buggy & trruggy + TQ Neo + MG66 RX7 1st Sportsman Class Truggy QLD State Titles 2012 !! Nitro Addicts Australia . com
MassiveMods is offline   Reply With Quote
Old 02-08-2007, 05:21 AM   #17
Originally Posted by MaDaGAS CAR
funny man u are itchy b but great idea, wat tool do u use to remove them?
I use a jewelers flat blade to carve it out. the bag trick is a good one too or just line it up with the flat blade and place the thumb over the clip so it cant fly off into the vally of the lost clips .. You know theyre trying to escape ...
Old 02-08-2007, 11:43 PM   #18
MaDaGAS CAR's Avatar
Send a message via MSN to MaDaGAS CAR
is that jewelers flat blade thingo 1 of those reali tiny screw drivers that u get with bout 6 other drivers in a small packet if u know wat i mean
MaDaGAS CAR is offline   Reply With Quote
Old 02-09-2007, 02:38 AM   #19
woo hoo got out those stupid pins i__i but now how do i put them in lol
Old 02-09-2007, 05:46 AM   #20
M7H
M7H's Avatar
trail and error......
Ehh, but it is better to use new clips.....
Serpent
M7H is offline   Reply With Quote
Old 02-11-2007, 02:14 AM   #21
got no new 1s on hand but ill order sum to have if i ever do need em cheers
Old 02-11-2007, 04:17 PM   #22
To put them back in a have a modified bent long nose plier, its got a small pointed nose with really flat even surface, i grip the tail of the clip ( end that curves in ) and push the end into the groove, i then twis the clip to make it smaller as i push it into the groove, i then cover the hole with my finger and push the gudgeon pin towards it to make sure its clipped in. I then rotate it in the groove so that the tail is facing sideways. Beware the tail is not bent outwards in any way... it can catch when hot and total your piston
OS .21 conrod no4hitter R/C Items: Wanted to Buy 3 06-17-2006 02:37 AM
OS VZ-R/VZ-B Conrod and Nova P5 Conrod rod_b R/C Items: For Sale/Trade 2 03-21-2006 06:58 PM
When changing P/S, also change the conrod? chachi Nitro On-Road 3 02-22-2004 06:00 AM
ACC P/S and conrod xtreme888 Nitro On-Road 10 10-02-2003 08:51 PM
JP conrod manokgt4 R/C Items: Wanted to Buy 0 01-12-2003 10:12 PM
