-   Onroad Nitro Engine Zone (https://www.rctech.net/forum/onroad-nitro-engine-zone-71/)
-   -   Done with pullstart- Converting to non-ps? (https://www.rctech.net/forum/onroad-nitro-engine-zone/144192-done-pullstart-converting-non-ps.html)
Aflem 01-11-2007 03:03 PM
So today marked the day in which I am DONE with pullstarts. I have now purchased a starter box and would like to put a backplate on the engine(an O.S. .12 CV-RX) since I wont need the starter anymore. I know I will need the backplate itself, but will I need to modify or replace the crankshaft as well? I know the PS version of the crankshaft has the small nub for the starter assembly, but will this nib prevent be from installing a backplate cover?
Any help is appreciated, thanks.
Rapid Roy 01-11-2007 03:38 PM
You will need to cut the nub off of the crank to convert it or you could buy a new crank. You could also just leave the pull start on and just use the starter box to start it.
Artificial-I 01-11-2007 04:19 PM
Couldnt have said it any better or quicker or simpler. +1
