Old 01-24-2007, 08:24 AM   #16
ALG
Grinder Quote:
Originally Posted by Rich Browne
They are available in standard and turbo plug (Nova Rossi or Sirio only). Custom made and usually not in stock from local hobby shops - these are for the "ultra-racer"
Purchase from Ashford Hobbies:
http://www.ashfordhobby.com
I know Ace Hobbies had some in stock (They're closing soon - better call quick): http://www.acehardwarehobbies.com
I would prefer you purchase from these sources. I am happy to help with Tech Questions. Our phone number is listed on the Empire site.
I use mine constantly. It is the easiest way to accurately measure head clearance that I have found. Great tool. Thanks Empire!
Dear Grinder, that is the ONLY and correct way to measure the head clearance, only if you are serious about the hobby
Have fun on the Winters!!!! and keep us posted with your engines
ALG is offline   Reply With Quote
Old 01-24-2007, 08:37 AM   #17
ALG
We should also state that the comments with regards to plugs and head shimming are when both are used together. Used alone a hotter plug will rev harder and a colder plug will make more torque.
AFM, I think this is vice versa. When you put a hotter plug, the ignition will be sooner, this is like advancing the cams of a car, if you advance the cams you will gain torque, and if you put a colder plug, this is like retarding the cams, making high end better.
As you know all of this is theory on a 4 stroke, can it be aplied on 2 stroke engines?
Old 01-24-2007, 10:30 AM   #18
afm
afm's Avatar
You answered yourself......"all of this is theory on a 4 stroke"...the corect answer is to long to post here, and I have it in Spanish...I'll send you a PM
AFM
afm is offline   Reply With Quote
Old 02-01-2007, 09:32 AM   #19
nitro_moe's Avatar
I got a question..??
Is it ok to put three 0.1mm shims in order to use 30% fuel ?? I checked my engine and although I know it is supposed to come with a brass and a silver shim. However, my O.S. TZ 12 came with two brass shims. So I added one more. I think I have got the right head clearance in theory, but is it normal to have three shims clustered like that under the engine head??
Thanks..
nitro_moe is offline   Reply With Quote
Old 02-08-2007, 01:37 PM   #20
rmdhawaii's Avatar
I finally got a chance to thoroughly read Dennis Richey's article posted above and it is really awesome info.
Can anyone help me find tune this info into some type of procedure/guide? It may not be possible, but I sure would like to try.
1. Measure head clearance.
2. Based on head clearance, choose your nitro %: (Maybe thse should be ranges)
a) .36mm or less, use ??% nitro
b) .46mm or less, use 20% nitro
c) .??mm or less, use 25% nitro
d) .56mm or less, use 30% nitro
If you need to use a higher or lower % nitro, add or remove shims.
3. Choose your glow plug:
And this is where the fun really starts...
afm posted this a while back.
http://www.rctech.net/forum/showpost...9&postcount=22
How to select the proper plug:
- When the ambient temperature is high, we have to use a plug with thicker wire.
- With higher compression, we have to use a plug with thicker wire.
- Humidity determines if we use a Cold (F) thermal range, or Hot (C) thermal range.
- With high humidity percentage we should use a Hot (C) thermal range plug.
- If we have high temperature and high humidity, we should use a plug with thick wire and a Hot(C) thermal range.
* Thermal Range: F (Fredda = Cold) C (Calda = Hot)
Is the opposite true?
- When the ambient temperature is low, we have to use a plug with thinner wire.
- With lower compression, we have to use a plug with thinner wire.
- With low humidity percentage we should use a Cold (F) thermal range plug.
- If we have low temperature and low humidity, we should use a plug with thin wire and a Cold(F) thermal range.
Now there is also this info:
The best instrument to determine which Turbo Plug to use, is those weather panels they sell for Yachts, that have Temp, Humidity and Barometric Pressure on them. Have it calibrated at your local weather station, and bingo, you’re ready like the Pros.
That is the key to success or failure tuning engines with Turbo Glow Plugs, because they are so sensitive to weather variations that is unbelievable.
Following is a selection chart for Novarossi Turbo Glow Plugs:
Code:
Type  Thermal Range        Nitro%  Temp C / Temp F Humidity%
C5TC  Hot/hot wire         10-20    0-10  / 32-50  70-100
C6TC  Hot/average wire     10-20   10-16  / 50-61  70-100
C7TC  Hot/cold wire        20-30   16-25  / 61-77  70-100
C8TC  Hot/ultra cold wire  20-30   25-up  / 77-up  70-100
C5TF  Cold/hot wire        20-30    0-10  / 61-77  40-70
C6TF  Cold/average wire    20-30   10-15  / 61-77  40-70
C7TF  Cold/cold wire       20-up   16-25  / 61-up  40-70
C8TF  Cold/ultra cold wire 20-up   25-up  / 77-up  40-70
At this point clutch setting and gearing play a role - not just the fuel, plug and head clearance. What are the troubleshooting steps before changing any of the above?
- If your engine overheats:
Cluch/gearing?
Troubleshooting?
Engine Tuning?
- If you need more top end speed:
Cluch/gearing?
Troubleshooting?
Engine Tuning?
- If you need more bottom end:
Cluch/gearing?
Troubleshooting?
Engine Tuning?
- Not enough run time (< 5 min.):
Cluch/gearing?
Troubleshooting?
Engine Tuning?
- If you increase or decrease your nitro %
Go back to step 2 and adjust your head clearance
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 02-08-2007, 02:41 PM   #21
MassiveMods's Avatar
Thanks..
Yes 3 is fine , what you want to check is that once you have shimms in place check that you have some meat left in the head button to seat into the cylinder.
Engine development manager Rifling Pty Ltd. Nitro fuel designer : Neo + World record title holder 2012 Austalian Nationals 147.6 KPH , 1 st 2 nd and TQ Australian National Buggy titles 2012. Victorian State title 2012 Neo + , South Australian state title ON and Off Road 1/8 2012 Neo + :-) QLD State Titles 2012 1st buggy & trruggy + TQ Neo + MG66 RX7 1st Sportsman Class Truggy QLD State Titles 2012 !! Nitro Addicts Australia . com
MassiveMods is offline   Reply With Quote
Old 02-08-2007, 03:06 PM   #22
afm
afm's Avatar
Cluch/gearing?
Troubleshooting?
Engine Tuning?
Cluch/gearing?
Troubleshooting?
Engine Tuning?
Cluch/gearing?
Troubleshooting?
Engine Tuning?
Cluch/gearing?
Troubleshooting?
Engine Tuning?
Rainer
With respect to 1 and 2.....actually you first have to determine what Nitro% fuel you will run, because mainly it is determined by rules, like EFRA & IFMAR which only allow 16%. In the states most top drivers run on 30% nitro.
Once you have determined that, you measure your actual head clearance without shims, and then add neccesary shims to adjust your engine's combustion chamber accordingly.
Now this rough figures apply for .12 engines.
16% Nitro .36mm - .40mm
20% Nitro .40mm - .50mm
25% Nitro .50mm - .60mm
30% Nitro .60mm - .65mm
Then you select appropiate plug according to table , and yes opposite is true.
Then you have to set your clutch with initial reccomendtaions from manufacturer and the adjust your carburator on the track.
When you feel the engine is not fast enough, but working fine, first thing you should think about is ....
1.- Are the tyres sticking? Is the track clean without to much dust?
2.- Do you have the right gear ratio?
3.- Is the clutch properly tuned?
4.- Are the transmission and bearings smooth?
5.- The last way is to lean a bit your engine, and here are some key points:
* At first do not lean the low-speed needle keep it rich. If you want more low end torque, change to a thicker clutch spring or tighten the clutch nut.
* Always use the tallest 2nd gearing your engine can pull. No need to worry about if the tallest 2nd gearing makes the acceleration slower. If you find the car slowing down a bit when it changes to 2nd speed, then you may need to delay the timing of 2nd speed clutch.
* Just remember when you lean the HSN, you may need to rich the LSN at the same time. When you lean the LSN, you may need to rich the HSN also. If you move HSN for 5 mins, then move the LSN 10mins(double). Then you will find a balance point between HSN and LSN.
AFM
Old 02-08-2007, 03:54 PM   #23
rmdhawaii's Avatar
Sweet! Thanks Alfonso
Old 02-08-2007, 08:09 PM   #24
gashuffer's Avatar
Trader Rating: 48 (100%+)
Question? I have a .21 ninja that I just broke in, I added a third shim for this process. Should I remove it now that it's broken in? When you measure the distance between TDC in the piston what are you sopposed to subtract it from? Where do I measure ? I'm a newbie
T-Sal
gashuffer is offline   Reply With Quote
Old 02-08-2007, 08:11 PM   #25
gashuffer's Avatar
Where is the head botton recess located? Pics can help me alot?
T-Sal
Old 02-08-2007, 11:42 PM   #26
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Thumbs up
Cluch/gearing?
Troubleshooting?
Engine Tuning?
Cluch/gearing?
Troubleshooting?
Engine Tuning?
Cluch/gearing?
Troubleshooting?
Engine Tuning?
Cluch/gearing?
Troubleshooting?
Engine Tuning?
Great info. Thanks greatly appreciated
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 02-10-2007, 03:19 AM   #27
rmdhawaii's Avatar
This is one way of measuring head clearance...
Ultimate Nitro Engine Tuning DVD: "Checking Head Clearance"
http://videos.radiocontrolzone.com/n...ng_sample1.ZIP
Since you're running a .21 and not a .12, I'm not sure how the tuning info posted above applies to you, so just keep that in mind.
Old 02-10-2007, 08:43 AM   #28
how about some head clearance #'s for 21's maybe on 20% 30% nitro
Randyc is offline   Reply With Quote
Old 02-22-2007, 04:44 PM   #29
.006" for every 10% of nitro you will run starting from 0%
0% -- .006"
10% -- .012"
20% -- .018"
30% -- .024"
these are conservative numbers and will get you in the ballpark safely.
adam lancia is offline   Reply With Quote
Old 06-14-2007, 10:17 PM   #30
Grenade10's Avatar
Trader Rating: 37 (100%+)
0% -- .006"
10% -- .012"
20% -- .018"
30% -- .024"
Ok, so now what do you do if you race at 5200 feet in elevation, and very little humidity??
Thanks in Advance
Grenade10 is offline   Reply With Quote
What Glow Plug? Truggy007 Nitro Off-Road 11 12-01-2007 01:33 AM
RED DOT glow plug? aussies1129 Nitro On-Road 8 10-06-2007 11:11 PM
can old nitro fuel destroy glow plug? wothrottle Electric Off-Road 6 05-25-2007 10:38 PM
Can't Get Glow Plug Hot buggyrac3r Onroad Nitro Engine Zone 4 09-24-2006 04:42 PM
glow plug ? jonnyc Rookie Zone 6 03-03-2006 11:13 PM
