Old 03-18-2007, 03:51 PM   #61
am
Fact is, for me anyway and i just do not care what you guys says. Red putty in the crank works like a charm!!! I do not care shit whats the theory is behind it, it works. And it works even if the crank is not drilled and lightened. It is an advantage that it is drilled but it is not amandetory.
If you can not see this on a dyno, well, then the dyno is just not good enough!
am is offline   Reply With Quote
Old 03-18-2007, 11:22 PM   #62
Moderator
mxwrench's Avatar
Show me a better one then smarty!
BK
Brian Kinney
TLR Design Engineer
2016 Sponsors: Team Losi Racing, AKA Tires, Orion, Nitrotane, Horizon Hobbies, Fast RC Paint.
mxwrench is offline   Reply With Quote
Old 04-28-2007, 05:12 AM   #63
fritzD's Avatar
Send a message via Yahoo to fritzD
I have a black ATV slicone. Will this work? Or is the red one better?
What are the one of the putty coming off? If it does, its end of the engine?
fritzD is offline   Reply With Quote
Old 05-04-2007, 06:29 AM   #64
Jerseyboy's Avatar
I have been experimenting with this quite a bit and all I can say is that it does make a significant difference.
I noticed that after the mod the engines spools up quicker. Making the engines accelleration faster. I believe that when you add the silicone you flow the crank and you decrease the crank volume. In doing this the pump pressure is increased and this in turn gives rise to faster acceleration.
I found that with this mod it does take away alot of bottom end control. On loose tracks you tend to loose traction easy. This mod will definitely benifit on-road engines more.
Jammin X1 FTE
Upgraded to Warp Drive
KO Mars Ex-1 Spectrum Telemetry
Jammin JPX 21/OS Speed
Jammin X1 CRT
Go tech 21 5p
Upraded to Stelar Galactic
Jammin X1 CRT.5
Power by SH12
Either your Jammin or losing"Catch me if you can"
Team Dramatic
Jerseyboy is offline   Reply With Quote
Old 08-29-2007, 06:02 PM   #65
rmdhawaii's Avatar
Today was the first time I read this entire thread and I think it's really funny. Almost sounds like someone trying to convince people that they saw a UFO, the Lochness monster or Bigfoot.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 08-29-2007, 06:36 PM   #66
wallyedmonds's Avatar
yep
wallyedmonds is offline   Reply With Quote
Old 08-30-2007, 08:49 AM   #67
FREELANCE_RCer's Avatar
Trader Rating: 27 (100%+)
It definitely sounds that you're the "MISTER KNOW-IT-assHOLE" OF R/C
Ranier a.k.a. COREXHAWAII.
FREELANCE_RCer is offline   Reply With Quote
Old 08-30-2007, 11:03 AM   #68
rmdhawaii's Avatar
Nice.
I was going to try this (without the drilling) until I started reading some of the latter posts. I'm not sure what to make of it now. It made perfect sense to me before, but having mxwrench post that he doesn't see any difference on the dyno is making me think twice about it.
Old 08-30-2007, 04:39 PM   #69
Old 08-30-2007, 11:08 PM   #70
Colt4g63's Avatar
mxwrench knows a thing or two... So i would take his advice as he has made ALOT more dyno runs on the X-Dyno then all of us.
Adam Blevins Owner/Operator of AB Mods X-Dyno equipped and World Record holding engines!
www.ABMods.com
Colt4g63 is offline   Reply With Quote
Old 08-31-2007, 08:05 AM   #71
I've had motors that showed an increase in performance by adding material to the crank inlet area and some that you couldn't tell the difference, but I don't think (or at least what I want to believe ) that I've ever hurt a motor by doing this, (unless we want to talk about the one I siliconed on a Friday night broke in Saturday night and tried to run Sunday - boy undried silicone will mess up a motor!!!)
Rick Davis is offline   Reply With Quote
Old 08-31-2007, 10:50 AM   #72
JayL's Avatar
the dyno is giving you a plot of rpm/hp. It is not showing how much fuel is flowing to accomplish said HP, nor is is showing throttle response based on letting off alittle then nailing it for a corner.
I think you guys are both correct
It may not increase max hp or rpm but it could increase throttle response and/or fuel consumption.
I do know, neither JP nor Grinder would add something worthless to your engine, measurable or not
This thread is awesome, love modding discussion. I have sooo much to learn.
JayL is offline   Reply With Quote
Old 08-31-2007, 11:30 AM   #73
Derby Bros Racing's Avatar
So you mean to say maybe it's similar to a carb restrictor?? (just thinking as I'm not really sure). It won't really mess with the max RPM or HP but makes the motor act differently coming out of the corner due to different spool up?? If that is the case, then the putty can be an advantage.
Derby Bros Racing is offline   Reply With Quote
Old 08-31-2007, 06:52 PM   #74
rmdhawaii's Avatar
How much of a "per lap" performance gain have you seen once you've added a ramp?
Old 08-31-2007, 07:18 PM   #75
rmdhawaii's Avatar
True
... nor is is showing throttle response based on letting off alittle then nailing it for a corner.
It would be interesting to discuss the theory on what exactly is going on in the engine to impact throttle response. I don't know how or if throttle response can be inferred by the dyno results.
True
From a manufacturing standpoint, this seems easy and inexpensive enough to do, so why doesn't every engine come with a ramp?
Serpent Cleaning Gum/Putty German Muscle Nitro On-Road 10 05-19-2008 05:00 PM
Kyosho 777 WC New complete shock sets,Springs,Wheel shafts,Center shafts GMartinez R/C Items: For Sale/Trade 0 02-07-2008 07:36 PM
After run oil - for motors with Silicone Putty GMSchmidt Onroad Nitro Engine Zone 10 06-17-2007 03:19 PM
cleaning putty meoff R/C Items: Wanted to Buy 0 06-08-2005 07:04 PM
Force .26 crank shafts WheelNut R/C Items: Wanted to Buy 0 06-01-2005 10:19 AM
