Old 02-26-2007, 03:24 PM   #46
Trader Rating: 13 (93%+)
i made this ramp with my stock tz and the powerband seams so much smoother
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 02-28-2007, 05:37 PM   #47
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Originally Posted by stefan
Oh, so all the real fast engines like Murnan's or JP's are drilled for their personal amusement?
Sorry I didn't know that. I actually started modding engines at the same time as Uriah Murnan (we raced at the same track), so I guess I've been doing everything wrong all those years.
DAMN!
Here is some information from OSengines.
Info on the OS Speed motor: The Crank's exterior is specially coated to minimize friction, the crankshaft also features a large mixture passage "filled with silicone to increase crankcase pumping pressure".
Same goes for quite a few companies , not even modifiers who add in silicone to the cranks. I know ive seen them first hand and have removed the silicone to do my own job and there is no extra drilling to be seen. Some maybe drilled , but it doesnt have to be drilled to have more crankcase pumping pressure or find benefits from using the technique.
So yeah , one could lean to the fact that you might be.
Artificial-I is offline   Reply With Quote
Old 02-28-2007, 07:34 PM   #48
MRX4-R03's Avatar
When an engine is modified (as in JP, Murnan,etc) the crankshaft is drilled out (towards the clutch) to make it lighter. The whole needs to be closed to keep crankcase volume consitant. Here is where the silicone is used. It does build a ramp that might help with gas flow, but that is NOT the primary reason to put it in.
Well Stefan a ns12s3 crankshaft is the same as a JP FX t03 crankshaft same inner diameter and no the JP is not drilled out bigger towards the "clutch" so why does he put the flow ramp there.
If it doesn't do anything why did novarossi come out with a tunned version which the only difference is the flow ramp on the crank.
MRX4-R03 is offline   Reply With Quote
Old 02-28-2007, 07:37 PM   #49
MRX4-R03's Avatar
Wrong, only the modders that don't know what they are doing, do this!
so i guess the os speed tunned and novarossi and ect dont know what they are doing..
Old 02-28-2007, 09:42 PM   #50
German Muscle's Avatar
DAMN!
considering that the JP FX .21 engines are novarossi S821B crankshafts and come from the factory drilled forward with no filler. No JP does not drill crankshafts out.
thanks, drive through.
German Muscle is offline   Reply With Quote
Old 02-28-2007, 10:38 PM   #51
Some old photos of my engines modification
bennylee is offline   Reply With Quote
Old 02-28-2007, 10:43 PM   #52
Some more photos
Old 02-28-2007, 10:52 PM   #53
some more
Old 02-28-2007, 11:06 PM   #54
stefan's Avatar
Send a message via AIM to stefan
It's not drilled bigger, it's drilled BEHIND the silicone, where the regular crank is solid.
Hard to explain. Pull the silicone out of a JP crank and you know what I mean.
stefan is offline   Reply With Quote
Old 02-28-2007, 11:08 PM   #55
blee's Avatar
Some more photos:
blee is offline   Reply With Quote
Old 02-28-2007, 11:14 PM   #56
blee's Avatar
some more:
Old 03-01-2007, 12:16 AM   #57
MRX4-R03's Avatar
I know what you mean the same crankshaft from the novarossi is the same same as the JP he does not drill it further..
This what JP says:
EFRA Crankshaft The modified and lightened crankshaft is filled with the special red putty which is positionned to improve the gas passage. In order to reduce the friction and the wear, the crankshaft is HardBlack coated.
Old 03-01-2007, 01:31 AM   #58
gashuffer's Avatar
Trader Rating: 48 (100%+)
Damm those photos got me all excited.
T-Sal
gashuffer is offline   Reply With Quote
Old 03-08-2007, 05:54 AM   #59
richardsonracin's Avatar
Guys, I'm new to nitro. Are there any mods i can do to a ofna force .28? THANKS
richardsonracin is offline   Reply With Quote
Old 03-18-2007, 10:42 AM   #60
Moderator
mxwrench's Avatar
bennylee, thanks for taking the time to post all those pictures! You must be quite proud!!
I really feel for someone with a slow connection!!!
Nice work though...very shiny!!
BK
Brian Kinney
TLR Design Engineer
2016 Sponsors: Team Losi Racing, AKA Tires, Orion, Nitrotane, Horizon Hobbies, Fast RC Paint.
mxwrench is offline   Reply With Quote
Serpent Cleaning Gum/Putty German Muscle Nitro On-Road 10 05-19-2008 05:00 PM
Kyosho 777 WC New complete shock sets,Springs,Wheel shafts,Center shafts GMartinez R/C Items: For Sale/Trade 0 02-07-2008 07:36 PM
After run oil - for motors with Silicone Putty GMSchmidt Onroad Nitro Engine Zone 10 06-17-2007 03:19 PM
cleaning putty meoff R/C Items: Wanted to Buy 0 06-08-2005 07:04 PM
Force .26 crank shafts WheelNut R/C Items: Wanted to Buy 0 06-01-2005 10:19 AM
