Old 03-23-2008, 09:57 PM   #1291
Trader Rating: 13 (93%+)
had a pretty bad fuel leak around the base of the carb / front of the engine this weekend. fuel was also going onto the brakes of the car.
is the sign of a leaking front bearing? i have my carb sealed alla round the bottom and pinch bolt.
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 03-23-2008, 11:34 PM   #1292
Team Kamikaze's Avatar
Your HSN housing is probably not tight enough against the carburetor, causing it to leak, I have seen a lot of this happened, I suggest you crank it down!
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 03-24-2008, 06:29 AM   #1293
Trader Rating: 24 (100%+)
Originally Posted by RANDY SMOOTH View Post
will the lrp glow plugs work with the red dot, from what i was told the
lrp motor are picco base motors and plugs
anyone
RANDY SMOOTH is offline   Reply With Quote
Old 03-24-2008, 02:23 PM   #1294
stefan's Avatar
Send a message via AIM to stefan
anyone
Yes, they are a perfect fit. Unfortunately, the LRP plugs are not very good. The sometimes only last one tank.
I know a couple of LRP team drivers and they all use Sirio or Picco plugs....
stefan is offline   Reply With Quote
Old 03-24-2008, 02:36 PM   #1295
Sp Racer's Avatar
LRP plugs are not very good - that's almost good to hear, I thought I was the only one having problems with them!
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 03-24-2008, 04:51 PM   #1296
thanks guys
Old 03-24-2008, 04:53 PM   #1297
Hi Sam
The HSN housing is tight and does not move with force. Im using a mates spare block/ carb and bearings that have had less than 2 litres thru it so ill see how it goes. I t hink it was te front bearing leaking.
Old 03-24-2008, 06:48 PM   #1298
I would have to say that I am sure that the front bearing is not a issue with leaking. As long as the seal is in place or the shield is not bad you will have no issues with a leaking front bearing ever causing a tune issue. The front bearing can be bad and have a problem with tuning but speaking about the leaking. Think about all the .21 engines that are run on road. They use shields not seals. You can see daylight through the bearing if you look up. The seal from the front is caused by the tight tolerance from the crankshaft in the case as well as the rotation of the bearings and inner retainer. It is moving so fast that there are no leaks. I have seen a bad rear bearing cause needle problems though.And also check the carb for air leaks. This is a cause as well.
xspower is offline   Reply With Quote
Old 03-24-2008, 11:45 PM   #1299
Just as xspower just said, front bearings are more likely not to leak, check your fuel line, you might have a pinhole that you did not see, I saw your post in another thread that you have an issue regarding bubbles in your fuel line, well that could be your problem.
Old 03-24-2008, 11:51 PM   #1300
yeh ill suss it out and see what happens
when i had the engine in the rrr it was fine so yeh maybe it was pin hole leak in the fuel or something...
Old 03-25-2008, 05:43 AM   #1301
itchy b's Avatar
That's what you get for switching to the Dark Side!
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 03-25-2008, 07:50 AM   #1302
Maximo's Avatar
Picco carbs leak guys !!!!!!! Out of 10 Picco's your going to find 3 with a split carb body that will leak and not tune...... This has been an issue with Picco for years and years..... Nobody has been quick enough to catch it tho !!!!! The seam between the composite carb body and the metal end bell is prone to leaking..you need to seal this seem with JB weld or sealant of some kind......... every Picco any of us run has this seem sealed and all our Picco's tune as easy as any other motor............ If you dont seal this seam the motors can be difficult to tune, as the airleak acts much like a Phantom leak..it will only become apparent when the motors gets fully heat soaked,,,,,,you will chase a tune forever till you seal this seem !!
Maximo is offline   Reply With Quote
Old 03-25-2008, 09:09 AM   #1303
Maximo, I have run PICCO engines for 3 years in a row, from the first .12 with the purple head, to a Mega ZX -12, Mega DS II ZX .21 to PICCO P3, P7 off road engine and to the P9 R on-road engine and never encountered a carb leaking problem, you must have been doing something very wrong to create the leak, as msgsr said it did not leak on his RRR and only started to leak when he transfered his engine to his new car, that tells you that it got to be a problem somewhere else.
hello is offline   Reply With Quote
Old 03-25-2008, 10:30 AM   #1304
Maximo's Avatar
Trust me mate..I am doing nothing wrong LOL !!!!! You never know who you are dealing with on the internet, but I can assure you I am more then qualified to diagnose a leaky carb body !!! I have many customers running modified Picco's and we have had to seal the bodies of a pretty high number of Picco carbs.... The difference between sealed and un-sealed is dramatic to say the least...
Now its still winter where I live..but within the next 4 weeks I hopefully will be able to run some nitro...When I do I will make a video of what these Picco's run like before and after I seal the carb body... I think a few of you are going to be eating some Crow on this one !!!!
Old 03-25-2008, 10:34 AM   #1305
Any pics of where in particular and how you'd recommend sealing it?
luke81 is offline   Reply With Quote
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 09:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 05:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 11:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 09:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 01:49 PM
