Old 01-30-2008, 10:38 PM   #1126
Trader Rating: 13 (93%+)
Default modifying the sleeve picco red dot evo 3
I just picked up an evo 3 and noticed the sleeve is very standard. on my previous engines i used to dremel small tear drops on the sides of the ports and this would make small noticeable power.
has anyone modded there liner in this way and what sort of changes were experienced??
thanks
john
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 01-30-2008, 11:24 PM   #1127
rcrevolution's Avatar
Send a message via AIM to rcrevolution
doesnt matter if the sleeve is standard or radically different as long as its making that power
rcrevolution is offline   Reply With Quote
Old 01-31-2008, 12:41 AM   #1128
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
thanks
john
Try the IDM version. Modified and I am almost sure the piston and sleeve and hand fitted.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 01-31-2008, 05:47 AM   #1129
stefan's Avatar
Send a message via AIM to stefan
Originally Posted by RayJ View Post
I am curious as to the differences between the inards of these two engines. I'm wondering if any of you engine guru's have actually measured the diffrences between :
Crank timing on evo2 vs evo 3
(did they change closing and opening of crank duration)
40 ABDC to 60ATDC on both engines
Crank Bore diameter evo2 vs evo 3?
slightly under 7mm on both engines
port timing?
Exhaust 166 on both engines
Transfer 114 on both engines
A different cooling head doesn't really change engine performance, but does effect car handling.
That's right, but the changes from the EVO 2 to the EVO 3 are mostly in the selection of materials for piston, crank and rod, which makes a considerable difference in power and consitancy
stefan is offline   Reply With Quote
Old 01-31-2008, 05:49 AM   #1130
stefan's Avatar
That's correct. All the parts of the IDM modificato versions are hand selected. That includes the crank and the bearings as well.
The engines are assembled by Daniele.
Old 01-31-2008, 01:34 PM   #1131
Sp Racer's Avatar
thanks
john
Don't do it John!....just try some different pipes, when you get the right one you'll be amazed at the power
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 01-31-2008, 03:10 PM   #1132
Team Kamikaze's Avatar
PICCO 2607 pipe set
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 01-31-2008, 03:22 PM   #1133
We have a guy here using a solaroli tuned efra version to this engine and they found the best pipe to be the miekle (mugen efra 2501)..this pipe had the most improvement in power over the rev range.
they also tried the novarossi 2630 and picco 2607. the feedback from the 2607 was it had huge bottom end but ran out of legs rather quickly. it was used on a kyosho rrr using 17/23 55/60 gearing.
I will try the picco 2607 as we have one coming from kamikaze so ill see how it goes.
Old 02-01-2008, 12:42 AM   #1134
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
Michael
Believe me 2607 is the 1 you want..I have use nr2501 with the JLR too but is no where near the performance of the picco pipe, my exprience of the Mugen pipe is, its allow you to lean the bottom end without the sign of lean bog but engine runs hotter and top end tune is very touchie, sweet spot is narrow not as wide as 2607 also you need to play with the head shims to make the most out of it.
*Tourer**Futaba***SpeedPassion
*F1**4PX***TORO
*12th**4PX***TORO
*8th**4PX***OS Speed XZ-R
*10th**4PX***OS Speed XZ
tl2111 is offline   Reply With Quote
Old 02-01-2008, 08:08 AM   #1135
RayJ's Avatar
Interesting on the crank bore being unchanged. I slightly enlarged the crank bore on the first version of the JLR to 7.25mm and the engine gained some rev's and smoothed out the bottom end. It also didn't sacrifice in fuel mileage or bottom end. I'm surprised they kept the crank bore the same. I also had cut a recess into the back plate, and upped the transfer timing afew degrees and the motor revved like a beast. Of course none of these things are necessary since the motor is fast right out of the box.
RayJ is offline   Reply With Quote
Old 02-01-2008, 05:39 PM   #1136
The bore measurement on the crankshaft of the JL EVO 3 is 7.45mm,
while the crankshaft bore measurement of the JL2 is only 6.75mm,
that is a whopping .70mm difference.
Old 02-01-2008, 06:45 PM   #1137
stefan's Avatar
Show me!
Old 02-01-2008, 06:53 PM   #1138
tl2111's Avatar
Show me!
Sam is right!!
Evo3 has a IFMAR crank(no limit), while the Evo2 was using EFRA crank(below 7mm) I have both engine
*F1**4PX***TORO
*12th**4PX***TORO
Old 02-01-2008, 08:06 PM   #1139
Show me!
I suggest you buy a JL EVO 3, so you can measure the crankshaft's I.D./BORE and see the actual measurement yourself.
for short Show it to yourself!
Old 02-01-2008, 08:25 PM   #1140
Thanks! tl2111
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 09:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 05:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 11:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 09:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 01:49 PM
