JL Racing .12
Old 12-11-2007, 01:16 AM
  #1036
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
Is there a reason for it?
Drift_Buggy is offline
Old 12-11-2007, 03:17 AM
  #1037
Xr Turbo's Avatar
No idea but mines the same.
Xr Turbo is offline
Old 12-11-2007, 03:31 AM
  #1038
Mugenville's Avatar
Trader Rating: 25 (100%+)
The Evo3 is the same also,
Change the carby over today from the Mega Zx.12 and all seems fine, got it running and starts well, now to tune it properly on Sunday at Moorebank, so it seems it might have been a problem with the orginal carb, will try it on the mega just to make sure, if it is i'm one carb down now
Mugenville is offline
Old 12-11-2007, 08:13 AM
  #1039
Rawz's Avatar
Went to put together my new .12 Offroad Red Dot and I noticed that the cooling head doesn't sit flush with the engine. This is my 1st nitro engine in a while. Am I meant to tighten it down? As it seems very tight?
Look right into the gap. You see the cooling head is sitting in the sleeve. That's what really need to be cooled. Well, that and the head button, it's "inside" the cooling head.
So, that is the way it should be. Remember to tighten(SP?) the screws a minute at a time on each one, going in a cross pattern from one to the other. Did I explain it good?
Rawz is offline
Old 12-12-2007, 04:40 AM
  #1040
Xr Turbo's Avatar
Perfect
Xr Turbo is offline
Old 12-12-2007, 04:43 AM
  #1041
Xr Turbo's Avatar
Well mine is up and running again after the carby problem.
It's ashame i can not get there sunday Bloody Xmas parties
Xr Turbo is offline
Old 12-12-2007, 05:53 AM
  #1042
Mugenville's Avatar
Arh well there's always next year, i'd rather be at a Xmas do but i'm needed at the track for video duty, the XRC guy's have requested my services for the day also
Old 12-16-2007, 01:21 AM
  #1043
Ok, went to break in my Offroad Red Dot .12 and it was running 160F - 180F. Thought I would try leaning out the HSN and i couldn't get it to move. I did take off that part to move the nipple around so it wasn't hitting the air filter. Are the really, really tight from the factory?
Old 12-16-2007, 08:18 AM
  #1044
quietstorm76's Avatar
Yeah the HSN is tight from the factory. I have two and it's the same.
quietstorm76 is offline
Old 12-16-2007, 07:36 PM
  #1045
Team Kamikaze's Avatar
Put a drop of oil at the HSN, that will lube the o-ring and loosen up the HSN on it's housing.
Team Kamikaze is offline
Old 12-22-2007, 08:03 PM
  #1046
hooked_on's Avatar
Originally Posted by LogiK View Post
Put the HSN back and try richening the LSN. They need a rich low.
Thank you... i tried it today and it is alot better now. I was really enjoying running around the track until the rain started to come down
hooked_on is offline
Old 12-24-2007, 05:56 AM
  #1047
LogiK's Avatar
Trader Rating: 11 (92%+)
No worries mate, gonna start running my Evo 3. in on Boxing Day
LogiK is offline
Old 12-25-2007, 08:17 AM
  #1048
Default JL3 Collet
Seasons greetings and Merry Xmas to all.
Can the guys running the JL3 in NT1 tell me if the collet that comes with the engines works on the NT1 or would I have to get the Picco collet from Xray?
jelayne is offline
Old 12-25-2007, 01:45 PM
  #1049
kaotickc's Avatar
Trader Rating: 43 (100%+)
One with the engine works.
kaotickc is offline
Old 12-25-2007, 04:07 PM
  #1050
Undies's Avatar
Hi
I was under the impression that the JLR Collet would need to be shorten'd to work on the NT1?
Undies
Undies is offline
