Old 12-04-2007, 04:33 AM   #1006
Xr Turbo's Avatar
Originally Posted by Drift_Buggy View Post
My local hobby shop only carrys O.S & Nova Rossi (well most hobby stores in Australia do). Would a OS P7 be the next best thing?
It's funny you ask that a couple of guys at moorebank onroad are using Os plug and they work for them
Myself i haven't tried them in a JLR.
Retired
Xr Turbo is offline   Reply With Quote
Old 12-04-2007, 12:35 PM   #1007
Questions??
What filter / Air Cleaner setup do you guys use on the JLR / JLR3?
Extrmbt is offline   Reply With Quote
Old 12-04-2007, 12:48 PM   #1008
Team Kamikaze's Avatar
Just use a good quality Foam filter soaked with air filter foam oil.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 12-04-2007, 02:29 PM   #1009
kaotickc's Avatar
Trader Rating: 43 (100%+)
Originally Posted by Mugenville View Post
After running this engine on the weekend found it hard to tune and gets very hot, have blister to prove, (had so good tuners look at it and still no go) on Sunday wouldn't start at all, replaced it with my ZX.12 and everything was fine, so no air leaks in the fuel system, also took the backing plate of for a look and found the rod has play in it on the pin to the crank, a little depressed at the moment as my mates JLR's kick ass not sure if it's air leaks or what but the carby is sealed around the neck with RTV
I have the same problem concerning the rod, and also seems to have a leaky carb. My motor never got over 230* at its hottest, and still has play in the con-rod/crank the first day out. What could be the cause ? ?
kaotickc is offline   Reply With Quote
Old 12-04-2007, 02:29 PM   #1010
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
you will find OS plug tapper is pretty close to picco with good seal also Sirio plug as well, but never use Nova plug in Picco based engine just totally wrong tapper
*Tourer**Futaba***SpeedPassion
*F1**4PX***TORO
*12th**4PX***TORO
*8th**4PX***OS Speed XZ-R
*10th**4PX***OS Speed XZ
tl2111 is offline   Reply With Quote
Old 12-04-2007, 05:18 PM   #1011
Read this http://www.rctech.net/forum/showpost...&postcount=525
And regarding the crank pin/con-rod it is normal to have a small amount of play, without that play it will almost be imposible to remove or install the piston/rod assembly into the crankshaft while it is inside the crankcase.
Old 12-04-2007, 07:57 PM   #1012
Default JL3 Fuel
Which fuel do you all recommend for the best performance, I only have 3 choices:
Maxy 20%
Byron 20%
O'Donnel 25%
jelayne is offline   Reply With Quote
Old 12-04-2007, 08:04 PM   #1013
Maxy 20%
Byron 20%
O'Donnel 25%
Maxy 20% is good.
Old 12-04-2007, 08:35 PM   #1014
jeff1's Avatar
I have GC air filter and the instructions says to not wash and re-use the foam. I borrowed a novarossi 3sct instruction and there says to wash the air filter with a mix of petrol (I guess it means gasoline) + 10% of oil.. I wonder what way is correct?
And if I follow GC instruction after a period of time the foam will be without oil because of normal use.. I'm confused 2 ~ 3 hours it recommended to replace the ganz air filter
Sam some time ago you said that alcohol is the best product to wash the engine. Can I use it direct in the carb? I worry about the composite part and rubber parts (o-rings etc.) the seal of rear bearing too.. can these parts be washed with alcohol?
jeff1 is offline   Reply With Quote
Old 12-04-2007, 08:42 PM   #1015
Yes, but use Methyl alchohol or at least Denatured alchohol, regarding the Foam air filter, just replace them after 1 hour of run, they are so cheap now a days. but if you want to wash them you can use dish washing soap, just let it dry completely before applying foam filter oil.
Old 12-05-2007, 01:04 AM   #1016
Drift_Buggy's Avatar
Cool, thanks for letting me know but while on the subject, what about RB?
Drift_Buggy is offline   Reply With Quote
Old 12-05-2007, 09:42 AM   #1017
RB plugs have the same taper as the Novarossi plugs.
Just remember that Picco plugs works best with Picco engine, Sirio plug have the same taper but it won't seat flush on the combustion chamber resulting into leaks, the heat range of the OS plug is different from the Picco plug which sometimes cause tuning issues.
Old 12-05-2007, 07:58 PM   #1018
aussies1129's Avatar
Trader Rating: 74 (100%+)
anyone got any websites to purchase a picco 2607 pipe for the JLR evo 3
also is there much difference between the JLR evo 3 and the picco P1-R evo turbo 5+2 slide modified engine?
THANKS
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 12-06-2007, 01:21 AM   #1019
THANKS
Where did you buy the JLR EVO 3 engine? they should have the PICCO 2607 pipe in stock.
Old 12-06-2007, 04:17 AM   #1020
Xr Turbo's Avatar
Not everywhere that stock the engine stock the 2607 pipe.
I bought mine from Hong Kong and they didn't stock pipes.
But i know where i will be buying my next one from.
Retired
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 09:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 05:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 11:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 09:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 01:49 PM
