Old 12-02-2007, 09:28 PM   #991
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
Originally Posted by jeff1 View Post
How do I ensure that my engine has no air leaks? Whats the method? Sometime I find it hard to tune.. is not steady
there are marks on the rear cover i think the conrod is touching it.. why of that? its normal?
thanks
The marks on the back plate are normal
For the air leak make sure you press the carburator in really tight before you tight the screw
Walter Diaz
wad is offline   Reply With Quote
Old 12-02-2007, 09:34 PM   #992
kreamUNO's Avatar
Originally Posted by Team Kamikaze View Post
Your POPs? What's his Name?
carlo from ehobbyhouse
Mugen MTX-4R-NINJA MR12TUNED-NINJA FLS || Kyosho v-one RRR evo.2-SirioXXX-Sirio 2611
Kyosho Inferno WC-JAMMIN' JP3 || Kyosho M3-Sirio CL7R-Novarossi
XRAY T3'-Novak 13.5/tekinR1 || Serpent S120-RP x11 3.5
Tamiya IFS-Novak17.5/SPX || Tamiya TT-01-LRP x11 17.5
kreamUNO is offline   Reply With Quote
Old 12-02-2007, 09:38 PM   #993
jeff1's Avatar
I pressed the carb against the engine block while i was tightening all the way down
jeff1 is offline   Reply With Quote
Old 12-02-2007, 10:56 PM   #994
Mugenville's Avatar
Trader Rating: 25 (100%+)
After running this engine on the weekend found it hard to tune and gets very hot, have blister to prove, (had so good tuners look at it and still no go) on Sunday wouldn't start at all, replaced it with my ZX.12 and everything was fine, so no air leaks in the fuel system, also took the backing plate of for a look and found the rod has play in it on the pin to the crank, a little depressed at the moment as my mates JLR's kick ass not sure if it's air leaks or what but the carby is sealed around the neck with RTV
Mugenville is offline   Reply With Quote
Old 12-02-2007, 11:25 PM   #995
nitrodude's Avatar
Engine likes a rather ricj bottom end, set it so that after going WOT it will instantly come back to a low idle, then just tune the top end. I runed my Evo3 JL all weekend and the engines has BALLS!!
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 12-03-2007, 05:51 AM   #996
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
have ran JLR over 6 months now, have to said this engine is quite easy to tune if you can keep in mind that need to run very rich bottom end and use the right pipe then you should be fine I have tried 4 different pipe on this engine only Picco 2607 pipe can show the potential on this engine. its day and night in performance.
if you race in Mbank next club meet then come and see me I'll try to help you out.
*Tourer**Futaba***SpeedPassion
*F1**4PX***TORO
*12th**4PX***TORO
*8th**4PX***OS Speed XZ-R
*10th**4PX***OS Speed XZ
tl2111 is offline   Reply With Quote
Old 12-03-2007, 10:13 AM   #997
Maximo's Avatar
the seem on the carb body between the composite and aluminum can leak on the Picco's......some JB weld, or 1211 will seal it right up..... sometimes the carbs wont leak till they get heat soaked.....
Maximo is offline   Reply With Quote
Old 12-03-2007, 04:34 PM   #998
Mugenville's Avatar
Thanks will be there in 2 weeks with ItchyB (Joe), was running with the 2607 pipe, did you run on the weekend if so was yours the purplily coloured body if it was that was one quick SOB. Are you T Lee
Maximo the carby was sealed with RTV sealant, was running on saturday but poorly and then saturday arvo it sort of died and wouldn't start, changed plug Sunday morning and it just wouldn't start at all, was over the moon to be running this engine at the birthday bash and having a good showing but that went out the window real quick, but i'll let tl2111 have a look and see what can be done, also have another new one as a backup so might have to run that in now and see how that goes
Old 12-03-2007, 06:04 PM   #999
tl2111's Avatar
Yeap that is my car, have to say tunning is spot on with picco pipe on the weekend and that is only the JL not JL3, cant wait to break in my JL3, temp was on 115-125 depend the time of the day.
*F1**4PX***TORO
*12th**4PX***TORO
Old 12-03-2007, 06:07 PM   #1000
nitrodude's Avatar
If you like your JL, you will love your JL Evo 3. Its even faster, and it stillgets good mileage.
Steven Muller
Ronin Speed Parts
Old 12-03-2007, 07:31 PM   #1001
Mugenville's Avatar
I'll come over and talk to you in 2weeks if your there, might change carby's from the new one and see how that goes, seeing these first hand yours, itchyB's and XR Turbo's i'm not disappointed i got them, just fustrated
Old 12-03-2007, 11:10 PM   #1002
Xr Turbo's Avatar
Well you may not be seeing mine for a little while the metal sleeve on the base of the carby has come
away from the plastic so the carby parted company with engine. Im a little confused as to how it happened
cause i didn't hit anything and all my end points are correct.
Retired
Xr Turbo is offline   Reply With Quote
Old 12-04-2007, 01:45 AM   #1003
Drift_Buggy's Avatar
I just bought a Ofna .12 Picco Red Dot Offroad and will be using 25% fuel. Can someone recommend a glow plug to start with? I live in Australia and it currently is Summer.
Drift_Buggy is offline   Reply With Quote
Old 12-04-2007, 02:35 AM   #1004
Xr Turbo's Avatar
I'd be using a 6 but make sure you use a picco plug i found other brands that i've tried leak.
Retired
Old 12-04-2007, 04:02 AM   #1005
My local hobby shop only carrys O.S & Nova Rossi (well most hobby stores in Australia do). Would a OS P7 be the next best thing?
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 09:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 05:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 11:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 09:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 01:49 PM
