Old 08-24-2007, 05:00 PM   #676
Team Kamikaze's Avatar
Originally Posted by qcrc View Post
Glad that I could help. Hope that you like the motor. I love mine!
I'm sure anybody who tried the JL Red Dot motor will love it.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 08-25-2007, 09:03 AM   #677
Send a message via AIM to NitroNubee
Originally Posted by Osiris 75 View Post
I think you still may have had some fuel in the engine, that will cause it to lock up!
Osiris, what is the best way to remove the fuel from the engine? Alright, I put the engine back in and buttoned everything up. Went to start it and could not get it going. I put a new plug in and no dice. It appears that the fuel is not being drawn from the tank. It will crank while on the box but will not get going. Sigh. It is almost beyond my knowledge now. I may have to take it to my LHS for some help. Any more suggestions on this topic?
NitroNubee is offline   Reply With Quote
Old 08-25-2007, 09:24 AM   #678
Try this: plug the exhaust stinger for 2-3 seconds while starting it, this way the pressure from the exhaust will force the fuel to the carburetor.
Old 08-25-2007, 03:30 PM   #679
Osiris 75's Avatar
Trader Rating: 17 (100%+)
And replace your fuel tubing.
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 08-25-2007, 08:31 PM   #680
TeamCarnage's Avatar
Trader Rating: 23 (100%+)
Anybody have carb problems? I had to replace mine with another carb to get through my race day. It ran great for the end of break-in. It wouldn't start today and when it finally did it wouldn't stay running. I suspect an oring problem. It did run great after the carb swap!! Fastest stock engine I've owned. Great linear power in my NT1 with 30% Byrons, 2067 pipe.
TeamCarnage is offline   Reply With Quote
Old 08-25-2007, 08:48 PM   #681
If it is an O Ring problem in the carb, then give OFNA a call, I guaranty it will be taken care off right away.
Sam
Old 08-26-2007, 07:14 AM   #682
You might have been right on! I found a small pinch in my line from the pipe. Then I put in a fuel filter (not sure that did it). BUT, I charged everything over night and it fired on the first try! Now I need some new shoes to get all that power working for me! Any suggestions for tires on concrete?
Sam: When I tried that trick, it would reach the carb but drain back into the tank. All's well again! If I can get some traction, I will let it eat!
Old 08-26-2007, 10:58 PM   #683
gearhead13's Avatar
My first raceday with the red dot. Came in third in the A.
Engine ran good, plenty of zip coming out of corners, which is very good because of our small track.
The only car that passed me on the straight was the same kind of car with a wasp. My main setting or my shift point must be off.
no leaking problems
Nubee:
What kind of vehicle is it in?
I run a Serpent 710 and use 35 shore Jaco foams all around
Serpent
Xray T2
OFNA/Picco red dot
Picco 2607 pipe
Dynamite race 20%
gearhead13 is offline   Reply With Quote
Old 08-27-2007, 02:54 AM   #684
bxpitbull's Avatar
What is the optimal temp on this engine? I leaned it and was getting temps at or around 235.....power on tap and I know I have room to reach. She was a bit gurgly on the low end, but when she hit mid-track and stretched her legs, she was screaming. I want more scream on the bottom and understand this isnt the snappiest engine from low to mid....what can I to make it punch a little harder on the bottom so I wont have to stretch her all the way into the turns??? Running O'donnel 30, Jaco 35 all around.
R40-Pondering a new Red Dot
Hara Pro4-GTB/3.5/Max Amps-yea.
Pondering moving on to Xray-have to go with a winner. If you cant beat em, join em!
I gear to run and win, not to THERMAL!
bxpitbull is offline   Reply With Quote
Old 08-27-2007, 04:53 AM   #685
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
bxpitbull, setup your clutch to get more bottom. this engine has heaps of bottom end and generally you would need to gear up for it.
*Tourer**Futaba***SpeedPassion
*F1**4PX***TORO
*12th**4PX***TORO
*8th**4PX***OS Speed XZ-R
*10th**4PX***OS Speed XZ
tl2111 is offline   Reply With Quote
Old 08-27-2007, 09:38 PM   #686
What pipe are you running it with?
Old 08-28-2007, 01:26 AM   #687
bxpitbull's Avatar
I am running the THS 1015T. One of my guys is running this pipe with his Novarossi **I dont know what engine it is ** and his car is a rocket. I set-up the clutch according to the default settings in the manual. I'll figure out what I should do with the clutch this before this weekend. I know when she opens up from mid to top, she is a bat out of hell.
Old 08-28-2007, 08:54 AM   #688
Osiris 75's Avatar
You absolutely have the wrong pipe for the engine. Any other pipe than the Picco 2607 will choke the engine..
Chris Kemper
Old 08-29-2007, 07:47 AM   #689
bxpitbull's Avatar
Word? Is this the general consensus? Is this pretty much the same pipe everyone here is running? If by a "show of hands" this is the case, I will snatch this thing out of my car so fast, it'll make your head spin. I have time anyways, I wrecked my car while praticing. Will more than likely buy Fastharry's NIB Hara R40. But in the meantime in between time, further comments or suggestions on the pipe...thanks
Old 08-29-2007, 09:41 AM   #690
tl2111's Avatar
the 2607 pipe is best for this picco base engine or if you can the mugen NR2501
also good(more top end)
*F1**4PX***TORO
*12th**4PX***TORO
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 09:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 05:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 11:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 09:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 01:49 PM
