Old 06-11-2007, 04:10 PM   #466
GK
Suspended
Sam and Nigel - thank you for providing o-rings, plugs and some good advice for my red dot! I ended up using it in my main at cap. classic after my other motor stopped running at 400 degrees for some reason...
Nice meeting you both!
George
GK is offline   Reply With Quote
Old 06-12-2007, 01:19 AM   #467
Team Kamikaze's Avatar
Originally Posted by Dreddlox View Post
My brother and I both ran the JL this weekend at the Capital Classic down in Maryland, and the engine was awesome. Special thanks to Sam and Nigel from Team Kamakaze. Sam twisted the screws on the engines for us and had them tuned right. The power is great all around and the run time is incredible. The motor ran with all the other motors, and ran away from some. You'll definately like it. The reason for the leak was from us over tightening the collar on the carb. Changed it and all is well.
Nice to meet you and your brother and I'm glad you liked the JL's
Originally Posted by lroy View Post
HI,
Is the jl red dot shimmed for 30% or do I need to add 1 shim
Using 30% tornado and skyline vr+ pipe
Lee
Add a .1mm shim if using 30% Tornado fuel.
George
Nice to meet you too George, I know you will be happy with the JL promise.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 06-12-2007, 07:22 AM   #468
Gael L's Avatar
Yeah the JL motor ran fantastic all weekend!!! Very durable and definatley keeps up with all the modded motors out there.
Gael L is offline   Reply With Quote
Old 06-12-2007, 08:41 AM   #469
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Guess I better add a shim to mine. Will that take away some performance on the engine?
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 06-12-2007, 08:55 AM   #470
RayJ's Avatar
Default Adding shim
Adding a shim to the motor really should not effect performance much. You may lose just a squeek at the low end, but you won't detonate(pre-ignition) the motor on the top end. You will actually gain top end with a properly shimmed motor. I run 30% Tornado and needed to add a .1mm shim. If your getting a sandblasted or pitted head button and/or piston ....your motor is detonating. This is very bad and puts a huge stress on the piston, wrist pin, connecting rod and crankpin. Adding a head shim will generally stop detonation. Another thing to consider is that detonation is much more prevalent on tracks where the motor is much higher in the rev range. Long straight aways( 180 to 230 feet) Here is where detonation can be a problem. If your using a Mega #7 cold plug(picco plug). I would probably add a shim.
RayJ is offline   Reply With Quote
Old 06-12-2007, 09:07 AM   #471
rcrevolution's Avatar
Send a message via AIM to rcrevolution
i run byrons 30% and i didn't need to add a shim
rcrevolution is offline   Reply With Quote
Old 06-12-2007, 04:53 PM   #472
Default JL POWER
I just want to say I ran the JL at the Capital Classic, and let me tell you I will only run JL Red Dots. The motor is sick in the infield.
The Rookie is offline   Reply With Quote
Old 06-12-2007, 05:08 PM   #473
Put 5 tanks through mine so far with break-in settings and am very impressed so far! No leaks either! Couple of more tanks should do it.......
Curious, what are you guys using for starter boxes? My mill is in a CRT .5 and I bought the Ofna Mini starter box which is having a tough time turning over the engine. Tried heating the head with a heat gun and that still didn't work. Even removed the glow plug to see if my box would turn it and that didn't do it either......HELP!
morati is offline   Reply With Quote
Old 06-12-2007, 05:53 PM   #474
It appears ofna 2 pipes with the #51900. One says .12R also. Which ones are you guys using.
CHUCKMANDO is offline   Reply With Quote
Old 06-12-2007, 06:40 PM   #475
Originally Posted by The Rookie
I would like to say thanks to Sam and Nigel for your help at the Capital Classic.
Thanks alot
Steve Green
Hey bump up king you are most welcome, congratulations you did very good with your JL.
Old 06-12-2007, 06:42 PM   #476
Make sure the rubber wheel is lined up exactly with the flywheel of the engine.
Old 06-12-2007, 07:39 PM   #477
Q-B0R0 B0MBER's Avatar
J.L.RED DOT IZ DA SHIZNIT........................................... ........
Q-B0R0 B0MBER is offline   Reply With Quote
Old 06-12-2007, 09:41 PM   #478
Samuel to the rescue again! This is the second time you have helped me! Many Thanks as this was the problem......It wasn't off by alot (maybe 1/16") but enough to cause the rubber wheel to slip on the flywheel. I thought the motor in the starter was stalling! Beginner mistake, by a Beginner. My apologies to everyone for taking up space in this thread!!!
Old 06-13-2007, 07:15 PM   #479
JL's are Coming
Old 06-14-2007, 06:58 PM   #480
Default Important Message
To everybody who pre-ordered, I will automatically ship the JL's as soon and as quickly as possible
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 09:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 05:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 11:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 09:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 01:49 PM
