Old 04-14-2007, 06:41 PM   #271
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Unhappy
Bad weather spoils a good plan weekend.
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 04-14-2007, 07:30 PM   #272
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Indeed.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 04-15-2007, 07:36 PM   #273
Send a message via MSN to wiggindude
Default Club race verdict.
Today was the first outing with my Red Dot. The track was not in the best conditions. We had water seeping up thru the cracks when the track heated up.. so it was loose and you had to dodge the water in places.. it wasnt that bad.. but still obsticales.
Anyway.. First impressions.. Freaking awsome! I ran it a bit hot on the second race.. it got to about 260 and the plug was loose... I tightened the plug and fired it back up and all was good. I had to richen the motor about 12 hours! I am thinking that I might need the 7 plug instead of the 6.
I need to adjust the clutch.. it was switching to early! I had to install the tallest gears in my RRR EVO as well. 23/17 55/60. This is enough motor that is for sure. I am going to get a few more just in case....
My 2 cents. I am sold. No more 400.00 motors for me for a while...
Right now i am running the 6 plug and 25 rocket science. I ended up after 10 min main about 230-235 temp but.. i had issues with a wheel nut coming loose and the battery came loose due to the ride height about 2 mm too low... I still managed to get some 18 second laps.. wow.
wiggindude is offline   Reply With Quote
Old 04-15-2007, 08:14 PM   #274
Thumbs up
Good to hear great feedback on the motor also I was told by Jeffery Lin(Ofna Pro Driver) don't worry about temps motor runs pretty hot he told me to listen to engine sound and watch how it smoke.
Old 04-15-2007, 08:37 PM   #275
C Verano's Avatar
Glad to hear the motor ran well for you. As far as temps go, when we tune Jeffrey's motor for a race we do not use a temp gun. We just listen for a steady idle when he brings it in and look for a good stream of smoke.
RC Target, Capricorn RC, Matrix Tires, KO PROPO America, PowerMaster Fuel, Absolute Hobbyz, Bellybutton Paint
C Verano is offline   Reply With Quote
Old 04-15-2007, 09:17 PM   #276
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Hay a tip for you guys who are in a pinch and need a exhaust gasket. I took a standard gasket and wrapped plumbers tape aka threaded teflon tape around the gasket a few times. Slapped on my header and it was a perfect tight fit.
Artificial-I is offline   Reply With Quote
Old 04-15-2007, 09:23 PM   #277
rcrevolution's Avatar
Send a message via AIM to rcrevolution
i just used the gasket that came with the Skyline pipe, fits perfectly...
rcrevolution is offline   Reply With Quote
Old 04-15-2007, 09:24 PM   #278
Team Kamikaze's Avatar
Sean,
I'm looking forward to hear from you soon, glad you like the JL, as I told you, this motor ain't no joke.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 04-15-2007, 09:25 PM   #279
Hey guys, I'm gonna be running 30% nitro with my new Red Dot. How much should all the shims add up to for head clearance? Thanks.
pelico is offline   Reply With Quote
Old 04-15-2007, 09:27 PM   #280
Moderator
Itll fit over it for sure , but it allows it to wiggle around too much for my tastes.
Old 04-15-2007, 09:28 PM   #281
If you are running at almost sea level, then just add another .1mm shim.
Old 04-16-2007, 11:23 AM   #282
Anyone notice that this engine has no Mid end needle adjustment? I did
Old 04-16-2007, 01:42 PM   #283
jeff1's Avatar
TURBO COLD GLOW-PLUGS
P5TC hot filament
P6TC medium filament
P7TC cold filament
TURBO HOT GLOW-PLUGS
P5TH hot filament
P6TH medium filament
P7TH cold filament
What plug is recommended? And what's the difference between Cold Glow-Plug with hot filament and Hot Plug with and Hot filament? Sounds strange for me.
Does these seals work good with Picco exhaust system?
http://www.serpent.com/product/202148/images/
jeff1 is offline   Reply With Quote
Old 04-16-2007, 03:46 PM   #284
afm
afm's Avatar
P5TC hot filament
P7TC cold filament
P5TH hot filament
P7TH cold filament
cold glow plugs are to be used when ambient humidity is below 70%
hot glow plugs are to be used with 70% or more air humidity
the number you'll use i.e 6 or 7 in any format, depends on your nitro % and air temp. colder temps calls for hotter filament and vice versa. higher nitro content colder filament
afm
afm is offline   Reply With Quote
Old 04-16-2007, 05:21 PM   #285
Yea I notice that when I first got the motor.
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 09:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 05:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 11:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 09:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 01:49 PM
