Old 04-21-2009, 11:04 AM   #1981
gentleman81's Avatar
Originally Posted by JetMD View Post
While your buying those gaskets Craig, get that exhaust hanger piece so you can replace it. And maybe an allen driver to replace that allen key you twisted up.
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 04-22-2009, 05:13 PM   #1982
Team Kamikaze's Avatar
Originally Posted by majk View Post
Hello Kamikaze, do you know when the new jlr evo4 will be available? couldn't wait.
Don't have the EVO 4's yet, but the PICCO 2651 pipe set is in stock!
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 04-22-2009, 07:34 PM   #1983
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Hey Sam... Are you especting a JL version of the EVO 4? or an IDM or Picco (blue head)???
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 04-22-2009, 07:45 PM   #1984
We are waiting for OFNA to bring them in, so the price will be very affordable, if not it will be as expensive as it is now, the reason behind it is that OFNA brings it in on large quantities, that is why they were able to sell it at a very low price, so expect them to be available in a month or so.
Old 04-24-2009, 10:19 PM   #1985
Default Engine Shaft
Guys is it normal to have small in and out play on the shaft?
jelayne is offline   Reply With Quote
Old 04-25-2009, 12:02 AM   #1986
Yes, it is what we call bearing endplay and as long as it is no more than half a millimeter play.
Old 04-25-2009, 11:23 AM   #1987
thanks Sam,
I am having an issue with my engine, it is constantly loosing tune, it is very erratic. The engine seems to be running rich and unable to get up to temp and unable to get to 2nd Gear. When I lean it out it get up t temp and gear changes but when I come around again to the straight away it dies again and when the temp is check is is at 150F.
Today I tried it again with some Picco owners and it did not start until the HSN was nearly fully out but in pulling the trigger and realeasing it would cut off. Also it would not keep idle.
The sleeve, liner and con rod looks great, some of the guys recommended changing the bearings. Could this be the issue??
Old 04-25-2009, 11:43 AM   #1988
GREGORY!'s Avatar
thanks Sam,
with the engine on tha car try to move the crank up and down.if the play is a lot change the bearings.also check the rod.something else.try to seal the carb in place the plastic contact the aluminium.the picco carbs tend to leak in this place after a while.
also try some other fuel.
if the engine don't idle try to puss the crank down from the pinions,if the engine idle for more then ,you probably need bearings.
and last check the orings.
GREGORY! is offline   Reply With Quote
Old 04-25-2009, 11:45 AM   #1989
thanks Sam,
What glow plug are you using? did you touch the head shims? what brand fuel and nitro percentage?
Old 04-25-2009, 12:31 PM   #1990
Riketsu's Avatar
thanks Sam,
Is your exhaust in good condition? I once was trying to tune a Picco on a friends car. And it would just not tune. No matter how lean I would make the HSN, it would just not lean out. He changed the pipe and problem solved.
For you, I'd suggest you carefully take apart the carburator and all its needles and put them back in factory condition. Change the glow plug and the exhaust gasket. If someone at the track has a spare pipe set, you can also try that. And start from there.
Old 04-26-2009, 01:52 AM   #1991
musti72's Avatar
Tried my red dot yesterday... With Picco P6TH plug...
It had problems with its picco 2607 pipe on its last race, so I put skyline pipe with mugen header on it. After adjusting the needles, it became a monster again. There was a Ninja t-01 on the track and mine was a bit faster than it on the straight, but it dominated the infield with tallest first gear ratio on my nt1 It easily ripped the tires even with little more than a half throttle out of the corners. But it was a little sensitive on the needles...
Looking forward to test it again with some mods
Mustafa Alp
http://www.aytemizhobi.com
Turkish shop for: Serpent, Xceed, Sweep Racing, MyLaps
musti72 is offline   Reply With Quote
Old 04-26-2009, 02:59 PM   #1992
bluef250's Avatar
after breaking in my engine and race tuning i have noticed excessive fuel in the carb throat is this normal? this engine SCREAMS so far it is better than the tz 5 port i previously ran.
bluef250 is offline   Reply With Quote
Old 04-26-2009, 03:04 PM   #1993
wingracer's Avatar
Trader Rating: 24 (100%+)
To the guy with the tuning problem, try some fresh fuel. Bad fuel will cause all the problems you describe.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 04-27-2009, 06:24 AM   #1994
I am using No.6 Picco plug, opened 2 new ones same problem. Yep I removed a shim to allow for the 25% as directed on the forum but I can recheck the clearance.
Running brand new gallon of 25% Maxy, well I hope it is new.
Old 04-27-2009, 06:33 AM   #1995
I saw the fuel post late as I wish I would have tried it at the track yesterday.
My day was wasted at the track fighting to get a tune, other JL3 drivers tried and still could not find a solution, we changed the fuel tube, fuel tank, O rings on the engine.
We were able to get it to run for 10 minutes but the acceleration was the slowest ever on the track but when it got after the slow build up on the straight away it would then shoot off, but coming out of corners it was a snail. Even through a tight chicane I would hold full throttle and go through with ease, it even felt as it it would cut off.
Forgot to mention I am running with a Skyline pipe, I would try the 2607 on my next attempt.
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 09:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 05:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 11:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 09:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 01:49 PM
