Old 04-20-2009, 06:44 PM   #1966
gentleman81's Avatar
WHAT IN THE HE** ARE YOU TALKING ABOUT? Apu from the Simpsons talks better than you.
you sound like that blond miss USA contestant trying to answer a question...
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 04-20-2009, 06:55 PM   #1967
Team Kamikaze's Avatar
Originally Posted by gentleman81 View Post
jl red dot 2, and 2607
the gasket between the pipe and motor are fighting each other??? the gasket is pushing hard against the pipe, to the point where it is very hard to get the dang thing on, especailly with one exhaust spring whole in the manifold. i had one good bump on the wall ans my gasket was toast, didnt bend the pipe tho. any better way to fit. its almost like the outside diameter of the gasket is too big around? help
Are you using the correct seal/gasket? it should be part #51998, the 51998 gasket fits perfect.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 04-20-2009, 07:01 PM   #1968
the little od looking gasket that just looks like a piece of hose, with no rim? that is what i got?
Old 04-20-2009, 07:15 PM   #1969
That gasket (51997) is only good for any Nova Rossi based pipe (like the skyline pipe) to JL engine, for the JL engine to Picco 2607 you need #51998
Old 04-20-2009, 07:18 PM   #1970
how many u have
Old 04-20-2009, 07:55 PM   #1971
how many u have
I have exactly 368 pieces, how many do you need?
Old 04-20-2009, 08:04 PM   #1972
holly molly! 3-5, should last me all season. let me get another order together and let u know! thanks
Old 04-20-2009, 09:03 PM   #1973
Trader Rating: 21 (100%+)
I hate to tell you this but you will probley have to replace that gasket every week you race. Last year I considered myself lucky to make it the whole day and it was still good to use for part of the next week.
VA_Racer is offline   Reply With Quote
Old 04-20-2009, 09:10 PM   #1974
JetMD's Avatar
If you're destroying those gaskets, you should play with your manifold-to-engine fit. Were you using 2 exhaust springs to hold the manifold on? Try one.
Also, play with the exhaust hanger on the car. See which side is falling apart, loosen the hanger, then try to position the pipe away from that side, then tighten down the hanger.
That should help make them last a little longer.
www.vorra.org
MINO Racing
JetMD is offline   Reply With Quote
Old 04-20-2009, 10:41 PM   #1975
well it seems like i am using the wrong one, but i think my brand new one had one in it. i will check
Old 04-20-2009, 10:45 PM   #1976
u know i tried to adjust the pipe but check this. my exhaust hanger mount is dead locked up, i bent an allen key into a twizler trying to get it off. i was flexing the upper deck?! the top phillips screw, not the set screw. i can adjust the pipe away from the pulley, and thats it. to really get it right i will have to bend the hanger, i must have banged the pipe last year and torqued it GOOD. i would have to drill it out.
the picco manifold only has space for one spring, wish it had 2
Old 04-20-2009, 11:06 PM   #1977
It is the same gasket for the manifold to pipe, so if you have a pipe set then you should have 2.
Old 04-21-2009, 07:49 AM   #1978
rankev11's Avatar
Craig, like Gene said, I would plan on one per race. That is if you plan on hitting any boards all day. This pipe manifold makes the most power for our track but it sticks out so far a little tap of the wall tears up that gasket. The Nova engine gaskets have a groove cut in them that sits in the engine which helps keep it in place but Piccos don't. I think that is why they get damaged so easily. So, buy a bunch of gaskets so I can borrow some when I need them!!! Oh yeah, I drilled an extra set of holes in my manifold. There isn't much meat but if you are very careful you can do it.
2010 VORRA Vice President
MUGEN MRX4X/ NINJA POWERED
MUGEN MTX4R/ Murnan Plus 12-3sct
Corally RDX Phi/Tekin RS 10.5
rankev11 is offline   Reply With Quote
Old 04-21-2009, 07:53 AM   #1979
JetMD's Avatar
While your buying those gaskets Craig, get that exhaust hanger piece so you can replace it. And maybe an allen driver to replace that allen key you twisted up.
www.vorra.org
MINO Racing
Old 04-21-2009, 11:01 AM   #1980
well i will be getting a bunch so let me know if you want some, because i dont have much else to order. can i bring you a header and u drill it for me? maybe rick can do it at the machine shop
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 09:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 05:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 11:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 09:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 01:49 PM
