Old 10-12-2008, 05:42 AM   #1771
keavze's Avatar
Originally Posted by aussies1129 View Post
HI just a question for a mate at my track who has been blowing plugs on every run out he is using the JLR3 and using P5 plugs in warm conditions and the wire element dose not last at all he has had the piston/liner and rod out and cleaned but it still does it could it be the bearings that are doing this its had about 5 litres of fuel through it and never ran hot?any suggestions?
cheers
how long has the conrod been used?
maybe the conrod is nearing its end...
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 10-12-2008, 08:55 AM   #1772
Team Kamikaze's Avatar
Originally Posted by Baedarlboo View Post
P5...sounds like a hot OS plug. You should be using a P7 if it's a OS.
OS plug does not last period. it is the wrong plug to begin with, that is why only Picco plugs (#6) are strongly recommended
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 10-12-2008, 09:00 AM   #1773
wingracer's Avatar
Trader Rating: 24 (100%+)
Put a Picco 6 in it and try again. If it still does it, change the rod. Might not be a bad idea to go ahead and change the rod anyway.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 10-12-2008, 02:05 PM   #1774
M7H
M7H's Avatar
If I would give a Picco user an advice, I would certainly not tell them that "only Picco plugs are recommended" certainly because they are not the best plugs out there, they are the most expensive ones though.....
Go for GRP plugs, yes the ones you buy in an orange box of 5, for the same price as 2 and a half picco plug...
GRP plugs DON'T break when abused, and won't fall in your engine.....
Also with GRP you can actually see if you have a 6 or a 7 in your hands....
Just my 2 cents..
Serpent
M7H is offline   Reply With Quote
Old 10-12-2008, 08:51 PM   #1775
mtbkym01's Avatar
Trader Rating: 26 (100%+)
Hi, it's actually my engine that has been popping plugs, I've basically run the Picco P5TH or P5TC plugs in the car since march this year (at the time i could only get P5's, not P6's), and only on my last time out, it has started popping them. The engine has run flawless the entire time at about 100 degrees C, even after 20/30 min mains. The plugs upon inspection have not burnt out, but appear pushed in after the first coil. I'm certainly interested to hear of any other plugs that work in these engines, as with exchange rates atm, 1 picco plug costs about $18 AUD, for the price of 10 plugs, I could nearly have a new engine.
Cheers
~Kym Nuske~
RCHobbyzone.com.au / Model Motorsports International
Mugen Seiki 1/8, Reds, Neo+ Fuels
AE 1/10, Reds
"If it's old skool, it's kool"
mtbkym01 is offline   Reply With Quote
Old 10-12-2008, 08:53 PM   #1776
mtbkym01's Avatar
Has anyone ever tried the O'Donnell plugs?
~Kym Nuske~
AE 1/10, Reds
Old 10-12-2008, 10:37 PM   #1777
From what I hear, ODonnell has a Novarossi taper, so I wouldn't use it.
Only other plugs I know work and not leak, are OS, Sirio, GRP.
From my experience the OS seem to last the longest, Sirio right behind the OS.
Baedarlboo is offline   Reply With Quote
Old 10-13-2008, 07:15 AM   #1778
wingracer's Avatar
Sounds like it needs a rod.
Team Shepherd USA
Old 10-13-2008, 05:56 PM   #1779
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
running since march with no problems and now it does,thats what i would look at,
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 10-13-2008, 08:36 PM   #1780
gentleman81's Avatar
is the jl evo 2 still available. i am very happy with mine and the price.
what is the difference in the 2 and 3?
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 10-13-2008, 08:42 PM   #1781
Just my 2 cents..
when ever anyone on here recommends Picco anything, somebody starts crying... i dont get it?
picco motor works great with picco plug... wow! who would have thunk it?
i have been running this picco plug for 3 race weekends, including a 2 day regional.
take the advise from Kamikaze.
Old 10-13-2008, 08:45 PM   #1782
crank shaft, back plate, timing.
The crank was bored out a little larger, but overall timing was brought down a little, and the back plate is modded for flow.
In my honest opinion, there almost no performance difference between the 2. However, if you can increase the timing on the evo 3 like the evo 2, that'll be a hot motor. Increasing timing like the IDM's by putting a shim under the sleeve will work well, just a matter of finding a shim. they don't sell the IDM shims alone.
Old 10-13-2008, 08:52 PM   #1783
so my timing can be changed? or did u mean the Tuned?
Old 10-13-2008, 09:01 PM   #1784
wingracer's Avatar
I have heard that a Novarossi .28 head shim has the right inside diameter to make a sleeve shim for the Picco .12's. You would just have to cut down the outside dia. Haven't tried myself.
Team Shepherd USA
Old 10-13-2008, 09:09 PM   #1785
thats a slick trick.
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 09:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 05:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 11:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 09:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 01:49 PM
