Old 10-10-2008, 06:24 PM   #1756
G87z's Avatar
Alright here are the pics. This is with the adjustment maxed out on the chassis.
Hopefully someone can help me! haha
Thanks again!
Team Shepherd USA / Picco Engines / Sanwa / Matrix Tires / Byrons Fuel / SRC
G87z is offline   Reply With Quote
Old 10-10-2008, 07:00 PM   #1757
Team Kamikaze's Avatar
Is the carburetor being stopped by the aluminum bracket? the picture is blurry.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 10-10-2008, 07:02 PM   #1758
nitrodude's Avatar
I dont know anything about the MTX4R, but it looks to me like its hitting the brace that go between the upperdeck and rear bulkhead
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 10-10-2008, 07:03 PM   #1759
G87z's Avatar
No, There is plenty of room. The brake disc is not hitting the carb either.
I am wondering if the chassis holes are drilled wrong. Like a defect.
Old 10-10-2008, 07:16 PM   #1760
Originally Posted by GREGORY! View Post
hmmm,xspower i thought that ceramics had better durability and srength unter hi temperature.
how about the tko?has any try them?i am looking for some feedback!
They do have more strength as I said and the durability is in the fact that the bearings ability to run free and smooth or true for a given period of time. The ceramic in it's life span will outperform a steel bearing but as I said there is the give and the get part. I guess to sum it up in a sentence then I would say that the ceramic bearing can withstand more abuse then the steel.
xspower is offline   Reply With Quote
Old 10-10-2008, 07:48 PM   #1761
So it is not hitting anything at all? how about try using a 2 piece engine mount and see if there is a difference.
Old 10-11-2008, 08:12 AM   #1762
G87z's Avatar
I have tried both types of engine mounts.
I am at a total loss here on this one.
Old 10-11-2008, 07:34 PM   #1763
Make sure your pipe/header is not attached, be sure you are using the right screw/spacer for the bottom engine mount screws. Make sure your clutchbell is not jamming up against the second gear housing. Look all around the motor to be sure nothing is hanging up the motor. Other then that, I don't know what to tell you, as I have the same car, same motor, and never had this issue before.
Baedarlboo is offline   Reply With Quote
Old 10-11-2008, 10:49 PM   #1764
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Check that the screws used to bolt the engine mount, dont use oversized countersink washers... Like Baedarlboo said... De-attach anything holding the engine when making the gear mesh (header, fuel line, throttle link)... If you had to add many shims after the thrust bearing, you could try remove them and add them before the flywheel... This will make the clutch assembly reach out farther. Be careful not to over do this because I have seen much lateral play in clutchbells when the assembly is pushed out like this which leads to stripped gears...
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 10-11-2008, 10:59 PM   #1765
aussies1129's Avatar
Trader Rating: 74 (100%+)
HI just a question for a mate at my track who has been blowing plugs on every run out he is using the JLR3 and using P5 plugs in warm conditions and the wire element dose not last at all he has had the piston/liner and rod out and cleaned but it still does it could it be the bearings that are doing this its had about 5 litres of fuel through it and never ran hot?any suggestions?
cheers
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 10-11-2008, 11:02 PM   #1766
Actually what I am saying is that your brain is full of crap, I answered a question regarding bearings, which part did you not understand?
good response Sam I got a good chuckle out of that!
H.E.I AUSTRALIA
Old 10-12-2008, 12:37 AM   #1767
cheers
P5? plugs?
Old 10-12-2008, 01:09 AM   #1768
cheers
P5...sounds like a hot OS plug. You should be using a P7 if it's a OS.
Old 10-12-2008, 01:52 AM   #1769
M7H
M7H's Avatar
Take it easy....
can take a joke?....
Serpent
M7H is offline   Reply With Quote
Old 10-12-2008, 05:33 AM   #1770
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
cheers
is the plug burning out or pushing in
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 09:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 05:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 11:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 09:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 01:49 PM
