Old 08-11-2008, 06:22 PM   #1696
Trader Rating: 85 (99%+)
so what glow plugs can you use. i know you cant use novarossi i know picco and os but what are the numbers
tony block is offline   Reply With Quote
Old 08-11-2008, 07:02 PM   #1697
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Use Picco, IDM or Sirio plugs. Use whatever number you need. (usually number 6 or 7)
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 08-11-2008, 07:04 PM   #1698
thanks scott
Old 08-11-2008, 07:05 PM   #1699
Team Kamikaze's Avatar
P6TH Picco plugs.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 08-11-2008, 08:31 PM   #1700
that is a medium plug. dont you want to use cold plugs like novarossi.
Originally Posted by Team Kamikaze View Post
P6TH Picco plugs.
Old 08-11-2008, 08:37 PM   #1701
P6TH plug which is the coldest you want to use on a JL .12, the PICCO P7TC is for a .21 engine.
Old 08-11-2008, 08:41 PM   #1702
rpoage's Avatar
Originally Posted by G87z View Post
I guess I kind of started a war here with my question. But in regard to changing the bearings, I have changed them out and still have the leaking in the front bearing. I have also swapped to a NOVA carb and there is no leaking present with it. I guess I will still hunt for the answer.
The engines we use seal the bearing by liquid lock. If you want a big term for it "surface tension" (The a property of the surface of a liquid that causes it to behave as an elastic sheet). The tollerance between the crank and the case is critical to this working which is why loosing a bearing can make a engine non rebuildable. It is common for boat and some plane engines to not even have a seal at all. Our engines have a seal to keep dirt out of the bearing not seal vacuum. If you use after run oil or leave fuel in the crank case it will leak out the bearing over time. If the engine runs fine I wouldn't loose any sleep over it.
rpoage is offline   Reply With Quote
Old 08-12-2008, 05:16 PM   #1703
TeamCarnage's Avatar
Trader Rating: 23 (100%+)
When my engines run well, I sleep very well!
TeamCarnage is offline   Reply With Quote
Old 08-12-2008, 05:39 PM   #1704
That's a nice slogan
Old 08-13-2008, 10:51 PM   #1705
EdwardN's Avatar
That is sound when guy knows what he is talking about!!!!!!
Hats off for him!
About my signature-I love it At list I have 90/10 ratio, which pretty high for most.
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 08-16-2008, 02:54 AM   #1706
rias5037's Avatar
anyone know if the following idm picco piston/sleeve set will fit the JLR.12 Red Dot (first version, not evo3)
1392 P1-R .12 RE EVO 2 ABC CYL / PISTON ON-ROAD
thanks
rias
rias5037 is offline   Reply With Quote
Old 08-16-2008, 05:29 AM   #1707
That is correct I was waiting for the teacher to spill the beans. But I guess he was waiting. All the statement was so that it was not needed to spell out that the lubricant in this case is spun into a liquid seal by the rotation of the inner raceway and balls at high rpm. I really do not think that there are many people who care about how it sealed. But I guess the teacher had to blind people with science for them to understand that if the front bearing is smooth do not worry about the leaking oil out as I stated in the posts prior. Thanks for the science of it I was not going to post the info. A++++
xspower is offline   Reply With Quote
Old 08-16-2008, 05:30 AM   #1708
thanks
rias
Yes it will fit fine.
Old 08-16-2008, 06:09 AM   #1709
rias5037's Avatar
thanks mate
Old 08-16-2008, 07:16 AM   #1710
rias5037's Avatar
sam reckons these two engines have different timings, if i out the IDM piston sleeve in the JLR, would it affect the performance.
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 09:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 05:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 11:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 09:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 01:49 PM
