Old 08-03-2008, 01:53 AM   #1681
Uga
Uga's Avatar
Originally Posted by stefan View Post
I am not trying to spam here, but if you need this manifold here in Europe, you could order it here:
http://www.scuderia-fun-and-drive.com/
Click on "Fun & Drive shop" and and then on "Auspuff"
It's the German IDM importer and they have it in stock.
Cheers.
Wow, the delivery from Germany to Latvia is almost 2 times more than from USA to Latvia, which is like.. umm, 5 times longer way..? And actually usually it takes around the same time for delivery +/-3 days. Thanks for the tip, but I think I will stick with the US shops at least for as long as the dollar starts rising again.
-=Xray XB4=-
-=Xray XB8E=-
-=Schumacher Cougar KF2=-
-=Awesomatix A800X=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 08-04-2008, 11:37 AM   #1682
G87z's Avatar
Any ideas on a leaking front bearing on my Red Dot EVO3? I noticed the front bearing was starting to leak after about the first quart of fuel. I have about 3/4 of a gallon through the motor now. I have changed the front bearing in the motor already and it has not stopped. I have read this thread from start to finish looking for some ideas. I sealed the carb where it enters the case. The carb is not leaking from any of the O-rings or where the metal is connected to the composite. My ehxuast manifold seal is in perfect working order. I have replaced the fuel tubing. I am 100% sure it is coming from the front bearing beacause it is slinging it all over the middle brace of my MTX-3. The leakage is pretty decent also. The bottom of the motors is also covered. I do not think the leaking is affecting the tune although I did have some issues with the tune this past weekend. Is there a fix to this problem or should I just junk the motor and replace it with a new one?
Thank you in advance!
G87z is offline   Reply With Quote
Old 08-04-2008, 12:12 PM   #1683
roadrage's Avatar
Trader Rating: 14 (100%+)
my motor is new, and all the jl's ive had befor this have done the same thing. i think it just has to do with wearing in because after a while it doesnt leak anymore
Austin Wolfe
Serpent America-Trinity/Revtech-www.ActivRC.com
roadrage is offline   Reply With Quote
Old 08-04-2008, 12:18 PM   #1684
I have 3 1/2 gallons thru mine. No leaks from anywhere. I guess I have been lucky.
I'm going to start breaking in my 2nd Red Dot tonight.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 08-04-2008, 04:27 PM   #1685
I have said this in another post somewhere. The front bearing would not make a difference if there was a leak with the engine off or not. The .12 engines have a sealed bearing and the others do not. The engine when it runs spins the raceway fast enough to seal the engine with no leaks. So the only thing that happens is that when you use a fuel that has good lubrication it will tend to build up in the front there is no where for it to go. We use shielded bearings on all our team motors and there are no problems with them, Nor do the on road .21 engines come with sealed. These are really for keeping dirt out on on road situations. So if there is a tuning issue and the front and rear bearings are smooth then you need to look at the other parts of the engine because the front bearing leaking some oil out is not the cause of the problem.
xspower is offline   Reply With Quote
Old 08-06-2008, 07:57 AM   #1686
EdwardN's Avatar
Sorry to correct you, but statment above is not correct. It is not the way how sealing works on engines.
You need to do more homework to learn sealing techniques on nitro engines.
For the guy which looking for reason of leaking bearing-I would start from measuring clearance beatween main shaft body (12mm diameter) and mating area on cranckcase-clearance should be .03-.05mm, make sure both bearing are full coaxial position (by all meaning) and make sure that radial play on both bearings within manufacturer specs. To do all these measurments you will need really good tool (which is expencive), so may be my suggestions will not work, but these are the area where it should start to look for reason first.
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 08-06-2008, 04:16 PM   #1687
Please do tell then how a shielded bearing that has no seal maintains crankcase vacuum without any leakage of air into the engine. And tell me how there is a leak between a inner race and the balls rotating at how many thousands of rpm? Oh and just for some more info the reason as I know this is how it is sealing is that I have spoken with the actual manufacture of bearings in fact a few of them as to confirm this years and years ago. I have done some work in the past with bearings. And if you are going to tell me that the clearance between the crankshaft and the crankcase is what is preventing this then you would have to mean that there would be less then .01mm clearance. The reason that this is happening then is why? And I am speaking of the front engine bearing leaking excess oil out. He is speaking between the inner and outer raceway not the bearing fit between the outer race of the bearing and the crankcase. Please let me know. I really do not like to even reply to these posts but I would like to hear how this is happening then. And you should truly not have to seal any part of the engine if the fits and clearances are correct that is what the o-rings are for.
Old 08-06-2008, 07:59 PM   #1688
EdwardN's Avatar
I just suggested to do your homework and I am not a teacher.
Get the hydraulic dynamics book and find answer there. Then you will know how the sealing happened on systems like nitro engines.
I hope you had chance to talk to SKF or INA engineers, not sales rep.
Good luck!
Old 08-06-2008, 08:35 PM   #1689
gentleman81's Avatar
this is alot of talking regarding this matter. either change the bearings as part of the troubleshooting or dont. what are they 30$ each?
not even worth you guys time arguing.
my 2c
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 08-06-2008, 08:47 PM   #1690
Old 08-06-2008, 08:50 PM   #1691
my 2c
I am with you like I said I am done with this. Still no answer. I am not getting into the dynamics of the engines crankcase pulses over a front bearing. I am done.
Old 08-06-2008, 09:04 PM   #1692
Team Kamikaze's Avatar
Why quit now? you have a point and you are right.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 08-07-2008, 12:16 AM   #1693
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Seems no one reads his signature... Could this be the 10%? or the 90%?
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 08-07-2008, 02:55 AM   #1694
NiTrO BoOsTeR's Avatar
haha i read it, i think that xspower is the person who is correct because he used actual terms and big words lol, plus he gave reasons for his answer and actually knows what he is talking about. the other guy i think is just a s***t stirrer plus his signiture makes him sus.
Just my opinion,
Mitchell
Serpent 733 - RB T10rc - Ko Helios EX-10
Serpent 733 - Novarossi 3SCT Tuned
============== SERPENT the only way ============
==== Pro Buggy Rc, Pitsworth - for all my RC needs =====
NiTrO BoOsTeR is offline   Reply With Quote
Old 08-07-2008, 05:58 AM   #1695
G87z's Avatar
my 2c
I guess I kind of started a war here with my question. But in regard to changing the bearings, I have changed them out and still have the leaking in the front bearing. I have also swapped to a NOVA carb and there is no leaking present with it. I guess I will still hunt for the answer.
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 09:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 05:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 11:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 09:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 01:49 PM
