Old 06-10-2008, 06:23 PM   #1531
gentleman81's Avatar
when should i change my rod?
i have had motors where i havent, and i had a ninja that broke on me. i wanna be safe. i do have a friend that has one and says he hasnt touched it.
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 06-10-2008, 06:53 PM   #1532
I changed mine after 2 gals.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 06-10-2008, 07:09 PM   #1533
Trader Rating: 21 (100%+)
Everything I have read says 1 1/2 to 2 Gallons.
VA_Racer is offline   Reply With Quote
Old 06-10-2008, 07:28 PM   #1534
Default won't start
Put a new JLR Evo 3 in my CRT .5 on the weekend and idled two tanks of 30% Tornado through it with a Picco P6TC plug. Went to start it up today and I just cannot get it going. Glow plug was brand new. I'm still new to this so what else should I be looking for?
morati is offline   Reply With Quote
Old 06-10-2008, 07:40 PM   #1535
On the Picco engines I would most defiantly change it at 1 gallon intervals. The engine revs high and can cause rod failure from stress if not maintained. I am sure they can run for longer but do you want to knock a hole in the case over a 40 dollar rod?
xspower is offline   Reply With Quote
Old 06-10-2008, 08:15 PM   #1536
wingracer's Avatar
Trader Rating: 24 (100%+)
It really depends on how hard you twist the motor. If you run short tracks with conservative gearing I have seen rods outlast the rest of the motor. If you run 301, every gallon, hahaha. High RPM's are a killer on the rod.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 06-10-2008, 08:56 PM   #1537
i will get one on order
Old 06-11-2008, 06:39 AM   #1538
[QUOTE=Team Kamikaze;4525921]Talk to me Steve.
I will give you a call about a engine later this week. I bought the last one off of you. It was great meeting you last week.
Steve Walter
Old 06-11-2008, 07:22 AM   #1539
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Team Kamikaze View Post
Take off your Head Button and install the Ninja Plug, then on the combustion chamber side you will see right away that it won't seat flush against the combustion chamber, meaning it won't work.
i have used the Ninja plug for over 12 months on all my picco engines.
i did remove the head button, i tried a nova plug, ninja plug and OS plug.
OS plug sits deeper into the combustion area. Nova doesnt seal. and ninja plug fitted perfect flush with the chamber, and seals perfect.
my last 2 events with the picco tuned motor, i used ninja 6 plugs. no problems at all with over 5 lts of Runnertime.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 06-11-2008, 07:26 AM   #1540
Pattojnr's Avatar
try a new glow plug. make sure your glow starter is charged. if it was running hot it could have blown a plug on cooldown. i have had many OS plugs inmy OS motors do this. more of a batch issue i think though. but its still possible to happen to any plug. if it does start, when its going again, try to richen the top end a bit, it may be running lean and creating heat, which is burning out the plug.
Serpent - Walter RC
Old 06-11-2008, 03:20 PM   #1541
Thanks for the help. It WAS the glow plug. Put a new one in and it started right away.
Old 06-12-2008, 04:58 PM   #1542
On the red dot. On a really humid day. What is the best thing to do, not to get it to over heat? Last weekend I richened the top end. But I think I should have done the bottom end.
Steve Walter
Old 06-13-2008, 12:20 AM   #1543
Team Kamikaze's Avatar
The bottom end needle only affects the initial acceleration, the High speed needle should only be the one adjusted if you want it to run rich.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 06-13-2008, 07:29 AM   #1544
I was more asking the question to help control over heating during the the high heat/ humid days we have in this area.
Steve Walter
Old 06-13-2008, 07:45 AM   #1545
M7H
M7H's Avatar
You can read posts here saying that you can run your engine leaner when it gets warmer outside, but when it gets even warmer and with the humidity we in the Netherlands also have to deal with, you must indeed richen the top end of the engine. This might needs to be set so rich, that the engine easily flames out, this is the point where you should put in a hotter plug.....
So:
Richen the engine and put in a hotter glow plug, because then the engine is better able to burn the fuel....
Serpent
M7H is offline   Reply With Quote
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 09:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 05:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 11:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 09:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 01:49 PM
