JL Racing .12
#136
Whered you pick it up at? Awesome motor isnt it?
#137
Originally Posted by three50zx
All I can say is, this motor made my car a missile at my local track this past weekend. Very easy to break in and runs strong all the way through the rev band.
thanks in advance
#139
Originally Posted by rcrevolution
there's a modified version of a modified engine ?
i thought the JLR was the only JLR there is out there, unless u modify it yourself which is kinda pointless
#141
man, when are .12 engines gonna get to the point where they cant make any more power without getting more displacement?
I remember 7 years ago 1hp for a .12 was ALOT now they are the same size and making almost double of that.
they have to be reaching a physical limit, no?
#142
Originally Posted by bullie1
I am considering getting one of these too.Is yours a stock one or a mod version
thanks in advance
thanks in advance
My motor is stock. Let me put it this way, I increased my lap times on the same track layout by .5 sec per lap and wasn't even trying. I had been looking for corner to corner speed and now I have it. I went from a Modded NSRS3 micro-cast to this motor and very much satified. Now I don't have to worry about run time. For the money, it's worth a try. Good luck.
#143
How does this thing run on 16% nitro ? Can it still outperform on a mega zx12 dsII or is it about the same. Trying too clear out some options (probably still get the mega or JP due too my LHS is supporting them)
#144
#145
The JL is the same as the DSII+ and like Dj said they are both picco based engines..
#146
Are you saying, that aside from a different color crankcase and head, the engines are exactly the same? That if I put both engines on a dyno, the performance curves are going to be exactly the same?
#147
I don'tknow if they will be the same on the dyno but I was told that internally, both motors are identical. THe crankcase and head are supposed to be different with the Mega having the whole sleeve in the case.
#148
Hi.I have JLR .12 Red Dot Engine. What type of glow plug is best for 16% nitro. I haveářčáář PT6H Picco Plug, is it good for me?Thanks
#149
Originally Posted by rmdhawaii
Let me get this straight...
Let's clear this out. The Mega .12 ZX DSII does not have the same piston/sleeve as the JLR. The crank is the same part, but the DSII does not have the silicone ramp.
Now, there is word that a newer DSII + (Plus), is coming out having the same piston/sleeve as the JLR, but no word of crank having silicone ramp.
Right now the only place you can get a Modified Mega .12 ZX DSII Plus (prototypes) is from Maxy's Modified Engines.
About performance curves on a dyno.....it would be nice if somebody had the money to send all the different .12 Picco based engines and had them tested to compare their differences, because if they are made under specs, they might have small different timings between them.
Latest Picco EVO3 (newer crank with bigger inner bore and scoop)
And these engines based on the Picco EVO2
JLR Red Dot
MEGA DSII Plus
IDM EVO2
LRP Spec3
AFM
#150
Nitro content: 16% 20% 25% 30%
Head shims: 0.40mm / 0.40mm / 0.50mm / 0.60mm
Large tracks may require an extra 0.10mm shim to reach higher top speed and improved fuel consumption, but this will decrease acceleration slightly.
TURBO COLD GLOW-PLUGS to use when humidity is below 70%
•P5TC hot filament
•P6TC medium filament
•P7TC cold filament
TURBO HOT GLOW-PLUGS to use when humidity is above 70%
•P5TH hot filament
•P6TH medium filament
•P7TH cold filament
The filament number will depend on the ambient temperature. Colder use hoter filament. Hotter use colder filament.
AFM
