Novarossi Plus 12+3ct Glow Plug recommendation
What plug should I be using? I am currently still using the plug that came with the engine. The engine is fully broken in now with a half gallon of gas through it.
:batman: |
Use C6TF Nova Rossi plug
C6Tf if using 16% Nitro and C7Tf is using higher Nitro
Oh ok cuz i am using 30% with a shim.
I'm running 7f. Runs good but I could use a little bit more bottom. :lol:
I use 6tc or 6tf plug........
this is the clutch setup I use for MTX4 flyweights drilled to 4mm diameter holes MSR ultra hard spring at 1.5~1.7mm clutch gap 0.60mm...... yellow shoe...... |
| All times are GMT -7. It is currently 12:01 PM. |
