did you polish the outside of the sleeve,and what do you have on the inside of the sleeve.
i have sponge on the inside, it makes it easier for camera to focus....and yes the outside is polished.
Nice porting job on your sleeve.
the exaust port on the motor case looks just the opposite of a novarossi, the top part goes up hill instead of the bottom going down. instead it looks like it goes strait out at the bottom, wallyedmonds do you see that to?
Just wondering, after doing that killer port job on the sleeve why did'nt you advance the timing on the crank??
I just haven't gotten to the crank yet....LOL but I wanted to post a pic of it stock, and after I do the crank today I will post pics of it cdompleted...... I have my timings marked out on the crank though if look at it..
If I'm not mistaken, you don't port the boost port. I'd have to look at my engines to verify though.
Dave |
Sorry Maximo I missed that first glance. When you finish that motor it should really rip!! :nod: Let us know how it does.
why dont you also try match porting the liner to the exhaust port ?
Do not port your sleeve to the exhaust port, you will mess up the timing for the exhaust . If you do not know how to messure timings and what changing the timing does to your enginem do not touch!!
I will also strongly advice you to messure timing on your crank before you alter this, then you know what you have done and you learn more from your project, |
