Old 10-06-2006, 05:53 AM   #1
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Default Werks LCollari LC12 AAC pro 3 1
Hi guys, just wondering if anyone has run this motor, or has some info about it, i cant find any HP specs. it is the IFMAR version. looks great, and would be my first AAC engine. any run-in and tuning info is appreciated as well. thanks.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 10-06-2006, 07:43 AM   #2
afm
afm's Avatar
I had one 2 years ago and it was made by Sirio (Star Engineering), based on the Sirio Evo 2, and with Mauro Collari's hand mods, and a special low garvity cooling head. It was the most powerful .12 engine at that time.
Break-in as any engine. Since it has an AAC sleeve/piston you need to warm it up several laps before attempting needle tune ups.
Specs
Manufacturer: LAMBERTO COLLARI MOTORSPORT
Base: SIRIO Evo 2
Bore: 14.0mm
Stroke: 13.7mm
Crank: TURBO with 8.0mm inner dia.
Carburetor: 3 needles, composite/aluminum, Interchangeable Venturi 5.5mm
(Base Settings)
High Speed - 5.5 turns out
Low Speed - 3-1/2 turns out (Generally this should be flush with the end of the slide)
Mid Range - Flush then one turn out.
Sleeve: Hard chrome aluminum
Ports: 3 transfer + 1 exhaust
Bearings: Front 7X17mm, Rear 11.2X21 mm
Head: Turbo with 0.20mm + 0.10mm shims (good for 25% Nitro)
Cooling Head: 52mm dia LCG
Timing: Transfer:114
Boost: 114
Exhaust: 159
Induction: 213
Max Power: 0.83hp @ 33,700 rpm (SAE Corrected) with 20% Nitro
Max Torque: 29.0 oz/in @ 19,600 rpm (Sae corrected) with 20% Nitro
Max. RPM: 41,000
AFM
afm is offline   Reply With Quote
Old 10-06-2006, 07:55 AM   #3
Pattojnr's Avatar
thanks AFM, i run 16% nitro, how is it comparable to say a ZX12 Picco ?
Serpent - Walter RC
Old 10-06-2006, 08:13 AM   #4
afm
afm's Avatar
For 16% Nitro you may take out the 0.10mm shim.
ZX 12 has more low end power. Collari more top end....but it is relative...depends on how you gear each engine.
Also don't forget that the Collari is an old version of Sirio, it is not based on the new T3 or STI versions.
If you are planning on jumping into Sirio based engines, better get the standard Sirio STI, or the Murnan modified version.
AFM
Old 10-08-2006, 04:11 AM   #5
Pattojnr's Avatar
just wondering what glow plug is best for 16% and what type, i run OS P7 at the moment, do these fit the sirio engines ?
Serpent - Walter RC
Old 10-08-2006, 07:24 PM   #6
Yes the Sirio and the OS plugs are cut the same way... For 16% nitro, I would use the OS. P6 or P3... The Sirio plug to use if you can find it is there #6 plug. They're the hot plugs and you should get alittle more power from using a hot plug with 16% fuel... .02
RC_Alan
rc_alan is offline   Reply With Quote
Old 10-09-2006, 12:57 AM   #7
Z00M's Avatar
Trader Rating: 15 (100%+)
Patto, I'll give you my old one on Sunday to have a look at if you like. Let me know if you want me to bring it.
Cheers,
Mike.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 10-09-2006, 04:10 AM   #8
Pattojnr's Avatar
thanks rc_alan for the info.
Zoom, do you have a sirio, or collari ? im frustrated with the ZX12, and i think ill sell the TZ with a mongoose. looking for an interim motor to finish the season off thats gonna hold its tune. but it also does help if the pit man uses my own fuel and not someone elses
Serpent - Walter RC
Old 10-09-2006, 06:21 AM   #9
Pattojnr's Avatar
do these motors inherit the crank problems of the sirio engines that broke crankshafts ? if they do , is there a way to look after it any better ? thanks.
Serpent - Walter RC
Old 10-09-2006, 05:39 PM   #10
Z00M's Avatar
The one I've got is the Collari LC12. It is sirio based but it comes in a collari box.
I'm not sure if it inherits the same crank issues. My conrod never lasted long enough to find out. The motor I have at home is only 2 race meetings old and the top bearing in the conrod is gone. This is of course just my experience.
I'll show it to you on Sunday.
You know if you get a better pipe your OS will be a better motor than one that's design is 4 years old.
If you end up buying the collari, let me know, I can sell you almost a complete motor for spares - cheap!!
Just my 2c.
Cheers,
Mike.
XRAY XB4
Old 10-11-2006, 08:36 AM   #11
Pattojnr's Avatar
ok, so how much you gonna slug me for the motor, wit out a conrod ?
and are conrods still available ? is the rest of the motor ok ?
so many questions. lol
Serpent - Walter RC
Old 01-14-2007, 08:02 AM   #12
Pattojnr's Avatar
Hi guys, wondering if there are parts for this engine ? and if so who stocks them ? thanks in advance.
Serpent - Walter RC
Old 01-16-2007, 05:07 PM   #13
nitro_moe's Avatar
Hi guys,,
Can anyone please post a link to this engine?? I'm currently on the lookout for a new .12 engine and would like to research perhaps every Sirio and Novarossi engine out there..
Thanks in advance..
nitro_moe is offline   Reply With Quote
Old 01-16-2007, 06:55 PM   #14
afm
afm's Avatar
Originally Posted by nitro_moe
Hi guys,,
Thanks in advance..
There is no link, the engine is no longer made, it's more than 2 years old....just read the posts here you have more then enough info to compare.
AFM
Old 01-16-2007, 07:17 PM   #15
Suspended
I have 2 of this motors, they are fast but "AAC" just doesn't last very long.
scarlet is offline   Reply With Quote
Werks B7 Pro speed metal Onroad Nitro Engine Zone 65 05-24-2012 11:56 AM
++++WERKS B7 PRO & B3+++ David Wall R/C Items: For Sale/Trade 44 08-21-2008 07:20 AM
NIB LCOLLARI XS 200 .12 Nitro$junkie Australia For Sale/Trade 5 06-11-2007 05:19 AM
Collari LC12 V Sirio Evo 3 Rody Onroad Nitro Engine Zone 2 09-12-2005 05:35 AM
Collari .12 LC12 3 Port AAC Nitro Engine (Slide/SG) NIB $230 Buy it Now JKA R/C Items: For Sale/Trade 0 08-15-2005 07:43 PM
