Old 10-04-2006, 04:55 AM   #1
ProudSavageOwnr's Avatar
Send a message via MSN to ProudSavageOwnr Send a message via Yahoo to ProudSavageOwnr
Default Running in LRP .18 on 20%?
ok me n my mate are having a little arguement about how to run in a .18 size LRP engine......i say u should run in the engine with wat u plan on using in it.....in this case run it in on 20% and use 20% in it......hes saying run it in on 5% and then use 15%
who is right and who is wrong?
FG leopard comp w/Trevor Simpson 28.5 bzm crank
HIP Baja 5sct
AE tc5 3.5t speed monster,Futaba 4pks
Raptor G4 ,Raptor e550,Gaui x5,Mini titan v2,Precision aerobatics bandit 4s monster,Carbon z scimitar Jr 11x
ProudSavageOwnr is offline   Reply With Quote
Old 10-04-2006, 06:34 AM   #2
Suspended
robot's Avatar
i've run all my .18 in on 10% then jumped up to 20% with no problems at all, now i'm using 16% as i'm starting to race with it and haven't had a drama, you just need to retune them for the nitro content, but i did run my .28 in on 25% with i was running at the time and dropped it back to 16% with a retune and works fine (only because that's all the fuel i had at the time 16%)
robot is offline   Reply With Quote
Old 10-06-2006, 06:37 AM   #3
duneland's Avatar
Both ways are fine. Breaking in with lower nitro content, saves a little money (since you waste a lot of fuel during break-in & lower nitro fuel is cheaper).
The main thing is how it is tuned.
duneland is offline   Reply With Quote
Old 10-07-2006, 06:38 AM   #4
dude.....wasting a few buks more on your fuel isnt realy gona hurt if u got a 300 or 500 dollar motor.....like seriously........i wouldnt wreck a 500 buck motor ujst because im tight not to spend a few bucks more n get some more content nitro
HIP Baja 5sct
Old 10-07-2006, 06:59 AM   #5
itchy b's Avatar
usually most experienced racers that i have talked to about this have recomended that the same fuel is used at runin as you use for racing
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 10-07-2006, 08:01 AM   #6
Suspended
robot's Avatar
been told both versions and read both versions, so i guess no one right or wrong then, as long as you get the heat cycle right
Old 10-07-2006, 08:54 AM   #7
duneland's Avatar
There is NO way that running lower nitro fuel will 'wreck' an engine. It's perfectly safe.
Old 10-07-2006, 05:09 PM   #8
err yes it can wreck an engine because running different nitro percentage = different temps which affects the way the sleeve and piston expand and contract........
HIP Baja 5sct
Old 10-08-2006, 01:36 AM   #9
Absolute twaddle
Thousands and thousands of glow engines have been running over the years with NO nitro in the fuel,just a methanol and oil mix.
In some racing applications nitro in the fuel is banned.
Allan is offline   Reply With Quote
Old 10-08-2006, 01:59 AM   #10
hyper7vspec's Avatar
Send a message via MSN to hyper7vspec
that is complete bullsh**,i have changed nitro in my engines with no dramas.i have gone from 20-30% nitro without problems.
-Andrew Foord- Thanks to all of my sponsors!
TLR - OMP/Modelflight - Orion - Proline - Nitrolux Fuel - Savox - HobbyWing - RCRS.com.au - Schelle - NVision - Ace Hobbies
hyper7vspec is offline   Reply With Quote
Old 10-08-2006, 05:56 AM   #11
duneland's Avatar
Absolute bull. Temp is determined by how you tune.
Still running a B3? Bikerbob Electric Off-Road 25 04-10-2008 05:40 PM
an 480 out-running BL on my SB... ny Electric Off-Road 2 03-17-2008 08:38 AM
running too rich or running to lean bumm_off_street Nitro On-Road 7 03-29-2006 08:28 PM
running-in a V One SII reckLEss Australian Racing 5 10-02-2004 08:47 PM
running out of gas gasnewb!!!! Electric Off-Road 2 08-05-2003 12:03 PM
