Old 10-01-2006, 06:21 AM   #1
razzor's Avatar
Default Front engine bearings ???
I am changing my front bearing on my AxeMotorRossi Black Magic .21 engine.Previously I replaced with rubber sealed bearings with the seal removed on one side of bearing.
I couldnt get rubber sealed lately and got metal sealed ones ,would I have to remove the seal on one side as well ?
Reason I ask is that rubber seal bearings usually seal well and metal dont.
Is this correct ?
On my Palmaris PR12 the front bearing is metal sealed and seals are still in place.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 10-01-2006, 08:35 AM   #2
EdwardN's Avatar
Is this correct ?
Hello Shiraz.
You can use shielded bearings instead of sealed for onroad-no problem at all (actualy it is better-rubber seal's leap will burn out in sealing diameter any way). Sealed bearings are required for off-road aplication due to the a lot of dust. Just get shileded bearings and remove one side shield.
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 10-01-2006, 08:52 AM   #3
razzor's Avatar
Thanks ED ,will have to look for some rubber sealed bearings then.
BTW got PR12 running sweet now ,Kitracer's advice was on the button.
cheers
Casterracing ZX1.5R
Old 10-03-2006, 02:54 AM   #4
Send a message via MSN to Qlone
The seal is removed on one side to allow the engine fuel to lubricate the bearing. If the front seal starts leaking the engine becomes hard to tune and will spill fuel all over the car.
A metal seal bearing is always a bit leaky. It should work fine without removing any of the seals (since it allows some liquid to pass through anyway) but may be a bit messier to use than a good quality rubber seal bearing.
Qlone is offline   Reply With Quote
Old 10-03-2006, 09:58 AM   #5
razzor's Avatar
Thanks bud ,managed to get a rubber sealed bearing.
Couldnt get Z rated but it should good for a race meeting.
Casterracing ZX1.5R
Old 10-04-2006, 03:31 AM   #6
Qlder's Avatar
I noticed that the ceramic bearing in the front of the JP P5FX Buggy motor has both rubber seals still attached, as do the TKO ceramic bearings.
Qlder is offline   Reply With Quote
What engine bearings hobdog Nitro Off-Road 2 09-11-2008 01:43 PM
Losi 8 buggy front clutch bearings???? btracing Nitro Off-Road 23 05-25-2008 01:42 PM
How do I replace the front and rear main bearings? rcjunky10 Nitro Off-Road 27 04-01-2008 08:10 PM
OS VZB Vspec front and rear bearings New NismoSkyline17 R/C Items: For Sale/Trade 0 05-21-2006 06:53 PM
Engine Bearings RayJ Nitro On-Road 1 01-11-2004 07:21 AM
