Old 09-23-2006, 10:53 PM   #76
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
Default running an Axial
We all know that if you put An Axial engine in any of the top ten at the worlds that it would produce the same result. As far as running the motor to 400 degrees in testing is not to see if it can run at that temp, but it was just a test the durability of the materials within the engine. Axial is commited to put the best quality into all of their products. If you had a little business sense you would understand why Axial decided to skip the worlds this time around. Time wil be the judge and those that acually own one.
Team Kyosho, Team Epic, IDM Engines, J-Tech racing fuels, Airtronics, Superiorhobbies.com
Speedypeterb is offline   Reply With Quote
Old 09-24-2006, 01:58 AM   #77
razzor's Avatar
Id have to agree ,as a Profi 12 user I have gone through some teething problems and have overheated engine a good few times where my temp gauge couldnt read the temp >400deg/c
I have stripped engine and everything is A ok.
Fianlly figured out the problem with engine was the hsn oring got too loose and when running car the hsn was turning clockwise ,leaning out the engine.
If anybody else had these hassles they would have given up on the engine but I had to find the problem.I found problem when I was blipping the throttle with car on the starter box and I saw something move in the corner of my eye,when i blipped a gain saw the hsn move.
I am convinced if I had this problem with any other engine I would have had a different result.Engine running sweet and is not showing any signs of power falling off.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 09-24-2006, 02:03 AM   #78
razzor's Avatar
Originally Posted by rmdhawaii
Thanks Edward. Is the Axial conrod 25 mm as well?
The Palmaris Profi PR 12 rod is 25mm and should be the same as Axial 12RR.
Casterracing ZX1.5R
Old 09-24-2006, 02:32 AM   #79
Registered User
You don't have a clue on what you are talking about, "put an Axial engine in any of the TOP ten at the worlds", What.............. you must be kidding, it is not going to even make the Y main you make me laugh
COREX is offline   Reply With Quote
Old 09-24-2006, 03:05 AM   #80
rmdhawaii's Avatar
Enough already
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 09-24-2006, 09:06 AM   #81
Moderator
mxwrench's Avatar
If anybody has a new (or relatively new) conrod, could you please measure points A and B as indicated below. Then I can put a engine matrix together for everyone to reference.
Thanks!
The Orion Wasp CRF engine con rod length on centers is 26.6mm.
I will have more info to add later, as this is the only one I have data on stuck in my head at the moment. I have many other engines that I will open and measure, possibly this evening.
BK
Brian Kinney
TLR Design Engineer
2016 Sponsors: Team Losi Racing, AKA Tires, Orion, Nitrotane, Horizon Hobbies, Fast RC Paint.
mxwrench is offline   Reply With Quote
Old 09-24-2006, 10:20 AM   #82
Enough already
you are right I thought that corex had a little sense but with his latest post it speaks for itself. ok onward with our education
thanks rmdhawaii
Peter
Old 09-24-2006, 11:10 AM   #83
nitrodude's Avatar
Ignore Corex. He is just a troll, and he is having fun with us now. Just ignore him and he will go away.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 09-24-2006, 11:59 AM   #84
rmdhawaii's Avatar
BK
Thanks Brian!
Old 09-24-2006, 05:58 PM   #85
I have a NIP STI conrod. I'll measure it tomorrow and post the results.
Dave
DaRollaRacer is offline   Reply With Quote
Old 09-25-2006, 07:25 PM   #86
Sirio Evo 3 STI Conrod Information:
Length A (Inner Diameter) - 22.1234mm
Length B (Outer Diameter) - 29.87mm
Crank Bushing Diameter - 4.5085mm
Wrist Pin Bushing Diameter - 3.3782mm
Conrod Lenth On Centers - 26.067mm
Dave
Old 09-25-2006, 07:46 PM   #87
rmdhawaii's Avatar
Thanks Dave!
The rod/stroke ratio for the STI comes out to 1.90. While not the greatest news, this isn't exactly a surprise, as it has already been mentioned that the STI is a high RPM engine.
Hmmmm... Now I just need the OS TZ conrod length for comparison.
Old 09-25-2006, 08:08 PM   #88
rmdhawaii's Avatar
Oh yeah... and the Mega ZX12 and new DSII.
BTW: More reading
Rod Ratio - Kinematics
http://e30m3performance.com/tech_art...atio/index.htm
Rod Ratio - Dynamics
http://e30m3performance.com/tech_art...mics/index.htm
Connecting Rod vs. Stroke Analysis
http://victorylibrary.com/mopar/rod-tech-c.htm
Old 09-25-2006, 09:21 PM   #89
afm
afm's Avatar
Thanks Dave!
Taking into account tolerances, and according to Sirio the rod lenght is actually 26.00mm.
Mega ZX, and ZX DSII have 26.00mm.
OS TZ's have also 26.00mm
So all these engines have a stroke to rod ratio of 1.86
The Orion CRF has a 26.6mm rod lenght and stroke to rod ratio of 1.90
1.75 : 1 ratio = wide power band
2.00 : 1 ratio = narrow power band
But to finish the chart you have to take into account the engine's timing diagrams.....Induction, Transfer, Exhaust
For example I have timings for:
Orion CRF OS TZ Sirio Evo 2
Induction 255 206 213
Transfer
afm is offline   Reply With Quote
Old 09-25-2006, 09:22 PM   #90
EdwardN's Avatar
Hi Reiner. It is really valuble info, but please remember that not everything from real car engines is translated straight to our engines. So when you make decision please take to concidiration that factor.
Enjoy!!!!
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
bore 'n stroke? nitrothugg Onroad Nitro Engine Zone 1 07-03-2008 12:22 AM
What is long stroke / short stroke engine? turboburns Electric Off-Road 18 10-03-2005 04:44 PM
OS Four Stroke 26 F - C markanda R/C Items: For Sale/Trade 2 09-28-2005 05:06 AM
4 stroke nate johnston Electric Off-Road 6 07-21-2004 11:15 PM
Engine displacement Eric2004 Onroad Nitro Engine Zone 17 06-09-2004 11:28 AM
