Old 08-29-2006, 07:37 PM   #1
Default Difference between EFRA & IFMAR Spec Engines?
Was checking out some engines and was just wondering what the difference is between a EFRA & IFMAR Spec engine. Thanks.
pelico is offline   Reply With Quote
Old 08-29-2006, 09:20 PM   #2
Team Kamikaze's Avatar
Mostly in the crank, or I suggest you wait for RACING4EVO he will be in this thread soon answering all your questions, he knows a lot about engines, and he stand by his statements.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 08-30-2006, 11:51 AM   #3
Thanks man. Guess I'll just have to wait till Evo comes on.
Old 08-30-2006, 03:29 PM   #4
Grinder's Avatar
The difference in IFMAR and EFRA are the crankshafts. EFRA only allows a 7mm crankshaft bore, and no turbo scoop protruding into the crankshaft. IFMAR has no rules on crankshaft bore, or turbo scoops. IFMAR engines are usually more powerfull.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 08-30-2006, 05:44 PM   #5
Thanks Grinder. So are these engines legal for ROAR sanctioned races?
Old 08-30-2006, 06:12 PM   #6
captian's Avatar
ha pelico
i believe that efra and roar go by the same rule with engines . 5,5 carb and 5mm stinger but i dont see in the roar book the size of the crank opening ?
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 08-31-2006, 04:59 AM   #7
Grinder's Avatar
Both engines are ROAR legal.
Old 08-31-2006, 07:04 AM   #8
Bandeira's Avatar
Send a message via ICQ to Bandeira
EFRA is the most conservative of all... Limitations in the crackshaft bore and no turboscoop in the hole. Those engines have a similar work done ONLY in the counterweight... I think efra also got some limitations on the exhaust port height... Don't remember if it still...
IFMAR and ROAR engines are mostly the same specs... they are more powerfull as you can have bigger shaft bore and scoop...
One more think, I guess that ROAR engines come prepared for higher nitro content, as the other organizations limit this...
Bandeira is offline   Reply With Quote
Old 08-31-2006, 08:43 AM   #9
M7H
M7H's Avatar
EFRA:
for .12 engine
- Max nitro 16%
- Crank limitation
Probably that why the WASP REV is not seen in EFRA races, because the limitation in the crank, is what kills the performance of this engine I believe......
for .21 engine
- Max nitro 25%
Serpent
M7H is offline   Reply With Quote
Old 08-31-2006, 01:05 PM   #10
Thanks for all the input guys. Think I'm gonna try out this engine and see how it runs.
EFRA 2008 legal pipe for v-spec Finken Nitro Off-Road 11 09-18-2010 01:48 PM
RB V12 R3 EFRA-IFMAR 2008 RC HulkNT1 Nitro On-Road 3 05-13-2008 06:58 PM
Differnce between efra and ifmar engine? hendrikcls Nitro On-Road 4 10-11-2005 01:26 AM
What is the difference between these two .21 on road engines??? mtx3racer Onroad Nitro Engine Zone 2 04-19-2004 10:23 AM
EFRA spec. CORE Mod. rc_square24 Electric On-Road 0 03-29-2004 06:02 PM
