Old 07-23-2006, 10:09 AM   #1
banky71's Avatar
Default OS12TZ Bearings
I bought some new bearings for my OS12TZ, I need to remove and install the new bearings for my engine. I noticed that OFNA makes a bearing remover kit....10797 10mm - 11mm & 10798 13mm - 14mm. I am thinking about purchasing one of these kits, I just need to know which one do i use for my engine....
banky71 is offline   Reply With Quote
Old 07-23-2006, 10:24 AM   #2
nitrodude's Avatar
just heat the block to 350 degrees for 15 minutes and then just tap the block on a wooden block. The front one will be a little harder than the rear bearing, for the front one get a wooden rod thats bigger than the hole on the bearing and push it out. Works every time. Do the same when you have toput the new ones in.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 07-23-2006, 10:47 PM   #3
banky71's Avatar
OK...thx, I will try that.... and save some money
Old 07-25-2006, 02:40 PM   #4
ProE's Avatar
Send a message via MSN to ProE Send a message via Skype™ to ProE
Im looking for a site where I can buy the ceramic bearings for this engine online. Any Ideas?
ProE is offline   Reply With Quote
Old 07-25-2006, 06:17 PM   #5
Trader Rating: 44 (100%+)
boca bearings
YOKObori MOkei
wyl03 is offline   Reply With Quote
Old 07-27-2006, 12:49 AM   #6
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
I use a flat-head screw driver thats bigger than the front bearing hole to gently push the front bearing out of the block. And as nitrodude suggested, just tap to get the inner bearing out.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 07-27-2006, 06:46 PM   #7
uniquexme's Avatar
Send a message via MSN to uniquexme Send a message via Yahoo to uniquexme Send a message via Skype™ to uniquexme
may i ask if we can use the bearing that we buy from local bearing shop? and also plastic and metal cover, are they the same? coz price really difference a lot.
uniquexme is offline   Reply With Quote
Old 07-27-2006, 06:54 PM   #8
wallyedmonds's Avatar
i have this motor,and i just run the bearings old its an os it will keep on runing ok the block is very sensitive so i just leave it alone (i killed one tz befor)
wallyedmonds is offline   Reply With Quote
Old 08-01-2006, 07:50 PM   #9
Trader Rating: 15 (100%+)
I just got both bearings from Tower Hobbies for $40. Is there anywhere that is alot cheaper?
THE DOCTOR is offline   Reply With Quote
Old 08-03-2006, 10:33 AM   #10
TTT
Old 08-03-2006, 07:38 PM   #11
40 i dont think so 40 is pritty good
Old 08-04-2006, 05:49 PM   #12
Ok, Thanks this is the first time that I have bought bearings for the engine.
HPI R40 nitro touring car, OS12TZ & OS 1040 pipe, Mugen Mielke pipe wyl03 R/C Items: For Sale/Trade 5 07-01-2007 08:59 PM
GR-racing tuned OS12TZ-3port rcforum Nitro On-Road 2 12-13-2006 08:29 AM
KANZEN Bearings vs Boca Bearings vs Other Bearings rmdhawaii Nitro On-Road 6 04-29-2006 09:38 AM
Next Best Bearings To Ceramic Bearings????? J Smith Electric On-Road 47 08-21-2003 03:26 PM
