Old 04-17-2008, 08:58 AM   #346
keavze's Avatar
Originally Posted by colt1402 View Post
But fro now is 0.4 head shims total. Meaning i need to buy a 0.1shim to put it total of 0.5shims on running 25%?
shims is not actual head clearance.
some engines come with stock 0.1-0.2mm head clearance without shims at all, while some come with 0-0.05mm head clearance.
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 04-17-2008, 11:05 AM   #347
COlt:
You state that you have an aluminum head. Could you provide the engine's part number?
I am about to purchase this engine, and all I see out there is Magnesium heads.
SasonRC is offline   Reply With Quote
Old 04-18-2008, 07:35 AM   #348
colt1402's Avatar
Trader Rating: 90 (100%+)
The engine number on the box is 11387. OS Speed 12tz specII ALU.
*************************Addicted To RC*************************
colt1402 is offline   Reply With Quote
Old 04-18-2008, 11:12 AM   #349
Great, thanks!!
Old 04-22-2008, 02:43 AM   #350
LOSI123's Avatar
Trader Rating: 63 (100%+)
I am buying some bearings from the local bearing shop,
and i was wondering if i should pull of the inside sheild of the front bearing , or just leave both sheilds on the bearing?
as i noticed that it doesnt seem to get lubed from the fuel?
LOSI123 is offline   Reply With Quote
Old 04-22-2008, 04:52 PM   #351
LOSI123's Avatar
i have the 5 port engine with the silver cooling head, Any one here know if the front of the crank case has a lube hole?
as i have just put my motor back together
Old 04-23-2008, 07:51 AM   #352
Rick Vessell's Avatar
Yes it does. The outer shield is there to primarily keep dirt out of the engine, not to seal the crankcase. No need to worry about lubrication of the front bearing.
Rick Vessell is offline   Reply With Quote
Old 04-23-2008, 07:44 PM   #353
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
does anyone have the part number for the spec II aluminum head?
madjack is offline   Reply With Quote
Old 04-24-2008, 10:25 AM   #354
Trader Rating: 16 (100%+)
Socko...I've got my 720 ready for your Mugen...are you scare now..?
Question for you....I just got my OS 12 back from modification....what OS plugs were you using @ last year Byron Race? Also, what pipe were you using..? Does Tower still carry the same pipe that you were using..?
R U still running the same Spec II from last year? When are you hitting LHR? Walt and I are getting the 1/8th ready...(actually, he ran last week already and sounds like the track is in very good shape after the long winter break)
Old 04-24-2008, 02:18 PM   #355
Mr. Lo,
I'm not scared of you. You forget that I'm the Ironman at Leisure!
I run the O.S. 1040 pipe. http://www3.towerhobbies.com/cgi-bin...&I=LXKBH1&P=SM
I run either the #7 or #8 plug. #8 if it's a long track and I want a little more rpm.
Yep, still running the same engine from last year. I'm probably going to Cincy next week for MWS but after that I want to come up and run at LH.
Old 04-24-2008, 03:28 PM   #356
Mr. Lo,
Yeah...you are scare, because you are running MUGEN...
Anyhow, thanks for the info....good luck @ Hamilton, let me know how good (or bad) is....hopefully it is not a tire eater track like other said.
When you are back, I think we can setup a Sunday race @ LHR.
Old 05-25-2008, 10:13 PM   #357
Chickentrader's Avatar
I need to re-sleeve an O.S. TZ(P) T5, and the new sleeve is too tight to fit push into the cylinder?? I tried to force it at first, but it just jammed and got stuck, it only came off when I heated it with a heat gun. I have since tried freezing the sleeve and heating the cylinder to normal operating temp for the engine, but it will only push down about 10 millimetres before getting stuck. Has anyone else had this kind of problem, and is there a solution? The new piston seems to fit well into the head; moves freely to about half ways up the cylinder before getting too tight. The old sleeve was also stuck, but popped out when I put a zip thigh in the exhaust port, and pushed it out with the piston.
Kindest regards,
Lars.
Chickentrader is offline   Reply With Quote
Old 05-27-2008, 08:55 PM   #358
What the differents between the 11385 and the 11387?
Thanks,
Joe
Joe Maxey is online now   Reply With Quote
Old 05-27-2008, 09:26 PM   #359
Ed Anderson's Avatar
Trader Rating: 26 (100%+)
About 16 grams.
11385 = speed specII (Magnesium head)
11387 = speed specII AL (Aluminum head)
Ed Anderson is offline   Reply With Quote
Old 05-28-2008, 10:42 AM   #360
jameslow's Avatar
Default Shim question!
What are the numbers of shim i need to use when i using 16% fuel for these engine?
.12 TZ t3/t5 = ?
.12 TZ speed tuned = ?
.12 TZ spec II = ?
Thanks!
Waiting!
jameslow is offline   Reply With Quote
OS Speed 12TZ (P) T3 Speed Tuned Engine SpeedyDad R/C Items: For Sale/Trade 6 03-02-2009 04:49 PM
GRP tuned 21 vs OS speed 21 big_klemo Nitro Off-Road 10 08-11-2008 08:50 PM
O.S. .12 TZ(P)-T3 Speed Tuned NIB!! occ Australia For Sale/Trade 2 10-14-2006 11:21 PM
