Old 04-03-2008, 10:30 PM   #331
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
spec 2 shimming question:
how many shim's would you recommend using for 30% fuel?
madjack is offline   Reply With Quote
Old 04-04-2008, 11:53 AM   #332
Rick Vessell's Avatar
Add the extra shim that comes with it. That will work for 30%
Rick Vessell is offline   Reply With Quote
Old 04-09-2008, 01:37 PM   #333
madjack's Avatar
has anyone experienced run-on with the spec 2 mag head motor? (motor runs on at refueling, but does not starve on the bottom end off the corner?)
Old 04-09-2008, 02:30 PM   #334
Try leaning the low speed more, it could be too rich. How does the plug look after a 5 min run?
Old 04-09-2008, 03:54 PM   #335
madjack's Avatar
plug looks good, I tried leaning the low speed more, but it only increases the run-on? (was wondering if it may be a function of the magnesium head?)
Old 04-10-2008, 07:58 AM   #336
The head does raise the temp a little due to reduced heat dissipation but if you stay on top of the tune it's not a problem. Try lowering the idle, check the clutch too. If you're running a grey clutch shoe and a small gap the clutch could be dragging due to the shoe heating up and swelling. You may just be too lean on the low speed too so try that first.
Old 04-14-2008, 01:16 AM   #337
FF25510's Avatar
hi all,
my Spec II only came with .3 shimming (no extra) should i remove .1 when running 20% fuel
thanks all
FF25510 is offline   Reply With Quote
Old 04-14-2008, 12:01 PM   #338
Yes.
Old 04-16-2008, 07:05 AM   #339
colt1402's Avatar
Trader Rating: 90 (100%+)
Hi to all, I bought the OS SPEED t1040 SC pipe set for my coming Speed 12tz SpecII ALU. I really looking forward using it on my NT-1. Hopefully i will be a new happy owner of the Speed range engine, this is my first OS 12 size engine...
Is there any more advise from you guys on the speed engine? In my country, many OS racers use the inexpensive Sage pipe(Taiwan pipe), the one have a ring on the stinger just like a Jammin pipe. Any comments?
*************************Addicted To RC*************************
colt1402 is offline   Reply With Quote
Old 04-16-2008, 08:28 AM   #340
NitroWD's Avatar
that sage pipe is good for small medium track and is of a softer material...
for OS can try skyline pipe.
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 04-16-2008, 08:39 AM   #341
colt1402's Avatar
Thanks for teh info. But i heard skyline pipe will make the engine run hotter esp in my country hot weather. Am i right to bought the OS speed 1040 pipe?
Old 04-16-2008, 11:05 AM   #342
JayL's Avatar
the os pipe is nice but it is also soft. I prefer the skyline vr12plus. I run in very hot weather 100+F with 140+F track temps
JayL is offline   Reply With Quote
Old 04-17-2008, 08:05 AM   #343
colt1402's Avatar
Finally, received my OS speed spec2 ALU... Need advise from you guys, the engine combustion head with 1 x 0.2 and 2 x 0.1 head shims total of 0.4mm. I intending to run with 25% fuel. Should i leave the head shims alone or remove a 0.1 from it?? Pls kindly advise...
Old 04-17-2008, 08:29 AM   #344
NitroWD's Avatar
i believe the OS comes shimmed for 30%...
in yr case, leave it alone for 25%.
to be sure, u gotta check the actual head clearance. 0.5mm needed for 25%.
Old 04-17-2008, 08:37 AM   #345
colt1402's Avatar
But fro now is 0.4 head shims total. Meaning i need to buy a 0.1shim to put it total of 0.5shims on running 25%?
OS Speed 12TZ (P) T3 Speed Tuned Engine SpeedyDad R/C Items: For Sale/Trade 6 03-02-2009 04:49 PM
GRP tuned 21 vs OS speed 21 big_klemo Nitro Off-Road 10 08-11-2008 08:50 PM
O.S. .12 TZ(P)-T3 Speed Tuned NIB!! occ Australia For Sale/Trade 2 10-14-2006 11:21 PM
