Old 02-04-2008, 02:51 AM   #301
Rico890's Avatar
Hi all,
Just want to know if the O.S. T1040 52 exhaust is EFRA legal, and what is the EFRA number?
Or what exhaust will work best for the O.S. speed tuned 12 tz spec 2 that is EFRA legal?
Thanks.
Rico890 is offline   Reply With Quote
Old 02-07-2008, 05:27 PM   #302
dameetz's Avatar
Originally Posted by Rico890 View Post
Hi all,
Thanks.
I m using Sirio pipe 2611 with good result and i think it is efra legal.
dameetz is offline   Reply With Quote
Old 02-12-2008, 11:22 AM   #303
Hi,
I would like to know if Charge or Sage exhaust goes well with a TZ 5P?
Thanks.
epsilon is offline   Reply With Quote
Old 02-12-2008, 01:27 PM   #304
Default os speed spec2
Originally Posted by epsilon View Post
Hi,
Thanks.
i'm just done with the break in procedure for my os speed spec2, and my first impression after that are really great.the engine is compined with the 2611 efra novarossi pipe.i had 7 min run time , 66c maximum temperature and really really great bottom and top speed.on sunday i'll have my first race with the os speed so i'll let you know more...
nickiphorosn is offline   Reply With Quote
Old 02-12-2008, 06:50 PM   #305
dameetz's Avatar
Hi,
Thanks.
The Sage pipe does go well with the TZ5. Mine is 6mm with reinforced stinger. I can get around 5min 30sec with this pipe and the power is good.
Old 02-13-2008, 02:46 AM   #306
Hi,
I just got myself a TZ 5P and about to do the break in.
Do i need to install any extra copper shim durin break in?
WHat % of fuel is suitable? I have got a 3/4 bottle of 20% from friend, can I use that?
Thanks.
Old 02-13-2008, 07:16 AM   #307
dameetz's Avatar
Hi,
Thanks.
No you don't need to add any copper shim if you are using fuel not more than 30%. I m using Tornado 25% with good result. As for your 3/4 bottle of 20% fuel just make sure it is still in good condition (fresh).
Old 02-13-2008, 09:43 AM   #308
thanks for the advice..
Old 02-17-2008, 11:07 AM   #309
Hi,
What is the different between OS T1040SC L52 Pipe and OS T1040 L52 Pipe.
Thanks.
Old 02-28-2008, 04:49 AM   #310
hi guys,
i recently got a pre owned OS.12TZ, it is still tight when in TDC, he used to run 16% fuel. Yesterday i started it up, i noticed that it will still be tight without the plug. Is that normal?
another thing is when in TDC the crank will have some play from the conrod.. is it normal? WIll it be the same if i change the conrod?
sorry if these are rookie questions. i read the whole tread, i know they are tight engine but was a bit concerned.
thanks in advance,
warren.
warrenf is offline   Reply With Quote
Old 02-28-2008, 04:01 PM   #311
Trader Rating: 13 (93%+)
Originally Posted by warrenf View Post
hi guys,
thanks in advance,
warren.
Hi Warren it is normal for the tight pinch with os tz engines. I used to run them a nd they take forever to break in. Find out how many litres its hard and if its been pinched or sleeve resized.
Depending on the amount of play it would be a good idea to change the rod. The os conrod is ony cheap anyway. I would replace the rod after 4 litre son the os engines, save the rod for the next engine break in and then discard it.
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 02-28-2008, 04:28 PM   #312
Team Kamikaze's Avatar
Hi,
Thanks.
The OS T1040SC L52 Pipe = The "SC" stands for "Spring Connect" which means it uses springs to attach the Tuned Pipe to the Header, also known as a 1 piece pipe, whereas the OS T1040 L52 Pipe still uses the old fashioned silicone coupling and nylon tie to attach to the manifold.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 03-01-2008, 10:40 PM   #313
i've recently used my spec 2 with novarossi 2630 pipe..the resaults at the begining were awesome as i had posted...7 min run time and 66 celsius...that was after i had finished brake in the engine..at the race i got into my first pit stop at 6:15 min,but as the time passed by i ended getting into the pits every 4 minutes....why that happened?i use 16% nitro fuel and i have not take off any of the head shims since i bought it..do you thing if i increase compression by taking off one head shim and readjust the carburater settings should fix the problem?or shoyld i try the 1040 os max pipe?what's your opinion gyus?...fortunately i won that race but i don't think i'm gonna win again if i enter the pits every 4 minutes...by the way the engine run perfect..the only problem is the fuel consumption
Old 03-02-2008, 09:18 PM   #314
CraigM's Avatar
Trader Rating: 34 (100%+)
odd that you were getting that runtime and temp with the 2630. Most people complain that it makes the engine hot and have poor runtime. The 1040 will definitely improve consuption, I think it's a much better pipe all around for the engine compared to the nova
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 03-02-2008, 09:26 PM   #315
As the engine starts to run in it will start to get richer which is propably why you were coming in for fuel sooner
OS Speed 12TZ (P) T3 Speed Tuned Engine SpeedyDad R/C Items: For Sale/Trade 6 03-02-2009 04:49 PM
GRP tuned 21 vs OS speed 21 big_klemo Nitro Off-Road 10 08-11-2008 08:50 PM
O.S. .12 TZ(P)-T3 Speed Tuned NIB!! occ Australia For Sale/Trade 2 10-14-2006 11:21 PM
