Old 05-17-2007, 10:20 PM   #181
Trader Rating: 13 (93%+)
Thomas i have to disagree with you here..
ive tried a few pipes with my rrr / tz combo and foune the mugen seiki efra 2501 pipe to work best overall.
the skyline pipe was next best but i sold this to try the novarossi efra fatboy pipe u talk of.
the novarossi pipe firstly does not seal too well on the tz engines and really efffects the engines run time. at our nsw state titles i couldnt not finish a 5min race and any leaner the engine would just bog.
last time i went out to moorebank using the same car setup but with mugen pipe i was finishing the 5 min race with just over a capful of fuel in the tank. the engine ran cooler and crazy power bottom end and top end.
it would shoot out of corners!
that was on my tz 3 with 5 port modified crankshaft. it also makes my mspeed tz come to life. i did not like the novarossi pipe/medium header.
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 05-17-2007, 10:21 PM   #182
im picking up 2 x tz speed engines tomorrow from rc hobbies
ill be using these in the aus titles
i dont really wanna use the new spec II
im sure it will be fast but i know the original spped is super fast!
Old 05-20-2007, 06:34 PM   #183
V1-RRR-WC's Avatar
I placed an OS Speed Tuned Crank into my 5Port TZ expecting a performance increase, to my surprise the engine seemed not to be as powerful or hit as hi rpm's as it did before.
Why would this be? Should this not have provided a performance increase?
Your comments please.
V1-RRR-WC is offline   Reply With Quote
Old 05-21-2007, 09:18 PM   #184
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Originally Posted by bvoltz
Yes, but I was not able to race it... of all the parts I have, I did not have any Spur gears... and the second gear is not compatable with the RRR... but First gear is... They kept on me about the gear mess, and I set by pinching the motor into the gears, and they taking 2 laps for it to wear in, to the prefect mess... My friends got me to try to set it before I took it out on the track.... oops....
My fault... I had to park the NT1, and it was faster... and go back to my trusty RRR...
While I was running it, I got about 7 to 7 1/2 mins. compared to the Skyline, which I get just at 5 mins out of it. And the motor ran 40 degrees cooler... with the OS pipe...
I have the Carlsen OS TZ. You think I'd also get better by going with this OS pipe? Any performance changes or are they about the same? I do notice my motor getting pretty crappy mileage...that even my 8th onroad beats! I'm guessing it's also around the 4-5min range as I always seem to gas up more than others. The engine has the 5.4mm black insert.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 05-21-2007, 10:57 PM   #185
jeff1's Avatar
guys
anyone here tried ceramic bearing on this engine? I need to replace mine.. they're very bad, lots of play and leaky. its worth or not?
jeff1 is offline   Reply With Quote
Old 05-24-2007, 07:22 PM   #186
i have the os 5 port and want to know how many shims should i be running under the head if i'm using 30% nitro, there is all ready one .2mm shim under their i guess that came from factory?
bosfan is offline   Reply With Quote
Old 05-25-2007, 09:08 PM   #187
Is Josh Cyrul's break in procedure good for this engine?? Curious..
DaNNy671 is offline   Reply With Quote
Old 05-27-2007, 07:44 PM   #188
bvoltz's Avatar
Trader Rating: 44 (100%+)
I think the OS pipe will be better, I have notied a 40 degree temp change, cooler, which means I can lean the motor down and get more time on a tank of fuel. I'm getting 7 to 7.5 mins....
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 05-27-2007, 07:46 PM   #189
bvoltz's Avatar
Here ya go...
1. Based on head clearance, choose your nitro %:
16% Nitro .36mm - .40mm
20% Nitro .40mm - .50mm
25% Nitro .50mm - .60mm
30% Nitro .60mm - .65mm
Old 05-27-2007, 07:49 PM   #190
bvoltz's Avatar
Yes... I use it all the time.... But I would say it is more important to stay in the temp range of 200 to 220 while breaking in your motor.... it is not good to run it cooler or hotter during break in....
Old 05-27-2007, 09:15 PM   #191
Thanks for your advise bvoltz...
According to Josh Cyrul, he doesn't even monitor the temps of the engine he breaks in. Now I know he's a pro and has a ear and experience for this but I guess everyone has their ways of breaking in...Anyone else use Josh's break in procedure on this engine? If so, do you just follow it to the "T" or do you all modify it to your liking and experience with this engine...
Thanks in advance
Old 05-27-2007, 09:20 PM   #192
HarKonnenD's Avatar
Thanks Bvoltz I'll give it a try.
Old 05-27-2007, 10:25 PM   #193
Here ya go...
thanks
Old 05-28-2007, 04:39 PM   #194
bvoltz's Avatar
Thanks in advance
Modified... when you get the to 4th tank, I hold it for 2 seconds off for 1 second... monitoring the temp the whole time.... I give it a break about every 5 mins.. I do not turn it off, I just slow down the RPM to drop the heat and then back at it. I believe that make changes in the temp range, the temp, this helps the piston break in to the wall of the sleve. Remember, no matter how much you think they are round they are not, so I'm trying to match the piston to the sleve.
Old 05-28-2007, 04:39 PM   #195
bvoltz's Avatar
Anyone know of a place to get this new motor in the US?
OS Speed 12TZ (P) T3 Speed Tuned Engine SpeedyDad R/C Items: For Sale/Trade 6 03-02-2009 04:49 PM
GRP tuned 21 vs OS speed 21 big_klemo Nitro Off-Road 10 08-11-2008 08:50 PM
O.S. .12 TZ(P)-T3 Speed Tuned NIB!! occ Australia For Sale/Trade 2 10-14-2006 11:21 PM
