Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
Zeppin Racing 12TZ3 Dark Force Ceramic Sneak Preview >
Old 08-24-2006, 09:36 AM
  #31
rskoncepts's Avatar
Trader Rating: 37 (100%+)
Still running a little rich and getting stronger. I'm really happy with the workmanship and power. I hear they're working on new stuff too. Can't wait to see what's next. Can't go wrong with the Zeppin!
rskoncepts is offline
Old 08-24-2006, 11:28 AM
  #32
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Are you making the five minutes mark per tank??
How much fuel do you have left?
OVA is offline
Old 08-24-2006, 11:57 AM
  #33
I make the 5min marker with mine and have a splash of fuel left, but I slapped a CD3 tank in my car and now can get close to 6 min
Cheers,
Scoobs is offline
Old 09-05-2006, 10:59 AM
  #34
griz11's Avatar
Default OS 18 is stout
I put an EB mod 18 tz in my pro mod dragster. This is a .21 class but I'm thinking the .21 has too much power for the weight so I went to an .18. I broke it in 3 10 minute periods just like the instructions said. Kinda worried me because I like to get a half gallon of fuel through an engine before I run it at the strip. It took 2nd place its first race. If I hadn't been hacked severely in the previous round I would have taken the win. The car started out at 2.41 seconds and by the end of the day had worked down to a 2.20 second ET at 58 mph for the 132 ft strip. No blown plugs running on 25% where the rest were running 55%. Took the motor apart as I always do after a race and there was no deposits or anything inside. Everything looked brand new. I didn't touch the needles all day only adjusted on the pipe length and clutch. It does the 6 ft in .347 seconds. Very comparable to my .21 powered rail. This motor has plenty of grunt and top end. I've been using Novarossi but I'm switching over to OS. Just bought a .12 TZ for my sprint car. Get some corrosion-x and use that for afterrun. You'll be amazed at how free it makes the crank bearings. Clean them up with B-12 chemtool to get all the gum out then spray with corrosion-x. Spin the crank before and after and you'll see the difference. Doesn't eat o-rings or do any damage. Their speed-x product is great for 1-way bearings. Its really for skateboard wheels but its the best 1-way lube I've found.
Griz
griz11 is offline
Old 09-05-2006, 01:17 PM
  #35
ProE's Avatar
Just funnished the running in of my zeppin 3port tz.
Does any one know what the recommended running temp. is for this engin?
ProE is offline
Old 09-05-2006, 11:23 PM
  #36
rskoncepts's Avatar
Running a little rich left me with more than a few drops left in the tank. Maybe about a 5:30 motor. This was on a wide open layout for our track. Motor never went over 220 after leaning it a little bit more. Top needle is a little below 2 turns out. Maybe about 1 11/12. Had to adjust my clutch between heats because it started to spin the tires coming out of the turns.
Old 10-06-2006, 12:17 PM
  #37
gtrmx's Avatar
The engine is not available at rc-mushroom anymore.
Anyone kept pictures of the modified pieces that mushroom had displayed?
gtrmx is offline
Old 10-06-2006, 12:26 PM
  #38
afm
afm's Avatar
Yo las tengo, donde te las envio
AFM
Lima-Peru
afm is offline
Old 10-09-2006, 11:45 AM
  #39
Thumbs up About Zeppin racing 12TZ3... GR racing
AFM
Lima-Peru
Dear, Sirs.
It is tuning engine of Korea's GR racing.
Hong-Kong is our agency.
Contact: [email protected]
web: www.grracing.co.kr
Thank you.
Chris Kim is offline
Old 10-09-2006, 06:45 PM
  #40
mugenb46's Avatar
can anyone post pics of just this motor
mugenb46 is offline
Old 10-09-2006, 07:13 PM
  #41
afm
afm's Avatar
The Zeppin is made by Gr racing in Korea, somebody posted this link in the G4 thread showing his engine...go here
http://pds11.cafe.daum.net/download....d&dncnt=N&.JPG
AFM
afm is offline
Old 10-09-2006, 10:00 PM
  #42
Trader Rating: 15 (94%+)
wow thats a lot of cuts in the back of te crankshaft
are they all required ??
mrgsr is offline
Old 10-10-2006, 10:21 AM
  #43
That Crank is Mad
Nick Simpson is offline
Old 10-10-2006, 04:06 PM
  #44
Default please reply to pm
Originally Posted by Chris Kim
Dear, Sirs.
Thank you.
hey Chris can you please reply to you pm i wnat to buy the os tr crankshaft from your website. Thank you
mrgsr is offline
Old 10-10-2006, 09:46 PM
  #45
SOLOARTIST 702's Avatar
Default hmm
wonder if it makes time
SOLOARTIST 702 is offline
