Old 05-13-2006, 09:23 AM   #1
TRFTIM's Avatar
Default Carburettor help please
I have a Rossi Pixy engine .12 and seem to have 4 needle settings on it.
The needle that is pointing to the sky is the High end setting
The other 3 not too sure
I have one that is on the end of the slide Carb, one that is opposite to that and one next to that.
I seem to of got the motor running alright its just a bit of a pain not knowing what they do.
TRFTIM is offline   Reply With Quote
Old 05-15-2006, 04:08 AM   #2
itchy b's Avatar
the one on the end of the slide carb is you low speed needle.
the one that is on the opposite end of the carb is the mid range needle that adjusts the spray bar for mid rev range, which is'nt normaly touched, olny for expert tuners adjust this one, its factory set.
the small screw next to this one is your idle screw.
hope that helps you out,
happy racing
cheers
joe
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Smaller venturi carburettor TRFTIM Onroad Nitro Engine Zone 11 04-27-2006 07:42 PM
