Old 08-24-2007, 03:16 AM   #1426
GREGORY!'s Avatar
Any help guys?
GREGORY! is offline   Reply With Quote
Old 08-26-2007, 01:28 PM   #1427
Hi, i have the 2006 version of this engine, i understand it has had the carb update.
I use 16% tornado fuel, with No.6 std plug and the silver (0.1mm?) head shim removed.
I have been having trouble with my engine since new, and its had 5 litres of fuel ran through it.
I think i may have an air leak in the carb somewhere. When i'm on the track and back off for corners or pit stop the engine revs rise, and it sometimes screams. but if i let it try to idel it dies after 2-3 seconds, so i have to keep reving it.
Please could someone advise what is best to do. Shall i change all of the o-rings in the carb? Do you get all of them in the o-ring set (ORI81325)?
does this include the ring that seals the carb to the crank case?
i have the needles at factory settings with the man needle leaned slightly to run good on the straights.
please help.
Matt
PS. Nano, thanks for all of your help in the thread. Great job. And i know these engine are great from what the people are running in the nationals, i just cant wait to get mine running like that.
mjthompson is offline   Reply With Quote
Old 08-26-2007, 01:43 PM   #1428
AddictedToRacin's Avatar
Sounds too lean on the bottom end.
You have to be very careful beacuse sometimes the engine seems to be to rich and is too lean. Try to open the needle one turn and fine-tune it from this point.
AddictedToRacin is offline   Reply With Quote
Old 08-26-2007, 01:49 PM   #1429
thanks, so it doesn't sound like an air leak then?
i wasn't thinking it was too lean. (im probably wrong), because it seems to take along time to clear its self and when it does it spurts out smokes a lot.
so is the factroy setting usaully too lean on the bottom?
thanks people.
Matt
Old 08-26-2007, 02:44 PM   #1430
rmdhawaii's Avatar
please help.
Matt
When your engine revs like that when it's off throttle, this works really well:
http://www.rctech.net/forum/showthre...91#post3185991
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 08-27-2007, 05:50 AM   #1431
Thanks everyone, ill give that a go.
am i wrong in thinking that if you set the low spped needle first, that you will inevitably (sp?) change it when you adjust the high speed needle?
I'm using my engine in a Serpent 720, with 2647 pipe with high torge manifold and an orion clutch conversion for the serpent centax 3.
Does anyone have a good clutch set-up for this version? what gearing do you use in the 720?
Cheers
Matt
Old 08-27-2007, 08:59 AM   #1432
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Have they made a Wasp clutch set for the X-ray NT1?
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 08-28-2007, 12:31 AM   #1433
Nano's Avatar
Mj, if your clutch setting is right, you should barely have to touch the low speed setting from the factory setting. Our basic principle is that if you have to go way off the factory carb settings then something is wrong. Usually the engine only requires a little leaning on the high speed needle and almost nothing on the low speed. If the engine is used/maintained properly you usually don't get air leaks from the carburator.
No special clutch set for the NT1 yet.
Nano is offline   Reply With Quote
Old 08-28-2007, 12:52 AM   #1434
rmdhawaii's Avatar
Does this mean Team Orion is going to make one for the NT1 or is the yellow NT1 shoe good enough for now? How does it compare to the CRF shoe?
Old 08-28-2007, 04:35 AM   #1435
B4
B4's Avatar
Make sure you are not compensating for a bottom end that is to rich by having the idle speed set to high. Remember make small adjustments only.
please help.
Matt
B4 is offline   Reply With Quote
Old 08-28-2007, 08:33 PM   #1436
rmdhawaii's Avatar
This is an interesting idea. I wonder how well it works...
CRF 88925 Manifold Spacer (1mm/2mm/3mm)
Enables length of exhaust to be adjusted in 1mm increments, without changing the manifold or muffler.
Old 08-29-2007, 11:17 AM   #1437
Nano, thanks for the response. (and everyone else)
i have the idle the lowest i can go without it dying, but it still revs crazily when i back off.
i have set it on the bench so it maintains a steady idle but am yet to try it on the track, i think it will be too rich on the bottom.
does my clutch need to be tighened, or take one screw out each fly weight?
do i measure preload by measuing how much thread is revealed above the spring tensioner?
does 2mm preload sound too much on the centax III? or is 0.5 clutch gap too small?
Am i right in removing the silver head shim? should i take out the copper one and put the silver one back in? I'm in the United Kindom.
Old 08-30-2007, 01:12 AM   #1438
Hi Matt
It sounds to me that your bottom end is too lean. A couple of us who run this engine at Nationals had this problem. The solution is to richen up the bottom end. However you must remember that the engine has to be fully warmed up before bothering with tuning it. I've found that It needs a good couple of minutes on the track (sometimes longer) before it's properly warmed up. My engine wont tick over until it's up to temparature, so setting the idle when it's cold will give you an engine that revs too high when it's warm. Once it's warm it will idle fine.
I'm happy to help you tune it at Wrexham on Saturday if you like.
pitbits is offline   Reply With Quote
Old 08-30-2007, 12:45 PM   #1439
thanks pitbits
Old 08-31-2007, 02:46 AM   #1440
Nano's Avatar
There's always a lot of testing going on with clutch systems at CRF. However it takes a lot of testing and experience with a particular clutch to make something that works properly. For the moment nothing is planned for the NT1.
Team Orion Wasp REV Nicolas Onroad Nitro Engine Zone 183 10-05-2006 09:04 AM
team orion wasp rev MAVICXXX Malaysian R/C Racers 31 09-19-2006 09:18 PM
Team Orion - Wasp!! BundyMan Onroad Nitro Engine Zone 1 03-03-2006 03:10 AM
Orion Element 19t Dyno results rinkrat99 Electric On-Road 7 10-09-2005 07:29 PM
Team Orion Wasp .12 HaLo_UsMc R/C Items: For Sale/Trade 6 03-16-2005 07:31 PM
