Old 08-13-2007, 01:11 PM   #1411
How far should piston go through cylinder?
Engine had serious problems this past weekend, flames out as soon as it gets enough hot, usually after 6-8 minutes.
JanisK is offline   Reply With Quote
Old 08-13-2007, 06:15 PM   #1412
rmdhawaii's Avatar
- When exactly is it flaming out on you? Are you stopped, on-throttle or off-throttle?
- What is the engine temp after 6-8 minutes?
- What fuel, head clearance and plug are you running?
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 08-14-2007, 12:13 AM   #1413
-It flames out off throttle
-Temperature is around 120C
- 16% Power save racing fuel (11% oil) is used, standart head shimm (i guess its 0.1mm), and Orion plug Nr.6.
That whas quite a hot day, ambient temp around 30C
To add, motor had very nice idl when its cool but after few minutes of driving, it just wont idl at all
Old 08-15-2007, 08:55 AM   #1414
Mike Schumacher's Avatar
Trader Rating: 36 (100%+)
Peak CRF and Orion CRF are 100% the same (except the head color and logo)?
What thickness of shim I should add if running 30%?
Mike Schumacher is offline   Reply With Quote
Old 08-15-2007, 07:04 PM   #1415
Rawz's Avatar
Mike, I have a Orion CRF, and two friends here have a Peak CRF.
They look like the same!
Guys, can some one answer this:
The Team Orion CNC Back Plate, Team Orion CNC Combustion Chamber and Team Orion CNC Big Carburator Inlet can be used in the Original, the first release Orion CRF ? (specially the inlet).
That inlet is race legal ? (IFMAR)
Rawz is offline   Reply With Quote
Old 08-15-2007, 07:30 PM   #1416
rmdhawaii's Avatar
After a few minutes of driving, the car should idle quite nicely. Try resetting all your needles to the factory settings, try adjusting your idle using the Bobby Watson method (click here) and then retune your HSN.
If you have one of the newer CRFs, the factory settings are posted here, otherwise, check the manual.
Hope this helps.
Old 08-15-2007, 07:33 PM   #1417
rmdhawaii's Avatar
Those parts will fit on the original CRF. I have no idea if it is IFMAR race legal or not.
Old 08-15-2007, 08:46 PM   #1418
Z00M's Avatar
Trader Rating: 15 (100%+)
The inlet is legal, Josh used it at the worlds. It still tapers down to 5.5mm which is the requirement.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 08-15-2007, 09:03 PM   #1419
Rawz's Avatar
Ok, thankx guys.
I guess I will get those, to see what is the effect. Still cant find where to get the new carb. Will try another e-mail to Orion.
Old 08-15-2007, 09:16 PM   #1420
rmdhawaii's Avatar
Ok, thankx guys.
Calling is usually best.
Old 08-22-2007, 08:25 AM   #1421
rmdhawaii's Avatar
With all the changes to the engine, it would be nice to see a new dyno graph.
Old 08-23-2007, 08:29 AM   #1422
Nano's Avatar
Janis with CRF technology, the piston goes through the cylinder even when new. You can take a new piston and liner and insert the piston from the top.
I think that if it's flaming out when warm it means that you have an air leak that only appears when the engine is warm. Check the backplate o-ring.
Nano
Nano is offline   Reply With Quote
Old 08-23-2007, 08:36 AM   #1423
GREGORY!'s Avatar
Default CRF
GREGORY! is online now   Reply With Quote
Old 08-23-2007, 08:39 AM   #1424
GREGORY!'s Avatar
Default CRF
Hi!today i disassempled my 2 carbyrator from my engine.the update and the stock one.now i have tangle the two spray nozle.the one has 1.7 mm littles holes and the other has 1.5mm.can someone tell me which is the update and which is the old?
Old 08-23-2007, 08:48 AM   #1425
GREGORY!'s Avatar
sorry double post!
Team Orion Wasp REV Nicolas Onroad Nitro Engine Zone 183 10-05-2006 09:04 AM
team orion wasp rev MAVICXXX Malaysian R/C Racers 31 09-19-2006 09:18 PM
Team Orion - Wasp!! BundyMan Onroad Nitro Engine Zone 1 03-03-2006 03:10 AM
Orion Element 19t Dyno results rinkrat99 Electric On-Road 7 10-09-2005 07:29 PM
Team Orion Wasp .12 HaLo_UsMc R/C Items: For Sale/Trade 6 03-16-2005 07:31 PM
