Old 06-07-2007, 05:28 AM   #1246
Originally Posted by kmaheartless View Post
Janisk - Hey thanks for the advice! But how do you determine which gear ratio works best for the crf? Is there a math formula that you can share? Do you mean the 1.8mm yellow spring? I dont think they have a black one.
K-Factory Push type Clutch Spring (1.8mm Black,Harder less coils) k1497-14 and K-Factory UFO Push Type Clutch Shoes RED k1497-6
Yellow spring is ~9,8mm
Crf clutch spring (ORI88680) is ~8.1mm
I found crf clutch spring to be a bit softer than k-factory black spring, and bit harder than yellow spring
About gear Ratio - no, i dont have any specific math formul, i simply us what seems to give the best performance, in case of CRF, thats quite low ratio (7.2 for 1st and ~5.2 for 2nd gear)
JanisK is offline   Reply With Quote
Old 06-07-2007, 03:18 PM   #1247
GREGORY!'s Avatar
Originally Posted by Nano View Post
Hi, no worries, everything sounds normal. As long as you have the conical carburator insert fitted on the carburator (old 2006 has cup shaped carburator insert), then it means you have the right engine.
Where did you buy the engine from?^^
Finaly my engine is the old one...i buy it from greece,from http://www.rchobbyathens.com/.thanks for the help anyway Nano!
GREGORY! is offline   Reply With Quote
Old 06-07-2007, 03:19 PM   #1248
GREGORY!'s Avatar
"p
Old 06-07-2007, 03:27 PM   #1249
GREGORY!'s Avatar
Old 06-07-2007, 06:53 PM   #1250
uniquexme's Avatar
Send a message via MSN to uniquexme Send a message via Yahoo to uniquexme Send a message via Skype™ to uniquexme
I m running ED system with 16/21 fitted, and 52/47. i think i might try to change to the KF black spring and red cluth shoe, do u think its neccessary to oso change to the red centrifugal shoes?
uniquexme is offline   Reply With Quote
Old 06-07-2007, 08:42 PM   #1251
Z00M's Avatar
Trader Rating: 15 (100%+)
I have found running the 16/20 with the 52/47 to be the best combo for our track with the CRF in the G4S. I run the orion clutch update parts for the UFO clutch. I have also run the standard clutch parts with the black spring and standard shoes with 1 weight removed from the flyweights. Keep the clutch gap low (around .4) and then just tune the spring preload.
As arr see car said, we had a good result with the Orion engines at our recent state titles. I must confess I even ran the whole weekend with a piston and liner set that had eaten a glow plug coil to see what would happen - turns out it still worked fine!! Quite a remarkable engine really. I also used the liner shims and found some good power gains.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 06-07-2007, 10:35 PM   #1252
Hello
These are the screws that I was talking about. They are not fully tightened to the combustion chamber and the crankcase and it was like this when I received it. This is my first engine from Orion, so I am not sure if I should screw them down or not.
Thanks!
Team Orion CRF Wasp Rev X-Dyno results-cimg3715.jpg   Team Orion CRF Wasp Rev X-Dyno results-cimg3716.jpg   Team Orion CRF Wasp Rev X-Dyno results-cimg3717.jpg
kmaheartless is offline   Reply With Quote
Old 06-07-2007, 10:40 PM   #1253
uniquexme's Avatar
Hello
Thanks!
thats the way it should be, dun worry. haha. dun overtighten it else, hehe, i heard few ppl overtightened their heatsink screw till it snaps, this might damage the crankcase.
Old 06-07-2007, 11:41 PM   #1254
asil's Avatar
Send a message via MSN to asil
Hello
Thanks!
comb.chamber screws are to be tightened to 0.9 Nm in cross pattern and head screws to 1.0 Nm again in cross pattern.. you have to use torque screwdriver..
Asil
asil is offline   Reply With Quote
Old 06-07-2007, 11:50 PM   #1255
uniquexme's Avatar
Asil
heh, can u show us the torque screwdriver? its cool, i wonder how it looks like, can get one oso. haha. thanks.
Old 06-08-2007, 01:07 AM   #1256
asil's Avatar
in fact I don't have one here in Istanbul, one of our friends has got one and it's way too expensive.. something like 250 ... It's like a screwdriver that you may adjust it via turning it's head to the desired torque value.. Torque wrenches which have a range of 40-200 Nm are much more cheaper than this one
Asil
Old 06-08-2007, 03:29 AM   #1257
uniquexme's Avatar
ok than, but is that Euro250?
Old 06-08-2007, 03:39 AM   #1258
asil's Avatar
yes
Asil
Old 06-08-2007, 09:30 AM   #1259
Nano's Avatar
This is an example, it's not the one we use though.
http://www.aircraftspruce.com/catalo...ges/torkit.php
The screws are a little tight but not locked in place, if you lock them then they will be too tight and creates mechanical stresses on the crankcase and screw up the piston/liber alignement.
Nano
Nano is offline   Reply With Quote
Old 06-09-2007, 04:01 AM   #1260
otraver's Avatar
Send a message via MSN to otraver
Hi Nano,
Thank's for the link.
I have find this other.
http://www.wihatools.com/200seri/285serie.htm
What's the recommended force to apply at the button head?
Octavio Traver
otraver is offline   Reply With Quote
Team Orion Wasp REV Nicolas Onroad Nitro Engine Zone 183 10-05-2006 09:04 AM
team orion wasp rev MAVICXXX Malaysian R/C Racers 31 09-19-2006 09:18 PM
Team Orion - Wasp!! BundyMan Onroad Nitro Engine Zone 1 03-03-2006 03:10 AM
Orion Element 19t Dyno results rinkrat99 Electric On-Road 7 10-09-2005 07:29 PM
Team Orion Wasp .12 HaLo_UsMc R/C Items: For Sale/Trade 6 03-16-2005 07:31 PM
