Team Orion CRF Wasp Rev X-Dyno results
#1216
Originally Posted by uniquexme
I tried richen LSN, but lack of power, so i played with slightly higher gear ratio for 1st gear. but still it seems wasp is lacking low end power, BUT long straight is really fast. keke.
The engine does not suffer from low end. It just does not want to rev up from idle at all, after refueling. It takes 2 to 4 seconds to start and then it is like a rocket in the whole band of power, low, middle and high.
Could it be that the tank looses the compression when it is opened and then takes a while to compress again?
#1218
Hi Nano and all,
I also broke in my engine yesterday, 80000 CRF Wasp REV .12 Cyrul Spec. I followed the instruction for the break in. After 4 tanks I started to lean the HSN, I’m very impressed with the top speed. I am using 30% Rocket Science fuel. The car is a Kyosho rrr, I lightened the clutch weights with a 3.5mm drill and set the 1.9mm spring to 1.4mm, with 0.5 mm clutch gap. I have a Skyline VR12 plus. The HSN is 4 turns out, minus one hour. I then started leaning the bottom end, while monitoring the acceleration from a standing start. Also performed the pinch test. I ended up at 47.88mm. I think both of these numbers are close to the recommended value!
OK the questions that I have are:
1) When I start the motor from cold it will not respond to the throttle being opened, in fact it wants to stop. I have to keep the glow igniter on for 10-20 seconds after it has started and try and coax it into life, as it warms up everything is OK, and it responds to the throttle well.
2) Idle is good, and acceleration from a standing start is also good, however if I drive at part throttle it doesn’t hold a constant rpm. I think it is too rich in the mid range, maybe going from a two to a four stroke. When I drive the car at full throttle and immediately bring it to a stop the motor immediately assumes the idling rpm, and this doesn’t change. I think this implies that I have the mixture pretty close. Also when I give the car full throttle it picks up immediately and heads off like a scalded cat. Do I need to consider a different insert in the carb? If so can you give me the part number?
I spoke with Orion USA today and they told me that I should lean the HSN to get the temperature between 250 and 260, and then lean the bottom end. Apparently the reluctance to pick up when cold and also the uneven revs at mid throttle are symptomatic of a rich LSN.
Nano do you agree with this? I asked about a different carb insert, and they said that the Cyrul spec was the correct setup.
I'm still confused
I'm still confused
#1219
About low end, if it's loosing to other engines then your clutch setup is wrong (at least for the CRF engine), yes it screams when the clutch engages.
Nosram, you might actually be too lean on the LSN, open it up one mark or two, one mark can make a big difference. The CRF engine sometimes feels like it's too rich but it's actually too lean. The hesitation in the mid-revs can be also because of a lack of fuel.
Wether it's cold or warm it should rev the same. When you start the engine it can bog a little, but a blip on the throttle will clean it out.
Last but not least the V12 pipe we have never tested, so again this can greatly affect the engines performance.
#1220
Hi Nano,
Any opinion for the problem that I described a few posts above?
I am not so sure that it is a tuning problem, since the engine performed fantastically in all the sections of the track. I had fantastic high end and equivalent with all other modified engines low end power.
Thanks in advance
Thanks in advance
#1221
Originally Posted by etgdpu
Hi Nano,
Thanks in advance
Thanks in advance
Nano
#1222
Thank you Nano! I will try messing with the LSN.
One last question, for now, the guy at Orion said I might have trouble making 5 minutes when running 30% nitro. He said that Josh ran 20% and 17% in the main at the nationals. Any comment on 30% nitro would welcomed. I am running 30% Rocket Science.
#1223
RC_Alan
#1224
Running higher nitro will increase the torque and lower the revs slightly
#1225
Thank you for that info, I have no idea why I was told this information, especially coming from Orion? Actually I was calling to try and get the new carb inlet, I have the 80000 Cyrul spec motor. He claimed that I had the very latest! Reading through these posts I know this is not correct.
What is the part number for the carb insert that I need
#1226
The Josh Cyrul motor (updated 2006 engine) has the same carburator and insert that we sell on all our engines today.
The larger size carburator insert #81358 is an optional part.
Nano
Nano
#1228
Frankie, if you tune CRF and clutch right then it's a rocket!!! unbelieveble high end.. I can not think of it with ED transmission..
Asil
Asil
#1229
CRF
NANO,The Josh Cyrul motor WAS SOLD IN THE PACKAGE WITH PIPE AND CLUTCH PARTS ONLY?WHAT IS HIS CODE?THE MANUAL IS THE SAME WITH THE OLD'S ENGINE?IF I SAY YOU THE THE CODE THAT IS WRITEN UNDER THE ENGINE CAN YOU TELL ME WHAT ENGINE I HAVE?
