Old 05-14-2007, 03:35 AM   #1156
asil's Avatar
Send a message via MSN to asil
I'm using CRF 2007 and so pleased with it.. There are 7 CRF 2007's in my club and we are all happy we never had problem with it..
Asil
asil is offline   Reply With Quote
Old 05-14-2007, 03:40 AM   #1157
johnhsp's Avatar
Trader Rating: 18 (95%+)
Send a message via MSN to johnhsp Send a message via Yahoo to johnhsp Send a message via Skype™ to johnhsp
Asil
ic,so have you change to os cab or just using orion cab,wht pipe u using now,5mm or 6mm,you buy 07 is combo set or just buy engine only
Sanwa M11X With RX451
Xray 808 buggy,Ace DS1015,JP-3 Pipes,VP Pro 803
RB WS7 III,PR21BS(Precirotate),SH PX2009
Power by Rapicon fuel
johnhsp is offline   Reply With Quote
Old 05-14-2007, 03:42 AM   #1158
johnhsp's Avatar
Originally Posted by Nano
Lately we sell the engine (which has the regular combustion chamber) with only 0.1mm shims. The original and conical combustion chambers don't have the same dimensions, so if you use only 0.1mm with the conical chamber bad things could happen.
0.3mm is then minimum when using the conical chamber. I think it should be ok for 16-30% nitro.
Nano
Nano wasp (old version) & 07 version what different,just only cab different,how about Piston,Liner,all same
Old 05-14-2007, 03:51 AM   #1159
Nano's Avatar
Originally Posted by uniquexme
As i drove around, at certain times, esp out of corner, when u want to give it acceleration, it just reluctant to move, u have to pump a few times b4 it moves.
Your clutch is set wrong and probably the carburator settings are off also. It's the nr.1 mistake with racers using this engine, they run the clutch to soft and then complain it has not bottom end, when in fact it should take off the line like a rocket...
What car are you using? pipe?
Nano is offline   Reply With Quote
Old 05-14-2007, 03:56 AM   #1160
Nano's Avatar
The 07 has the same base as 06, only extra work to the crankcase internals and different piston/liner. At the end is has more torque and power throughout the rpm range and more top speed. Carb is the same as updated carb.
Old 05-14-2007, 04:05 AM   #1161
johnhsp's Avatar
i am using TM G4S with 2630 pipes
Old 05-14-2007, 04:42 AM   #1162
asil's Avatar
I use CRF's carb. I've changed nothing.. using Skyline VR12 plus pipe..
all of us drive TM G4S and as Nano says we use hard clutch spring.. clutch adj. is so important..
at every start of race, I enter 1 st curve in the first place.. so bottom end is good..
Asil
Old 05-14-2007, 04:45 AM   #1163
johnhsp's Avatar
Asil
so u didn't using orion pipes,why don't using orion pipes,i hear someone said need using orion pipes.can i know skyline pipes is 5 or 6 mm ,i know wasp low end is good,high end also good,so thinking to buy another wasp (07) again
Old 05-14-2007, 04:26 PM   #1164
Nosram's Avatar
Still Confused
I have just bought a new CRF WASP off eBay. I did this before I read this thread. I suspect that I have the original carb I haven't recieved as yet.
1) How will I be able to identify which model of carb it is?
2) If it is the original, do I then need to get a high speed needle and a complete carb body?
Thank you MRX4-R03 for the OS answers! Have you ever raced at the Golf Coast Raceway in Houston? This is my local track, and I would like to know what gearing to use?
Thank you in advance
Nick Marson
Nosram is offline   Reply With Quote
Old 05-15-2007, 02:05 AM   #1165
asil's Avatar
I use 5mm Skyline and also bought 6mm and will try it on next race..
Asil
Old 05-15-2007, 02:07 AM   #1166
johnhsp's Avatar
Asil
i think i will buy wasp again keep my wasp (old version) for spare hehe
Old 05-15-2007, 02:25 AM   #1167
Nano's Avatar
Originally Posted by Nosram
Still Confused
Hi,
1) If the carb has a "cup" shaped insert it's probably the old version. It it has a conical insert it's probably new.
2) Yes, you can contact Team Orion USA about them.
Nano
Old 05-15-2007, 02:28 AM   #1168
Nano's Avatar
The thing with pipes is that they need to be legal for racing. There is no point for us in using and developping the engine around outlaw pipes.
Right now the best legal pipe is our 2647 pipe with either the short or long header.
Nano
Old 05-15-2007, 02:36 AM   #1169
johnhsp's Avatar
Nano
hope wasp 07 didn't got any problems,since many ppl using it hope loh
Old 05-15-2007, 05:47 AM   #1170
etgdpu's Avatar
Hello all,
Nano, you made me trust you. I bought the engine in the bag with Adrien's signature. I also bought the new turbo button and the fuel splitter. I have the MTX4 and we use 16% nitro. I suppose that the recommended setup is to use the new turbo button with 0.30 spacer, the new carburator insert, orion shoes with all the screws in, orion shoe, orion spring and orion exhaust and manifold. I have seen that you recommend 0.5mm gap and almost 0 end play but I do not know where to start the spring preload (just a good starting point and I will adjust according to the track conditions). I would appreciate if you confirmed that the above set up seems OK and if you advised the spring preload.
The intelligent can become anyone, anyone can not become intelligent.
etgdpu is offline   Reply With Quote
Team Orion Wasp REV Nicolas Onroad Nitro Engine Zone 183 10-05-2006 09:04 AM
team orion wasp rev MAVICXXX Malaysian R/C Racers 31 09-19-2006 09:18 PM
Team Orion - Wasp!! BundyMan Onroad Nitro Engine Zone 1 03-03-2006 03:10 AM
Orion Element 19t Dyno results rinkrat99 Electric On-Road 7 10-09-2005 07:29 PM
Team Orion Wasp .12 HaLo_UsMc R/C Items: For Sale/Trade 6 03-16-2005 07:31 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
