Old 04-19-2007, 04:11 PM   #1081
rmdhawaii's Avatar
Originally Posted by Rawz
Hello.
I am looking for the CFR Clutch conv. kit for a TM G4S, and canīt find where to order. Horizon Hobby says itīs discontinued ????
Can someone tell where to get it, or does it not ship anymore ?
Thankx!
Clutch part numbers are listed on this page:
http://www.teamorion.com/Products/Nitro+Clutches
Best bet is to call Team Orion directly.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 04-20-2007, 01:04 AM   #1082
razzor's Avatar
Hello.
Thankx!
Bud use the red Kfactory clutch shoe and all the weights and 1.8mm black spring or Mugen super hard spring.
Its been a mission to find the G4S clutch sets ,had no luck too.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 04-20-2007, 01:21 AM   #1083
Z00M's Avatar
Trader Rating: 15 (100%+)
I'll see if my guy has any left.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 04-20-2007, 02:10 AM   #1084
ziggy12345's Avatar
Dont you use the RRR clutch for the G4? I thought they were the same
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 04-20-2007, 03:47 AM   #1085
Z00M's Avatar
No they are different. The G4S UFO clutch has it's own kit from ORION.
XRAY XB4
Old 04-20-2007, 05:59 AM   #1086
Is anybody carrying the latest model yet?
CHUCKMANDO is offline   Reply With Quote
Old 04-20-2007, 01:13 PM   #1087
ziggy12345's Avatar
I was at the track today and was tuning up the Murnan CRF for the race on Sunday. I had a bit of trouble with the low end lag and was fiddling with the middle needle. I managed to solve it and the engine is flying.
Is the screw on the end (middle needle) the same as the ones on an old Novarossi engine? It didnt seem like it had the same effect.
Anyway it seem to sort out the engine and the low end lag dissapered
Cheers
Sponsored by:
Norfolk and Chance
Old 04-20-2007, 01:19 PM   #1088
captian's Avatar
any word on the 21 3.5cc engine's
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 04-20-2007, 01:45 PM   #1089
Schrijver99's Avatar
Cheers
Can you post your settings? and did you remove the 0.2mm head shim?
Thx
Schrijver99 is offline   Reply With Quote
Old 04-20-2007, 06:37 PM   #1090
MRX4-R03's Avatar
If your are still having trouble tunning and if you have a o.s. tz carb use it but use it with the orion wasp high speed needle and your engine will start up on every try and no more hassle I figured this out and now all the guys over here using and love it, I am running mine with a nova 6mm insert and getting over 6min run time, running right at 230-245 deg..
Try it and tell me what you think..the problem with the os high speed needle the wasp needs more fuel at top and the os can only put out so much before it starts leaning out and only has 2 holes on it, with the orion has 4 holes and delivers more than enough fuel..
MRX4-R03 is offline   Reply With Quote
Old 04-20-2007, 07:47 PM   #1091
rmdhawaii's Avatar
Is that the new HSN or the original HSN? I am soooooo tempted to try the OS carb on this thing...
Old 04-20-2007, 10:17 PM   #1092
MRX4-R03's Avatar
I am using the new hsn but looking at the older there is really not that much of a difference and I think one of the guys over here that I told is using the older one with no problem,,,
Old 04-21-2007, 06:43 AM   #1093
ziggy12345's Avatar
Thx
only the 0.1mm shim installed with a No 5 plug. LSN is 2 turns out and HSN 4. The middle screw is 3/4 turn out. I am going to take the carb to bits to see what the middle screw does.
Sponsored by:
Norfolk and Chance
Old 04-23-2007, 01:17 AM   #1094
Nano's Avatar
About using the OS carburator, the OS carb might be easier to adjust for you, but it will make the engine slower. If it's still fast enough for you then it's ok, but just be aware that it will hinder the engine's performance.
The trick with our carb is to make tiny adjustments at a time, not 1/2 or 1/4 turns at once. When you are close to the good setting you don't even need to move the needles one mark.
The middle screw (spray nozzle) we use 1.5 turns out from fully screwed in. This setting we always use and never touch. Again if you believe something else works for you that's cool, but we never touch it.
Nano
Nano is offline   Reply With Quote
Old 04-23-2007, 09:54 AM   #1095
MRX4-R03's Avatar
Nano
Hey nano let me ask you, why is the engine so hard to restart after you have ran a tank of fuel, even though the engine is great and not overheating.. And it is just not me other guys I have talked to about it.. Is there a lean spot somewhere, that is the only issue I have with the engine hard start, and the tunning changes after a long main..
Team Orion Wasp REV Nicolas Onroad Nitro Engine Zone 183 10-05-2006 09:04 AM
team orion wasp rev MAVICXXX Malaysian R/C Racers 31 09-19-2006 09:18 PM
Team Orion - Wasp!! BundyMan Onroad Nitro Engine Zone 1 03-03-2006 03:10 AM
Orion Element 19t Dyno results rinkrat99 Electric On-Road 7 10-09-2005 07:29 PM
Team Orion Wasp .12 HaLo_UsMc R/C Items: For Sale/Trade 6 03-16-2005 07:31 PM
