Old 04-09-2007, 09:54 PM   #1066
Chris Young, you have PM.
SNACKPACK is offline   Reply With Quote
Old 04-09-2007, 10:00 PM   #1067
Default 2007 spec. Wasp REV Motors
Hi guy's,
I apologise if this has been answered already, but are the new 2007 spec. motors available yet? If so, where?
Thanks in advance.
Old 04-10-2007, 12:02 AM   #1068
asil's Avatar
Send a message via MSN to asil
Originally Posted by SNACKPACK
Hi guy's,
Thanks in advance.
yep, I used one of them last sunday..
you may find it here;
www.rcteamgo.com
Asil
asil is offline   Reply With Quote
Old 04-10-2007, 08:09 AM   #1069
MRX4-R03's Avatar
If you guys are still have tunnig problems and if you have a o.s. tz put the carb on there and all I gotta say is HOLY S--T the engine is a whole new beast much faster.. Let me know if you guys tried it, I wanna see what you think
MRX4-R03 is offline   Reply With Quote
Old 04-10-2007, 08:17 AM   #1070
asil's Avatar
wow, I've used my 2007 CRF for 8-9 tanks of fuel and it was a rocket.. If you're sure about putting os tz carb. onto it I may give it a try
BTW, we had no tuning issues with the engines. Also our fast guy Ozgur's HSN was 2 turns out at the end of the day.. Maybe Nano may comment on this needle setting.. Temp. was around 110-115 C..
As mentioned before, we realised that it takes time for engine to heat soak.. It's important to wait it to heat up completely before tuning..
Asil
Old 04-10-2007, 11:14 AM   #1071
MRX4-R03's Avatar
the only problem that a couple of guys here are getting, is that after the engine cools it is very hard to start and bogs bad and once it starts it runs perfect,
I my self have the 07 version and the hsn was alittle lean had to richen it up 3 hours and low 1 hour other than that I really had no problems with the newer carb but with the older carb with out the update screw that I never got it right. but with the os carb I did not even touch the settings prior to installing it I just had to rich the top and richen the bottom and did not have a problem at all ran it all day yesturday and started up every time with no problem..Give it a try see what you think
Old 04-10-2007, 11:51 AM   #1072
impalabob64's Avatar
Send a message via AIM to impalabob64
Default OS TZ CARB
Hmm ,i hve 3 CRF,s might hve to try that just to see any difference.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 04-11-2007, 12:06 AM   #1073
asil's Avatar
We realised one more thing, orion glow plug needs much more current than other brands. We also checked needle settings before starting per carb. update insert which was in the manual.
Asil
Old 04-11-2007, 12:33 AM   #1074
MRX4-R03's Avatar
so what, did you do
Old 04-11-2007, 01:16 AM   #1075
asil's Avatar
factory settings were a little out of tune and we adjusted per insert and adjusted glow plug driver to max. setting. A little weak powered starter may start other engines but CRF needs a higher speed for starting..
Asil
Old 04-17-2007, 12:57 PM   #1076
Schrijver99's Avatar
Hi,
can someone give me a good starting setup of the carb for the CRF Cyrul spec on 16% (already have the head shimmed out with only one 0,1 ring) LSN, HSN and spray nozzle?
Orion's settings for the new carb doesn't work fpr me (i think its way to rich)
And also the spray nozzle old spec was a turn out but the new one 1 ???
(with 1 turn out i get it better to work than on 1 out)
Thx
Schrijver99 is offline   Reply With Quote
Old 04-17-2007, 05:54 PM   #1077
Default CRF Region 4 A-main
Well ,Crf made the A-main at Region 4 race at Kraceway ,it put me in 7th starting position ,but sadly didnt get to run the A-main .Got rained out.Also did some gearing testing. Anyone that has this motor in the S720 here is the gearing i highly suggest trying 16/61 22/57 ,tires 59.5 frt 61.5 rear.
RoninRc.com
Basher BT-4
Old 04-18-2007, 02:59 AM   #1078
Nano's Avatar
Originally Posted by Schrijver99
Hi,
Thx
Are you sure you have the new carb? if so the carb insert should be conical vs cup shaped on the old version.
The settings I posted on our website are the settings we use as base settings and they work for us everyday. Obviously you will need to fine tune them but they should be very close. Also these are used along with a good clutch and a pipe that suits the engine.
If you are far off from these I would generally assume that something is not right.
Nano
Nano is offline   Reply With Quote
Old 04-19-2007, 06:10 AM   #1079
Nano
I have the CRF Cyrul spec (with the conical insert)
I'll try again this weekend, and have now used the 47,9 with a fully unscrewed the slide valve stop screw (to get a better measurement)
Old 04-19-2007, 02:46 PM   #1080
Rawz's Avatar
Hello.
I am looking for the CFR Clutch conv. kit for a TM G4S, and cant find where to order. Horizon Hobby says its discontinued ????
Can someone tell where to get it, or does it not ship anymore ?
Thankx!
Rawz is offline   Reply With Quote
Team Orion Wasp REV Nicolas Onroad Nitro Engine Zone 183 10-05-2006 09:04 AM
team orion wasp rev MAVICXXX Malaysian R/C Racers 31 09-19-2006 09:18 PM
Team Orion - Wasp!! BundyMan Onroad Nitro Engine Zone 1 03-03-2006 03:10 AM
Orion Element 19t Dyno results rinkrat99 Electric On-Road 7 10-09-2005 07:29 PM
Team Orion Wasp .12 HaLo_UsMc R/C Items: For Sale/Trade 6 03-16-2005 07:31 PM
