Old 02-22-2007, 09:10 PM   #931
Rawz's Avatar
OK, thankx for the info on that.
Well, I just got the engine.
As I posted, I got from someone that had it unused, in the box.
But, it wasn't sealed on a plastic bag(like other engine I did buy in the past)
Well, it looks new, dont have the slytest(SP?) sign of use.
Anyway, my problem is, the crancksaft have some .5 mm play, on its longitudinal axis. So, I can pull and push the crancksaft on it's "housing".
Is that normal ? Comparing to the other engine I did buy, it feels strange. The other was very tight in every "axis", if you know what I am trying to explain...
Was that clear ? Is it normal for this engine ? Or even if it isn't the way every CRF comes from the factory, can it be used that way ? (I know that, with the collet and flywheel, that play won't be present, but...)
Ok, hope I can sort this out, So I complaing with the guy or I mount it fast
Thankx guys!
Rawz is offline   Reply With Quote
Old 02-22-2007, 09:27 PM   #932
Z00M's Avatar
Trader Rating: 15 (100%+)
Mine is like that and I don't have issues with it. When I fit the clutch the nut pulls it to the front anyway.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 02-23-2007, 12:53 AM   #933
ziggy12345's Avatar
Mine is like that to. There is nothing inside the engine to stop it floating, only after the flywheel is attached does it stop moving.
The engine is not sealled in a bag either just wrapped in bubble wrap
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 02-23-2007, 02:29 AM   #934
Nano's Avatar
The play in the crankshaft is absolutely normal, the contrary is not normal, it means there is something that binds or is not centered.
The crankshaft has play because the ballbearings are straight and centered and the tolerances are very tight, this means that when the engine is running there is no power lost because the shaft is too tight in the bearings or putting pressure on the bearings because the bearings are not centered.
Bad tolerances are when you have to use a hammer to knock the crankshaft out of the case or use a screwdriver to pull the liner out...
Once you install the clutch, it will remove the play in the crankshaft.
Nano is offline   Reply With Quote
Old 02-23-2007, 10:05 AM   #935
Diesel Racer's Avatar
Originally Posted by Nano
It should work, but from our experience, Byron is not the fuel giving the best results.
Nano
Thanks for that Nano,
I've now found an on-line shop that sells both O Donnell and Tornado and will post it, I've always used Tornado in the past, is there anything to choose between these 2 with the CRF?
Diesel Racer is offline   Reply With Quote
Old 02-23-2007, 10:14 AM   #936
Default Using a Spektrum Temperature Sensor with CRF
Because the combustion chamber bolts on separately on the CRF engine with an extra ring of bolts, what is the best location for the Spektrum temperature sensor for the most accurate measurement, where the cooling head meets the crankcase or the next row of fins up which is adjacent to the glow plug? It just seems a bit tight at the cooling head/crankcase joint for a good reading.
Old 02-23-2007, 11:15 AM   #937
Rawz's Avatar
Ok! Thankx guys!
Old 02-26-2007, 01:03 AM   #938
Nano's Avatar
Diesel Racer,
From the two fuels I guess O'Donnel would be the best choice.
For the temp, we only go by measuring the temperature of the glow plug with a temp gun.
Nano
Old 02-26-2007, 09:13 AM   #939
Rick Hohwart's Avatar
Both Josh Cyrulk and I used Tornado fuel at the 2006 ROAR Nationals with great results. I have no doubt that Tornado fuel and the CRF engine are a great combination.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 02-26-2007, 01:18 PM   #940
Nano & Rick,
Thanks for the feedback, I think I'll stick with the Tornado as I've used it before.
Mark
Old 02-26-2007, 09:23 PM   #941
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Can any other glow plugs be used on the Wasp, other than the Team Orion $10 plugs??
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 02-27-2007, 01:11 AM   #942
Z00M's Avatar
I am currently using the Ninja plugs. They seem to work quite well. I have also used Novarossi and OS plugs. Don't know why they all worked but they did.
XRAY XB4
Old 02-27-2007, 04:28 AM   #943
Guys I am thinking of getting a Wasp 12, but now I am seeing the prices dropping on tower, but I am not sure if it is the updated Josh version or the old version without the updates that they are trying to ge rid of, from what I have noticed the old version part number ORI80000 and the Cyrul version is the same ORI80000, how would I know the difference when making a purchase online???
jelayne is offline   Reply With Quote
Old 02-27-2007, 06:43 AM   #944
ziggy12345's Avatar
Ask them what is says on the box. The new one says Josh Cyril version
Sponsored by:
Norfolk and Chance
Old 02-27-2007, 09:59 AM   #945
Rawz's Avatar
My fuel choices here are very limited(Itīs Byron or ... Byron. With some good contacts I can get Sidewinder, on large packages ...)
But, a LHS is selling Trinity now. Itīs 8% lubrificant. This should be a better choice to use on the CRF, no ? (than Byron, I mean)
Team Orion Wasp REV Nicolas Onroad Nitro Engine Zone 183 10-05-2006 09:04 AM
team orion wasp rev MAVICXXX Malaysian R/C Racers 31 09-19-2006 09:18 PM
Team Orion - Wasp!! BundyMan Onroad Nitro Engine Zone 1 03-03-2006 03:10 AM
Orion Element 19t Dyno results rinkrat99 Electric On-Road 7 10-09-2005 07:29 PM
Team Orion Wasp .12 HaLo_UsMc R/C Items: For Sale/Trade 6 03-16-2005 07:31 PM
