Old 01-15-2007, 09:19 AM   #841
Nano's Avatar
Great to see that you are enjoying the engine's performance impalabob!
Surikarn just won the Serpent Nitro Tour 2007 race in Bangkok this weekend, check out http://teamorion.com/News/ca40/newsid/155
Nano
Nano is offline   Reply With Quote
Old 01-15-2007, 09:46 AM   #842
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
What car was surikarn using?
Artificial-I is offline   Reply With Quote
Old 01-15-2007, 09:48 AM   #843
Moderator
Originally Posted by rmdhawaii
Missed that in your title previously, it's a Murnan Modified CRF.
Interesting. Would love to see some photos of the internals. I had heard he was attempting to modify them. Guess he pulled it off as usual.
Old 01-15-2007, 10:29 AM   #844
Congratulation Surikarn !
WorldCup2004 is offline   Reply With Quote
Old 01-15-2007, 02:55 PM   #845
Serpent 720...
RC_Alan
rc_alan is offline   Reply With Quote
Old 01-15-2007, 04:19 PM   #846
Moderator
Originally Posted by rc_alan
Serpent 720...
RC_Alan
The photo of him , he was holding a car with hot bodies stickers on it. Makes sense as its the serpent nitro tour...
Old 01-15-2007, 04:37 PM   #847
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default hmm
im curious from those who actually use the motor is it really a hot motor i saw josh use it but havent had the pleasure of first hand experience i have no clue
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 01-15-2007, 05:38 PM   #848
dj apolaro's Avatar
No ones motor will be like josh, if nothing else, he has so much experince with clutch, plugs, head clearance, etc. If you take a motor and give it to him he will get more out of it. I have seen a couple of guys with the motor at our state races and it is not bad. Bobby has the most luck with them and his is pretty fast. All of the newer motor are good. They have their differences and ways of being tuned.
dj apolaro is offline   Reply With Quote
Old 01-15-2007, 07:30 PM   #849
Default hmm
thanks just checking
WILLIAM PENDERGRASS
Old 01-16-2007, 09:19 PM   #850
MaDaGAS CAR's Avatar
Send a message via MSN to MaDaGAS CAR
hey guys interested in buy a wasp but want to know a bit of info
first off is this a fast engine compared to a novarossi or a sirio
secondly does it keep its power through out its life? (in other words is it fast to begin with then dies after 10 litres)
how easy is it to get parts for these motors as in rebuild kits, bearings?
wats the life span of the compression how many litres till its dead
if any1 can answer the questions honeslty be much appreciated thanks
MuGeN powered by MAX POWER !!!!
MaDaGAS CAR is offline   Reply With Quote
Old 01-17-2007, 12:23 AM   #851
ziggy12345's Avatar
Talking
The engine is a fast as anything out there. Whether you can drive your car any faster with it in depends on a number of factors. Driving style, Your ability to tune the engine, clutch, select the right exhaust etc.... etc....
The engine is cheap enough to throw it away and buy a new one when its dead.
The engine has very little pinch compared to other engines but that doesnt matter
My last one lasted 4 galls only but it was like new when I put it on the track. The pressure pipe came off the exhaust so it ran lean and it blew a hole in the crankcase. My fault
I am waiting for the Murnan Modified version to be availalbe
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 01-17-2007, 08:45 AM   #852
Nano's Avatar
I work for Team Orion and I will try to anwer your questions.
Performance wise, we believe that our CRF engine concept is superior to other engines concepts and we are working very hard to prove that.
The piston/liner combo is not supposed to wear out. The way the engine is made the piston does not directly touch the liner, it slides on an oil film at the liner's surface. Obviously if you run the engine too lean for extended periods of time it will wear out, but if it's used properly it should require very little maintenance. So basically it should not loose power, even after many many liters of fuel. The engine does not require an extended break-in, just a couple of fuel tanks to make sure everything is running good, it will be very fast out of the box.
The only part that has to be replaced on a regular basis is the rear ball bearing it has to be replaced every 10 hours. Failure to replace the rear bearing can cause the crankshaft to vibrate and cause engine failure.
Again in this engine there is almost no pinch, the compression exists because it is airtight, not because the piston binds on the liner. I know of CRF engines that have run well over 20 liters and are still running as strong as new.
Feel free to ask if you have anymore questions.
Old 01-17-2007, 10:04 AM   #853
rmdhawaii's Avatar
I totally forgot about this..
What is the cause of this problem? Are there exceptions to this rule? (i.e. run on small tracks versus large tracks) Is this something Team Orion is working on addressing? Can this problem be resolved by putting in some other type of bearing (i.e. ceramic?)
Thanks!
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 01-17-2007, 10:31 AM   #854
ziggy12345's Avatar
Thanks!
10 hrs is 2 gals of fuel. Thats pretty good for any bearing.
Sponsored by:
Norfolk and Chance
Old 01-18-2007, 02:41 AM   #855
Nano's Avatar
We have determined that the rear bearing will perform at 100% for a minimum of 10 hours. After 10 hours, the bearing's performance could deteriorate and cause loss of performance and/or engine failure. I am not saying it will happen, I am saying it can happen.
10 hours of running is about 9 liters of fuel (2 gallons), 120 5 minute runs or 10 races. It's not a short period of time...
This was established by the CRF engine designer himself, who always expects 100% performance.
There is probably a lot of people out there running engines which are not performing at 100% but do not notice it, and when the crank pin breaks off, the conrod breaks or the engine seizes, they buy a new engine thinking that their engine has lived it's life.
This happens with all engines, engines need maintenance to maintain their performance. Any engine can last for a long time if it's maintained properly, unfortunately only few know how to do that.
Team Orion Wasp REV Nicolas Onroad Nitro Engine Zone 183 10-05-2006 09:04 AM
team orion wasp rev MAVICXXX Malaysian R/C Racers 31 09-19-2006 09:18 PM
Team Orion - Wasp!! BundyMan Onroad Nitro Engine Zone 1 03-03-2006 03:10 AM
Orion Element 19t Dyno results rinkrat99 Electric On-Road 7 10-09-2005 07:29 PM
Team Orion Wasp .12 HaLo_UsMc R/C Items: For Sale/Trade 6 03-16-2005 07:31 PM
