Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
Team Orion CRF Wasp Rev X-Dyno results >
Old 11-06-2006, 11:37 AM
  #781
impalabob64's Avatar
Default CRF Powered s720
Just got back from Kraceway US SEDAN Championship in Kissimee Fla. 3rd in the A-main open class. The engine was crazy fast, it was the only CRF powered car at the track.The motor stood its ground an was out powering alot of modified motors at the track.I will be running this motor at the Winternats 07.Ps did not ever hve any carb problems at all ,also running 40% nitro.
impalabob64 is offline
Old 11-08-2006, 01:04 AM
  #782
Nano's Avatar
Great news Impalabob!
What pipe were you using? did you change the head clearance?
Nano
Nano is offline
Old 11-08-2006, 05:27 AM
  #783
Default Nana
The pipe was the novarossi 2630, with novarossi med conicol header,no did not add a shim, ran it right out of the box. I will be testing the mega pipe combo 2607.I hve met alot racers that hve given me props on running this engine because they just cant get there,s to run so im kinda the CRF King around these parts.Hint trying to get in with The TeamO
Old 11-08-2006, 10:50 AM
  #784
fastrcracer's Avatar
Impalabob/Nano:
A couple of questions. I have the wasp crf engine and I have ran it a couple of times now. The last time I ran the engine was on the big track in Cincinnati. The engine was awesome, but I had one issue. I could not keep the temperature consistant. One run it would be rich the next it would be lean. I run the RRR with the Orion clutch set and 20% Byrons fuel with a number 6 glow plug stock head shims. This seems like an air leak. I found a couple of things when I cleaned the car up.
One was a torn exhaust gasket and the other was the o-ring at the base of the carb seat was out of its indention. Could these have caused the problem I was having ?
And could the issue with the HSN housing cause this also ?
I have not run the car since as the weather here has not been great in a couple of weeks. Thanks for your insight.
fastrcracer is offline
Old 11-08-2006, 11:07 AM
  #785
ziggy12345's Avatar
Any one of those or all of the 3 things you mentioned can cause the tuning variation. There is a new carb out that addresses the housing problem and always check the exhaust seal. I have a hole in the bottom of the crank after running mine with a split seal!
ziggy12345 is offline
Old 11-08-2006, 11:13 AM
  #786
Default fast
Ziggy is right about that ,i did not hve any of those problems, one of crfs finally went after about 3 gallons of Byrons 40%.
Old 11-09-2006, 09:31 AM
  #787
Nano's Avatar
Thanks for the info impalabob. Btw what do you mean that the CRF went after 3 gallons of 40%, did something break?
About getting in with the Team, please contact Rick Howhart at [email protected]
Nano is offline
Old 11-09-2006, 09:36 AM
  #788
Nano's Avatar
Fastrcracer, maybe the damaged seal and o-ring where the problem. Also you have to check the plastic sleeve around the carburator. If the carb retainer is overtightened, it can squeeze the sleeve and create gaps where air can filter thru.
Also the updated hsn holder may help, it has a bigger bore so it's less sensitive and it makes the engine setup more stable.
The updated carb is exactly the same, it only has a bigger bore to improve low-end power.
Contact your hobby shop or Team Orion USA to get the updated parts you need.
Nano is offline
Old 11-09-2006, 09:41 AM
  #789
Nano, will the new batch come with updated carb ? when are they going to be shipped ? thanks
speedy100 is offline
Old 11-09-2006, 10:17 AM
  #790
Team Kamikaze's Avatar
You're welcome RMD.
The updated parts are being shipped and will be available anytime.
As stated before the needle holder is free and the updated carburator body is offered with a 50% discount.
Who do you contact to get this updated parts? Are you guys going to deal with the consumer directly or thru a hobby shop?
Team Kamikaze is offline
Old 11-09-2006, 01:16 PM
  #791
rmdhawaii's Avatar
If you're planning on getting them from Team Orion USA, call them. Don't rely on email.
rmdhawaii is offline
Old 11-17-2006, 02:53 PM
  #792
Default CRF /MEGAPIPE COMBO 2607
Try this combo you will be amazed ,i hve this on my S720 ,you hve to open the header alittle to fit the crf .My gearing 17/61 22/55or 21/56
Old 11-24-2006, 06:35 AM
  #793
Who has tried the new generation CRF 12 ?
barclayrc is offline
Old 11-24-2006, 05:16 PM
  #794
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Is this basially a CRF with new parts or a completely new model?
HarKonnenD is offline
Old 11-25-2006, 09:41 PM
  #795
Are the stock head shims ok for 30%?Or can I remove one?
Thanks,
Mark
markallen is offline
