Old 07-17-2006, 08:49 PM   #646
Z00M's Avatar
Trader Rating: 15 (100%+)
I run with 16% and seem to have it working. I run with a #6 novarossi or OS plug and I have removed the aluminium shim from the head.
The sound you hear with the engine when it sounds as though it struggles to get fuel or get up to speed on the bottom means the bottom is too lean.
My settings are 4.8lsn, 4.7hsn and half a turn out on the middle needle. I know it's different for every environment but I used the settings that were posted here and worked from there.
Only do your tuning at race temps. Go out and turn some laps hard before making changes and even then only change in small increments as the change in temp will change the behaviour of the motor as well. Creep up on a good setting and then use that as a base whenever you get lost again.
If you then find that the bottom end doesn't have enough, you need to work with your gear chart and your clutch settings.
Cheers,
Mike.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 07-21-2006, 02:17 PM   #647
Josh Cyrul's Avatar
fastrcracer - If you can, get your hands on some Tornado Fuel!! That will be a huge help!! Also, you may just need to lean the bottom end and richen the top. Usually, I tune the engines to idle for at least 30 seconds so it is nice and clean on the bottom end so you have good throttle responce with a consistant idle. I use the top to adjust the temp/power.
Just a bit of news for everyone:
We are currently testing and preparing for the Great Lakes Challenge in Toledo. At the event I will have a display engine set-up for people to take a look at. Also, I am speaking with the event organizer to possibly set-up a few seminars about the engine and proper clutch set-ups and tuning. Team Orion is setting us (Official Hobby Shop of the GLC) up with a bunch of engines, clutches and various other goodies to support the engine. Stop by, say hey and check it out!!
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 07-22-2006, 02:07 AM   #648
ziggy12345's Avatar
Whats the part number for the clutch spring for the CRF??
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 07-23-2006, 08:12 AM   #649
You can find it here : http://www.teamorion.com/products/Nitro+Clutches
WorldCup2004 is offline   Reply With Quote
Old 07-23-2006, 04:17 PM   #650
impalabob64's Avatar
Send a message via AIM to impalabob64
Thumbs up CRF in S720
Hey ,just got the new 720 ,i also hve the G4S with CRF boy this motor is sick in my G4s it is insane,crazy fast in the 720 with 40% nitro temp 200 degrees. can wait to get to the GLC.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 07-23-2006, 04:23 PM   #651
Default PS THANX Josh
Josh thank you for the tuning setup help, both of my cars run flawlessly with 40 % nitro run time 5.30.See at the GLC
RoninRc.com
Basher BT-4
Old 07-24-2006, 12:23 AM   #652
robert maestrey's Avatar
40%
robert maestrey is offline   Reply With Quote
Old 07-24-2006, 08:52 AM   #653
Josh, are you using the sqare spring from CRF ?
Old 07-24-2006, 10:56 PM   #654
Default sup Rob M
Man can wait to get to Toledo.Austin snapped the crank in his Sti Sirio
RoninRc.com
Basher BT-4
Old 07-25-2006, 09:57 AM   #655
SCUBA STEVE's Avatar
Trader Rating: 85 (99%+)
Josh, I hope you do have the seminar! I was having the same problem that fastrcracer was having...I already toasted my CRF once ...I replaced the piston, rod and sleeve but now I'm scared to run it but I need to get it ready for the GLC!.......I hope I don't toast it again or I may not be racing
SCUBA STEVE is offline   Reply With Quote
Old 07-25-2006, 10:31 AM   #656
Josh Cyrul's Avatar
WorldCup2004 - That's the ONLY spring I use now!!! Even in my 1/8 cars!!
Scuba - When you get to the GLC, just stop by and see me. I'll be on hand a little on Tuesday but from Wednesday on, I'll be there all day, every day!!
I have to work out a few things with Ted and club but I'm sure we can set up some good seminars for the week and weekend to help everyone out.
Old 07-25-2006, 10:48 AM   #657
fastrcracer's Avatar
Thanks to Josh and everyone for the help. I think I got it going now. Just a little tweaking on the needles and idle speed and it seems to be running great now.
Josh - I have since switched to Byrons fuel, our lhs doesn't carry Tornado fuel. Where could I pick some up or who can the lhs contact to order. Also, I can't make the GLC this year, baby due that weekend. Are the pipes and clutches available through the lhs for the CRF motor yet ?
Thanks everyone and good luck at the GLC.
Associated FT SC10
Futaba 3PK
AKA Tires
Maxamps Batteries
SRI Raceway, Louisville KY
fastrcracer is offline   Reply With Quote
Old 07-25-2006, 12:13 PM   #658
Default But!!
Originally Posted by WorldCup2004
Where does one buy these mythical parts?
The motor is not that much better than anything else that I will waste a bunch of international telephone calls to order parts.
The least Orion could do is answer the mail sent to the email adresses that are listed on their site for sales.
At their prices I am not going to beg for the parts. (perhaps that is the angle)
If they want to play the game then they need to keep up with the big dogs.
I can get Novarossi, Mega, JP , anything, - online.
Their dealer this end knows less than I do about the parts.
Do these parts actually exist or are they just trying to maintain hope while they sell motors?
If the parts are not freely available on the mainstream hobby sites then as far as I am concerned they do not exist.
Clarity on this would give some credibility to the motor.
C Mike Hunt is offline   Reply With Quote
Old 07-25-2006, 01:38 PM   #659
Moderator
mxwrench's Avatar
Mike, try Ultimate hobbies in California, as I believe they have all the parts in stock now.
BK
Brian Kinney
TLR Design Engineer
2016 Sponsors: Team Losi Racing, AKA Tires, Orion, Nitrotane, Horizon Hobbies, Fast RC Paint.
mxwrench is offline   Reply With Quote
Old 07-25-2006, 01:50 PM   #660
Rick Hohwart's Avatar
Call Team Orion USA and buy them if you are in th US.
As much as we wish we could, we can't force distributors or hobby shops to carry the spare parts. Only customer requests will convince them that they need to.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Team Orion Wasp REV Nicolas Onroad Nitro Engine Zone 183 10-05-2006 09:04 AM
team orion wasp rev MAVICXXX Malaysian R/C Racers 31 09-19-2006 09:18 PM
Team Orion - Wasp!! BundyMan Onroad Nitro Engine Zone 1 03-03-2006 03:10 AM
Orion Element 19t Dyno results rinkrat99 Electric On-Road 7 10-09-2005 07:29 PM
Team Orion Wasp .12 HaLo_UsMc R/C Items: For Sale/Trade 6 03-16-2005 07:31 PM
